Out of easyness I’d like to access item names by a variable (e.g. var(item) or var(actionCommand)) within a STANDARD MainUI component to be used for other properties.
This makes it easier to copy/paste directly in yaml code
it is easier to maintain your pages if you add new items or if you replace item.
I do not mean variable in the way which is described in your link. have a look at how I try to access an item and the value of actionCommand by an ‘implicit’ variable in the last line of my example (background:)
sure it is wrong syntax, as it is just for explanation purpose. what is the correct syntax?
The link I quoted explains what types of variables are available in OH and how they have to be structured to access an item name which is stored in that variable. To be precise =items[vars.someVar].state
What I think you realy want to know, if it’s possible to access the value of a config parameter which answer is no as far as I can tell. And I personally does not see a benefit in doing so - but feel free to open an issue for that if you seeing something that I’m not aware of.
You can doing all of that with properties inside a custom widget of course.
You can verify this by e.g. adding the following code to config.label (where TestItem is the openHAB item toy want to use in the widget:
label: =JSON.stringify(items[TestItem])
The label will display the entire contents of the JSON object returned by openHAB3, and it only contains 1 tuple, as in:
{"state":"-"}
So unfortunately the item name is not available through a property of the item. Maybe this could be changed by filing a PR to the openHAB core developers.
