Variable Wakeup-Time Sequence
A more common way to solve this issue:
rule "wakeup"
	Item wakeup_Felix_hour changed or
	Item wakeup_Felix_minute changed
	wakeupTimer?.cancel
    var Integer nHour = null
    var Integer nMinute = null
    if(wakeup_Felix_hour.state instanceof Number) nHour = wakeup_Felix_hour.state as Number
    if(wakeup_Felix_minute.state instanceof Number) nMinute = wakeup_Felix_minute.state as Number
    logInfo("wakeup", "Starting timer {}:{}",nHour,nMinute)
    if(nHour === null || nMinute === null) {
        logWarn("wakeup","Time not set!")
        return;
    wakeupTimer = createTimer(now.plusDays(1).withTimeAtStartOfDay.plusMinutes(nHour*60 + nMinute), [|
		logInfo("wakeup", "Time is up")
		wakeupTimer = null
withTimeAtStartOfDay is Midnight, plusMinutes adds the given amount of Minutes.
Please always ensure that type of data is correct to avoid null-pointer-exceptions.
