You can’t install a binding not mentioned as compatible to OH2 with the addons.cfg, so the message is absolutely correct. Don’t touch addons.cfg for manual installation, as it’s … manual…
Did you configure a device in services/vdr.cfg yet? I’m not sure about user/password, as I did not set any user/password in my vdr.
As Volume is a Number, you will have to link to a Number Item or at least to a Dimmer Item.
As Channel is also a Number, you will have to link this to a Number Item (and use setpoint in the sitemap to change the channel).
is there anyone who’d be interested in a VDR binding for openhab2 or openhab3?
I’ve created a binding for my personal use based on the original openhab 1 binding.
As my time is limited I wouldn’t invest the effort to polish it for public use if there is no interest in it.
Dear @ruperts, thanks for your feedback.
Here’s a binary for openhab 2.5.x.
A thing needs to be created for each vdr. Either in PaperUI or in things file.
Thing vdr:vdr:srv “VDR” @ “Serverschrank” [ ip=“192.168.0.21”, port=6419, refresh=30 ]
Shutdown, Volume and Channel can be changed. Message and Keycode support.
Current and Next EPG entry are also available by polling.
works perfectly: I simply stopped OH (I’m on version 2.5), exchanged the jar file (was vdr-1.15.0 before), and started OH. No other changes were necessary. Thank you!
I will definitely give it a try to do an official submit.
But I use a library (svdrp4j) that is not available in the common maven repositories and the whole process to get the binding ready for a pull request is quite complicated for the hobby programmer I am.
There seems to be a problem, at least with the current version for openHAB 3.4.2
See
and
for reference.
When a thing with vdr addon is active, there is an error Message in the log each time the Items list is loaded (e.g. in VS Code openhAB plugin):
[ERROR] [al.ChannelCommandDescriptionProvider] - Dynamic command description matches original command description. DynamicCommandDescriptionProvider implementations must never return the original command description. class org.openhab.core.internal.types.CommandDescriptionImpl has to be fixed.
If stopping the bundle, the errors are gone immediately.
