steve_su
(steven surinx)
January 5, 2020, 8:42pm
#1
hello everyone,
i’am trying to get my velbus to work with openhab , i have installed velserv on the raspberry pi3B and i can connect velbusLink throug the server.
as it comes with the binding i’ve got no luck yet, in the config of the bridge i can not select tcp only serial,
the binding i installed is 2.5 .
when i check the supported things i can’t seem to find the VMB1TS sensor ,is it not supported ?
i hope someone can help me
greatings steven
I searched the forum and this thread looked promising.
Hey @Geert_Verbist
Did adding the V1 serial binding from within PaperUI solve the problem?
Cédric says…
I defined a dependency on the serial binding, so when installing the binding from the official distribution I expect the serial binding to be installed automatically. However, using a jar file to install the latest version of the binding might bypass this dependency check. Once the VMBELx en VMB4AN modules are integrated I should make some time to merge all changes of the 12 months…
steve_su
(steven surinx)
January 5, 2020, 10:02pm
#3
hé Bruce ,
thanks for pointing me to that thread ,i now see the velbus network bridge and scant the velbus and found all the modules.
I just can’t find the channel for the “current temperature” of the VMB1TS, but i’am going to look at that tomorrow
and thanks again
greatings Steven
MDAR
January 5, 2020, 10:18pm
#4
Hello
Which version of the binding are you using?
As I think there is a slight issue with the VMB1TS, I used to see it working, but not mine isn’t initialising.
steve_su
(steven surinx)
January 6, 2020, 8:34pm
#5
hi Stuart,
it is velbus 2.5,
I read about it, so i have to be patient., i am still discovering openhab ,so i have much to learn
greatings
MDAR
January 6, 2020, 9:25pm
#6
steve_su:
Please feel free to ask any questions regarding Velbus in openHAB2, I’ll help where I can.
Good luck
MDAR
January 8, 2020, 12:11pm
#7
Hello Steve
Cédric has worked his magic on the Velbus binding yesterday and got the VMB1TS working again.
Please check this forum thread for advice on how to download this development version.
steve_su
(steven surinx)
January 10, 2020, 10:18pm
#8
hé Stuart,
got it back to work, i struggled with something and had to reinstall openhab.
thanks
Just updated the Velbus binding on my Odroid using this methode mentioned on the Velbus forum.
I had the same issue where VMB1TS wouldn´t go online after updating OH to 2.5.1-2.
Now it works great again. Thank you Stuart (and Cedric ofcouse!).
