Hi guys!
My System;
- openHAB 4.2.2
- Ubuntu 20.04 LTS
- Verisure binding 4.2.2
Today I noticed an error message from Verisure binding.
ll, support=null, typename=null], typename=Device], type=null, state=CLOSE, wired=false, reportTime=2021-03-18T13:20:39.000Z, typename=DoorWindow]], communicationState=[], mice=[], doorlocks=[], smartplugs=[], userTrackings=[], typename=Installation]]])
19:43:58.775 [DEBUG] [ing.verisure.internal.VerisureSession] - HTTP GET: https://mypages.verisure.com/batterywizard/choose/device?_
19:43:58.825 [WARN ] [ing.verisure.internal.VerisureSession] - Failed to query for door&window status: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was STRING at line 1 column 1 path $
19:43:58.830 [DEBUG] [ing.verisure.internal.VerisureSession] - HTTP GET: https://mypages.verisure.com/batterywizard/choose/device?_
19:43:58.858 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWave_Node_008_TZWP102_Telldus_socket_and_energy_meter_Electric_meter_watts' changed from 25.278 to 472.258
19:43:58.869 [WARN ] [ing.verisure.internal.VerisureSession] - Failed to query for door&window status: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was STRING at line 1 column 1 path $
19:43:58.871 [DEBUG] [ing.verisure.internal.VerisureSession] - HTTP GET: https://mypages.verisure.com/batterywizard/choose/device?_
19:43:58.903 [WARN ] [ing.verisure.internal.VerisureSession] - Failed to query for door&window status: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was STRING at line 1 column 1 path $
19:43:58.904 [DEBUG] [ing.verisure.internal.VerisureSession] - HTTP GET: https://mypages.verisure.com/batterywizard/choose/device?_
19:43:58.938 [WARN ] [ing.verisure.internal.VerisureSession] - Failed to query for door&window status: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was STRING at line 1 column 1 path $
19:43:58.939 [DEBUG] [ing.verisure.internal.VerisureSession] - HTTP GET: https://mypages.verisure.com/batterywizard/choose/device?_
19:43:58.975 [WARN ] [ing.verisure.internal.VerisureSession] - Failed to query for door&window status: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was STRING at line 1 column 1 path $
19:43:58.977 [DEBUG] [ing.verisure.internal.VerisureSession] - HTTP GET: https://mypages.verisure.com/batterywizard/choose/device?_
19:43:59.010 [WARN ] [ing.verisure.internal.VerisureSession] - Failed to query for door&window status: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was STRING at line 1 column 1 path $
19:43:59.014 [DEBUG] [ing.verisure.internal.VerisureSession] - HTTP GET: https://mypages.verisure.com/batterywizard/choose/device?_
19:43:59.050 [WARN ] [ing.verisure.internal.VerisureSession] - Failed to query for door&window status: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was STRING at line 1 column 1 path $
19:43:59.053 [DEBUG] [ing.verisure.internal.VerisureSession] - Querying API for user presence status
19:43:59.056 [DEBUG] [ing.verisure.internal.VerisureSession] - postVerisureAPI URL: https://m-api01.verisure.com/graphql Data:[{"operationName":"userTrackings","variables":{"hideNotifications":false,"offset":0,"pagesize":0,"giid":"60758098062"},"query":"query userTrackings($giid: String!) {\ninstallation(giid: $giid) {\n userTrackings {\n isCallingUser\n webAccount\n status\n xbnContactId\n currentLocationName\n deviceId\n name\n currentLocationTimestamp\n deviceName\n currentLocationId\n __typename\n}\n __typename\n}\n}\n"}]
19:43:59.060 [DEBUG] [ing.verisure.internal.VerisureSession] - Setting cookie with vid smt5oc4rg4tq9glej5tlbs6pb4
19:43:59.063 [DEBUG] [ing.verisure.internal.VerisureSession]
I noticed this error message after upgrading to OH 4.2.2 from 4.2.1 but I cannot say that it is depending on the upgrade. It may have existed for a while.
Searching in the community forum I could not find any simular but I found an answer in another forum that says:
The error message you got "expected BEGIN_ARRAY but was BEGIN_OBJECT at line 1 column 2" usually indicates that the JSON response from the server is an object ({}) instead of an array ([]). To fix this, you need to update your code to handle the response correctly.
My verisure system contains 7 door/windows sensor and that number corresponds to the number of error messages,
I have deleted all items for detection of low battery but that did not help to get rid of the error messages.
I have also noticed that the binding stops frequently, Still active when using bundle:list in karaf console but the items says āERROR:BRIDGEā.
If I go into the bridge thing and just saves the thing all things go online for a while and then goes into ERROR:BRIDGE again.
So I am wondering if any of you have seen this or anything simular?
My reflection is that the binding needs to be updated based on the answer I found but that is just a guess from me.
So if any of you have som tips for correcting this problem I am thankful.
Regards,
Olle.
