ERROR is a higher log level than INFO. I’ll switch that message over to WARN I think. Are you getting data on your channels? A lot of those errors are not so much ‘errors’ and I probably need to knock down the default debugging (checksum problems happen pretty regularly in my experience as two messages stumble over each other – they can be ignored as it’s sending data every few seconds). I just pushed a new jar up that fixes some of the debugging info and got rid of that message about the relay (that wasn’t supposed to make it out yet :D)
Thing is: after setting the binding to TRACE and back again to INFO, it still spits out all information.
So it is:
- binding does the INFO logging
log:set TRACE org.openhab.binding.VEDirect
- binding does the TRACE logging
log set INFO org.openhab.binding.VEDirect
- binding still does the TRACE logging
even after deleting the JAR, restarting OH3, or rebooting the Pi…
So, I replaced it with the yesterday’s version and got this (still with INFO logging), was too fast for fontail, so I’ll have it split in:
openhab.log:
2021-10-01 07:58:22.119 [INFO ] [internal.VEDirectSerialBridgeHandler] - vedirect:serial:VEDirectShunt: Initializing VEDirect Serial Bridge: /dev/ttyUSB_shunt
2021-10-01 07:58:22.150 [INFO ] [internal.VEDirectSerialBridgeHandler] - vedirect:serial:VEDirectShunt: Connecting to VE.Direct using /dev/ttyUSB_shunt.
2021-10-01 07:58:22.226 [INFO ] [internal.VEDirectSerialBridgeHandler] - vedirect:serial:VEDirectSolar: Initializing VEDirect Serial Bridge: /dev/ttyUSB_solar
2021-10-01 07:58:22.246 [INFO ] [internal.VEDirectSerialBridgeHandler] - vedirect:serial:VEDirectSolar: Connecting to VE.Direct using /dev/ttyUSB_solar.
2021-10-01 07:58:22.272 [INFO ] [internal.VEDirectSerialBridgeHandler] - vedirect:serial:VEDirectSolar: Connection established using /dev/ttyUSB_solar. Configuring IO parameters.
2021-10-01 07:58:24.890 [ERROR] [internal.VEDirectSerialBridgeHandler] - Invalid block: Csum 7437!
2021-10-01 07:58:24.893 [ERROR] [internal.VEDirectSerialBridgeHandler] -
PID 0xA389
V 26115
VS -12
I 444
P 12
CE 0
SOC 1000
TTG -1
Alarm OFF
AR 0
BMV SmartShunt 500A/50mV
FW 0407
MON 0
Checksum z
2021-10-01 07:58:24.897 [ERROR] [internal.VEDirectSerialBridgeHandler] - Invalid block: Csum 5875!
2021-10-01 07:58:24.899 [ERROR] [internal.VEDirectSerialBridgeHandler] -
H1 -76272
H2 0
H3 0
H4 0
H5 0
H6 -813142
H7 24310
H8 29052
H9 0
H10 6
H11 0
H12 0
H15 -23
H16 0
H17 2077
H18 2159
Checksum
2021-10-01 07:58:25.887 [ERROR] [internal.VEDirectSerialBridgeHandler] - Invalid block: Csum 7437!
2021-10-01 07:58:25.890 [ERROR] [internal.VEDirectSerialBridgeHandler] -
PID 0xA389
V 26117
VS -13
I 464
P 12
CE 0
SOC 1000
TTG -1
Alarm OFF
AR 0
FW 0407
MON 0
Checksum u
2021-10-01 07:58:25.894 [ERROR] [internal.VEDirectSerialBridgeHandler] - Invalid block: Csum 5875!
2021-10-01 07:58:25.896 [ERROR] [internal.VEDirectSerialBridgeHandler] -
H1 -76272
H2 0
H3 0
H4 0
H5 0
H6 -813142
H7 24310
H8 29052
H9 0
H10 6
H11 0
H12 0
H15 -23
H16 0
H17 2077
H18 2159
Checksum
2021-10-01 07:58:26.889 [ERROR] [internal.VEDirectSerialBridgeHandler] - Invalid block: Csum 7437!
2021-10-01 07:58:26.891 [ERROR] [internal.VEDirectSerialBridgeHandler] -
PID 0xA389
V 26118
VS -12
I 490
P 13
CE 0
SOC 1000
TTG -1
Alarm OFF
AR 0
FW 0407
MON 0
Checksum u
events.log:
2021-10-01 07:58:21.899 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:mppt:VEDirectShunt:BinderSolar' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2021-10-01 07:58:22.099 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:serial:VEDirectShunt' changed from UNINITIALIZED to INITIALIZING
2021-10-01 07:58:22.128 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:serial:VEDirectShunt' changed from INITIALIZING to UNKNOWN
2021-10-01 07:58:22.181 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:serial:VEDirectShunt' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Port in use: /dev/ttyUSB_shunt
2021-10-01 07:58:22.187 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:mppt:VEDirectShunt:BinderSolar' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2021-10-01 07:58:22.208 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:serial:VEDirectSolar' changed from UNINITIALIZED to INITIALIZING
2021-10-01 07:58:22.214 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:mppt:VEDirectShunt:BinderSolar' changed from INITIALIZING to ONLINE
2021-10-01 07:58:22.238 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:serial:VEDirectSolar' changed from INITIALIZING to UNKNOWN
2021-10-01 07:58:22.270 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:bmv:VEDirectSolar:BinderShunt' changed from UNINITIALIZED to INITIALIZING
2021-10-01 07:58:22.293 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:bmv:VEDirectSolar:BinderShunt' changed from INITIALIZING to ONLINE
2021-10-01 07:58:22.300 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:serial:VEDirectSolar' changed from UNKNOWN to ONLINE
2021-10-01 07:58:24.407 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BinderSmartShunt500A_Battery1_Current1' changed from 0.74 to 0.44 A
2021-10-01 07:58:40.399 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BinderSmartShunt500A_Battery1_Current1' changed from 0.44 A to 0.5 A
2021-10-01 07:58:56.400 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BinderSmartShunt500A_Battery1_Current1' changed from 0.5 A to 0.49 A
2021-10-01 07:59:12.397 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BinderSmartShunt500A_Battery1_Current1' changed from 0.49 A to 0.46 A
2021-10-01 07:59:27.406 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BinderSmartShunt500A_Battery1_Current1' changed from 0.46 A to 0.52 A
2021-10-01 07:59:30.289 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:mppt:VEDirectShunt:BinderSolar' changed from ONLINE to UNINITIALIZED
2021-10-01 07:59:30.314 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:mppt:VEDirectShunt:BinderSolar' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-10-01 07:59:30.317 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:serial:VEDirectShunt' changed from OFFLINE (COMMUNICATION_ERROR): Port in use: /dev/ttyUSB_shunt to UNINITIALIZED
2021-10-01 07:59:30.341 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:serial:VEDirectShunt' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2021-10-01 07:59:30.344 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:mppt:VEDirectShunt:BinderSolar' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2021-10-01 07:59:42.396 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BinderSmartShunt500A_Battery1_Current1' changed from 0.52 A to 0.48 A
2021-10-01 07:59:42.862 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:bmv:VEDirectSolar:BinderShunt' changed from ONLINE to UNINITIALIZED
2021-10-01 07:59:42.882 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:bmv:VEDirectSolar:BinderShunt' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-10-01 07:59:42.887 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:serial:VEDirectSolar' changed from ONLINE to UNINITIALIZED
2021-10-01 07:59:42.941 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:serial:VEDirectSolar' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2021-10-01 07:59:42.950 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'vedirect:bmv:VEDirectSolar:BinderShunt' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
Hm. Would you be able to send me a copy of your original openhab.log? Not sure why that checksum is coming up bad, will need to see the raw bytes. Will PM you my email address.
Dears,
I search a binding for OH2.
This binding runs only on OH3, right?
Thank you for your feedback
Any chance this project is still alive? I have a BMV-702 attached via USB (VE.direct) and I’m looking for a more direct way to communicate with it than over mqtt, as I’m currently doing.
Still is. Haven’t done a release though in a while for the latest OpenHAB. Will try to get something pushed out in the next few days.
That’s great news
I tried the latest jar file on an Raspberry Pi 4 Model B Rev 1.1 running openHAB 3.3.0 - Release Build with just one VE.Direct serial cable attached. Openhab detects the cable, but I cannot see the device connected to it, a BMV-702, in the GUI. I can see all the values in the log, though. Should this already work on openHAB 3.3? I 'd be happy to do some testing/validation/etc.
From the log:
21:40:42.206 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'vedirect:serial:VE4WQMJU' has been added.
21:40:42.206 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'vedirect:serial:VE4WQMJU' to inbox.
21:44:35.996 [ERROR] [covery.VEDirectDeviceDiscoveryService] - Declaring Unknown Device
21:44:36.929 [ERROR] [.internal.VEDirectSerialBridgeHandler] - vedirect:serial:VE4WQMJU: Invalid block: Csum 6413 !
21:44:36.933 [ERROR] [.internal.VEDirectSerialBridgeHandler] - vedirect:serial:VE4WQMJU:
PID 0x204
V 24237
I -2299
P -56
CE -10694
SOC 962
TTG 4277
Alarm OFF
Relay OFF
AR 0
BMV 702
FW 0311
Checksum A
21:44:37.017 [ERROR] [.internal.VEDirectSerialBridgeHandler] - vedirect:serial:VE4WQMJU: Invalid block: Csum 6899 !
21:44:37.021 [ERROR] [.internal.VEDirectSerialBridgeHandler] - vedirect:serial:VE4WQMJU:
H1 -155119
H2 -10695
H3 -130587
H4 2
H5 0
H6 -8658849
H7 10
H8 30891
H9 25463
H10 135
H11 0
H12 0
H15 1
H16 11
H17 21465
H18 23750
Checksum
