Viessmann API binding
Screenshot from 2022-09-19 12-44-16
Viessmann API Binding
This binding integrates Viessmann heating devices using the Viessmann API.
It provides information similar to what you can get through the ViCare mobile app.
Please note this binding is unofficial and not endorsed by Viessmann in any way.
Supported Devices
Currently this binding has only been tested with Vitodens 100-W in a fairly
basic configuration, however it should support other Viessmann devices.
Supported Features
  • Temperature sensors
  • Temperature setpoints (read-only)
  • Burner status
  • Burner modulation
  • Burner statistics (hours and starts)
  • Circulation pump status
  • Frost protection status
  • Basic text properties: device serial number etc.
  • Consumption statistics
  • Program mode temperature settings
  • DHW Heating status
  • DHW Hot water storage temperature
  • DHW Primary and Circulation Pump Status
  • Holiday Program settings
  • Heating curve settings
Configuring
In order to use the binding, you will need to have a Viessmann API account and
configure it with the redirect URL for your OpenHAB installation and then authorise
the binding. Follow the instructions in openhab at http://<Your OpenHAB>/vicare/setup
After authorising the binding, you should be able to add the Viessmann API Bridge item.
Configure it with your Client ID which you should obtain from the Viessmann Developer
portal.
Once configured, then it should automatically discover any heating devices you have
and they will appear in your Inbox.
Changelog
3.3.2
Polling interval is now configurable.
Read-only support for additional features:
  • Burner status
Note that the names of some channels may have changed slightly in order to
distinguish between “active” and “status”. Status channels are now of String type
and not Switch - you may need to either change your linked item type accordingly or
apply a transformation to the value.
Fix #2 If more than one boiler is configured, the binding doesn’t work correctly
3.3.1
This is the initial release
Resources
Github source code
Github Release binary
I get the following error for the authorising:
{"error":"Client not registered."}
After filling the client ID manually in the url, I get this error:
Received error from server: invalid-token-request
I think your correct URL is:
http://192.168.101.120:8080/vicare/authCode
Ther is a Space missing after that.
Currently you write:
.....vicare/authCodeOnce this is done, then.....
Sounds like either:
  • you don’t have a clientId from Viessmann - you need to go to https://developer.viessmann.com and sign up for their API, once you’ve done that the clientId is shown in the Developer Portal Dashboard
You also need to configure it with the redirect Uri to your own OpenHAB install as shown
Then you should be able to go to /vicare/setup on your OpenHAB install and authorise it.
Edit: Ah ok I see you’ve done this
Yes, you are right, there is a typo in the URL, on the setup page. It will be fixed in the next release
I cannot find your bridge …
I just copied the binding in the addon folder … any other steps necessary to see your bridge?
You should be able to add the bridge as soon as the binding is installed - just go to Settings->Things, click ‘+’ → Select Viessman API Binding → Viessman API Bridge
Works for the first step :slightly_smiling_face:
But for me the binding doesn’t supply all the information I like to have.
I’m looking for these items :innocent:
I’ve created a github issue Support additional features on Viessmann API Binding · Issue #1 · rtuck99/openhab-binding · GitHub
It’ll take a little while to decode all that :slight_smile:
I think you should have quite a few of those supported already though, this is what my heating system shows:
I will continue my testing on friday :grinning:
If I remember, my item list was not so long :thinking:
I’ve updated the github issue, there is a link to a spreadsheet on it with a breakdown of what features correspond to what.
There are some features that are advanced features and only available in Viessmann’s paid-for API. If there’s demand for it, I might consider supporting if people are willing to send sample API responses to develop against.
The other ones, some I can support fairly easily but others I will need to see what the API is returning. I will see if I can get you a debug version of the addon that will record what comes back from the API so I can support them.
There is one of the values “Externe Betriebsartenumschaltung” that I really have no idea what it is “External operating mode switchover”? Do you have a better translation? I can’t find anything that looks like a likely candidate in Viessmann’s API documentation.
“Externe Betriebsartenumschaltung” means an external “switch” for changing the operation mode.
The API ist an internal switch :wink: - so not really necessary
Additional features requested should now be supported in 3.3.2
looks good :+1:
when I create items in vscode from the vscode extension for openhab (create items from channel), all items are undefined
thanks for integrating the Viessmann API. I have been waiting for years to integrate my Viessmann Heating to OpenHab.
I installed you binding (version 3.3.2) and created the bridge. I have added the correct client ID. But it remains in state unknown (no log message why). Once I add the Heating Device I get the following NullPointerException:
‘com.qubular.openhab.binding.vicare.internal.VicareDeviceThingHandler@5a9d76’: null
at com.qubular.openhab.binding.vicare.internal.VicareUtil.decodeThingUniqueId(VicareUtil.java:25) ~[?:?]
at com.qubular.openhab.binding.vicare.internal.VicareDeviceThingHandler.initialize(VicareDeviceThingHandler.java:62) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor107.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
Any advice?
Thanks a lot!
Björn
Hi there,
It sounds like it can’t find a property defined on the Device Thing. There should be a property
deviceUniqueId that is automatically populated on the Thing when it is created in the Inbox.
If you are creating it via a text file, it won’t work, as the info in this needs to be obtained from the API.
I’m not familiar with the VSCode extension. Where does it get the information for the channel definitions from?
I dont know … I just use it :see_no_evil:
In the UI I can see the correct definition … ok, thats more nice to have :grinning:
In current version I’m missing the channel for the normal mode “DWH” or “DHWandHeating”.
Can you mark which channel are writeable?
I test to set the eco od comfort mode but without success …
The channels for:
heating_dhw_pumps_primary_active and heating_dhw_pumps_circulation_active give an UNDEV back.
Currently there’s no write support for any of the channels, although I am planning it. I’ve raised an enhancement for operating.modes.active property which is what selects between DHW, heating and DHW+heating
The heating_dhw_pumps_primary and heating_dhw_pumps_circulation features don’t have an “active” property for some reason, only “status”. Hence they are UNDEF. TBH I am not entirely sure what the distinction is between “active” and “status” properties, I haven’t figured out why sometimes one is used and not the other. But some things have both, and sometimes the status is something other than “on” or “off”, like “connected” or “error”.
I will have a bit of a look at VSCode, although I don’t think I’m doing anything unusual, so it should just work?
sounds good :slight_smile:
So like I wrot, the vscode method for creating items is mor “nice to have”.
Suggestion from my side:
Make the differnt modes and pump for dhw circulation writeable.
My plan is to change between these modes in depend of outside temp and if someone is present in the house or all outside.
Like:
Outside > 10 degree, no one present – change mode to reduced
Outside > 19 degree, change mode to dhw only
Outside < 11 degree, no one present, change mode to eco
No-one present, stop dhw circulation
And so on. Today I do this manually … but this is not smart :stuck_out_tongue_winking_eye:
