Thanks for the feedback on the instructions. I now see that they are wrong - I will fix them for the next release.
The binding only supports 3.3.x, I suspect you have 3.2 installed - the core library interface is different and that’s what causes the exceptions and missing values.
function getRoomTemperature($circuitId = NULL): string
return $this->viessmannFeatureProxy->getEntity($this->buildFeature($circuitId, self::SENSORS_TEMPERATURE_ROOM))->getProperty("value")["value"];
If the feature is really not present in current version, could you add this? This is quite useful to make more automatics
Could someone paste an example of working bindings configuration for heating device (Thing/Channel) in *.things file? When I’m adding from GUI based on Inbox notifier, then works great. However when copy settings into *.things then still I have some issues: HANDLER_INITIALIZING_ERROR. Pretty sure I have to add more properties, but for first view I can not find what it can be.
heating.circuits.N.sensors.temperature.room isn’t currently supported as I’ve yet to encounter an installation which has it. If you send me your API response JSON (as documented elsewhere in this forum), I can add support for it.
At the moment I don’t support creation of things from files as the binding creates various properties in the Thing and Channels but you can’t specify these in the config file, you can only specify configuration parameters (which are not the same thing). These are derived from what the API returns and aren’t documented because I might change them in future (and OpenHAB doesn’t even let you see the ones on the channels in the UI).
Also the channel types may change in future - I am currently working on dynamically creating channel types from templates, as the number of different properties and installations makes it difficult to cater for everything. It will also allow (eventually) some of the info from the API to appear in things such as UI controls e.g. limits for temp settings, which can only be exposed via the channel type. Having channels hard-coded in user’s .thing files would make this difficult to support.
Need to some if possible - I got stuck at the following point:
I had problems with the bridge in “unknown” state so I removed the Viessmann API binding. Then I also deleted the client on the Viessmann developer page. Stopped openHAB, cleaned cache and restarted openHAB.
I have then re-installed the Viessmann API binding. When I open /vicare/setup it still says binding is “AUTHORISED” and even shows me two two devices. When I click on “Authorise ViCare Binding” then I get the message “error:Client not registered”.
Then I add the Viessmann API Bridge via openHAB-UI and enter the current Client ID of Viessmann client. Thing gets created (stays in UNKNOWN state) and throws an error in log:
12:09:31.280 [WARN ] [icare.internal.VicareDiscoveryService] - Unexpected error occurred scanning Viessmann API
at java.util.Objects.requireNonNull(Objects.java:221) ~[?:?]
at java.util.ImmutableCollections$MapN.(ImmutableCollections.java:827) ~[?:?]
at java.util.Map.of(Map.java:1399) ~[?:?]
at com.qubular.openhab.binding.vicare.internal.VicareDiscoveryService.discoverHeating(VicareDiscoveryService.java:146) ~[?:?]
at com.qubular.openhab.binding.vicare.internal.VicareDiscoveryService.lambda$scanJob$0(VicareDiscoveryService.java:104) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
at java.lang.Thread.run(Thread.java:834) [?:?]
Not sure how to get that solved. I have tried to remove the binding so many times and reinstalled it. Is there still something left somewhere which I can delete manually? Or any other idea of what to do in order to get rid of the UNKNOWN state?
Using OH 3.3 Stable and latest Viessmann API binding 3.3.5.
If you “deleted” the client on the Viessmann site ( how?), I’d suspect you can’t connect via the binding nor via ViCare. Or am I missunderstanding what you actually did?
Sorry, I should have mentioned that I created a new client on Viessmann’s page and used the new client ID when creating the Bridge thing.
…plus, on the developer portal page of Viessmann I see that the section “Use of the API transaction” increases the number of transactions constantly meaning the binding is connected.
When enabling the “Response Capture Debug” I don’t see a file with extension “.json”. I even did a restart of openHAB.
/userdata/cache/org.eclipse.osgi there are only many subfoldes with increasing numbers containing a data folder each. No one contains a file with anything like “capture”.
In userdata/cache there is a LOG file containing:
!ENTRY org.eclipse.osgi 4 0 2022-11-29 20:29:14.411
!MESSAGE Error stopping the framework.
!STACK 0
org.osgi.framework.BundleException: Could not lock the system bundle state for shutdown.
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:230)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:226)
at java.base/java.lang.Thread.run(Thread.java:834)
!ENTRY org.apache.karaf.log.core 4 0 2022-11-29 20:29:30.248
!MESSAGE FrameworkEvent ERROR
!STACK 0
java.lang.IllegalStateException: Configuration Admin service has been unregistered
at org.apache.felix.cm.impl.ConfigurationAdminImpl.getConfigurationManager(ConfigurationAdminImpl.java:325)
at org.apache.felix.cm.impl.ConfigurationAdminImpl.getConfiguration(ConfigurationAdminImpl.java:156)
at org.apache.karaf.log.core.internal.LogServiceImpl.getConfiguration(LogServiceImpl.java:121)
at org.apache.karaf.log.core.internal.LogServiceImpl.setLevel(LogServiceImpl.java:103)
Does this mean anything? If not, is the binding not able to even write the debug into a file?
Yesterday after my post I did a clean-cache in OH3 and restarted it.
Now there is no new LOG file created in userdata/cache but also no installationsResponseCapture.json…
What still wonders me:
if I delete the things and uninstall the binding, do a clean-cache and restart OH23… when installing the Viessmann binding again and go to http://xxxxxx/vicare/setup, why does it immediately show me the two entries again? Is there a way to really delete the information related to the Viessmann binding?
I don’t think that log message is specifically related to the Viessmann binding. If you have authorised the binding, and go to the setup page and it renders the list of connected devices (as in your screenshot), if you have set the REsponse Capture Debug option when it shows the page, it will definitely create the capture file, you just need to find it. just type something like
find . -name *.json
it will be in there.
Regardless, you’ll need to wait for the next release for a fix.
2022-12-04 09:43:06.436 [WARN ] [care.internal.VicareDiscoveryService] - Authentication problem scanning Viessmann API:Unable to authenticate: No valid access token and no refresh token.
I’m new in this round and have the same issue.
But maybe I can help a little bit to find the root cause.
As mentioned I have the same issue in my configuration, but when I’m deleting the my Heating-System out of the VICare App, the openhab Bridge will change directly into “online”.
Maybe you can check this also on your side and hopefully we are than one step further
BTW … after adding the system in the VICare app again and restarting the raspi, the ViCare bridge was shifting back to state “unkown”
