Viessmann Binding [5.0.0.0;6.0.0.0)
Hi @sven1234, I’ve checked your log. All data from Viessmann is correct.
I think there’s a bug in version 5.1.3. I fixed many issues in version 5.2.M2, but it hasn’t been released yet.
However, you can install this version (5.2.0.202602211614) from the Add-ons Marketplace or download it here: https://github.com/rogrun/openhab-addons/releases/download/Release-Viessmann-Binding-5.2.0.202602211614/org.openhab.binding.viessmann-5.2.0.202602211614.jar
Then place it in your addons folder. Please remove the old binding first.
Well, I’m using 5.1.3 Release Build as well and the Viessmann binding which is shipped with the release version. works flawless here.
Sometimes a uninstall/reinstall of the binding may help (you don’t need to remove any Things or Items, but maybe restart openHAB before reinstalling the binding)
I did so, but it did not help. Removing the distro binding and installing the “beta” binding from the marketplace worked.
Hi Ronny!
Thank you sooo much for this binding! :slightly_smiling_face:
Unfortunately I got these two errors every 1-2 minutes with my Vitocal 222S:
2026-03-16 20:56:15.031 [WARN ] [smann.internal.handler.DeviceHandler] - Unknown unit. Could not parse unit: seconds of Feature: heating.device.mainECU - Please create an issue on GitHub with this anonymized detailed JSON:
  "apiVersion" : 1,
  "isEnabled" : true,
  "isReady" : true,
  "gatewayId" : "{{gatewaySerial}}",
  "feature" : "heating.device.mainECU",
  "uri" : "https://api.viessmann-climatesolutions.com/iot/v2/features/installations/{{installationId}}/gateways/{{gatewaySerial}}/devices/0/features/heating.device.mainECU",
  "deviceId" : "0",
  "timestamp" : "2026-03-16T19:53:57.530Z",
  "properties" : {
    "runtime" : {
      "type" : "number",
      "value" : 113018255,
      "unit" : "seconds"
  "commands" : { }
2026-03-16 20:56:15.102 [WARN ] [smann.internal.handler.DeviceHandler] - Unknown unit. Could not parse unit: seconds of Feature: heating.heatingRod.runtime - Please create an issue on GitHub with this anonymized detailed JSON:
  "apiVersion" : 1,
  "isEnabled" : true,
  "isReady" : true,
  "feature" : "heating.heatingRod.runtime",
  "uri" : "https://api.viessmann-climatesolutions.com/iot/v2/features/installations/{{installationId}}/gateways/{{gatewaySerial}}/devices/0/features/heating.heatingRod.runtime",
  "deviceId" : "0",
  "timestamp" : "2026-03-16T04:48:37.748Z",
  "properties" : {
    "levelOne" : {
      "type" : "number",
      "value" : 8577,
      "unit" : "seconds"
    "levelTwo" : {
      "type" : "number",
      "value" : 9742,
      "unit" : "seconds"
  "commands" : { }
Do you experienced this ever on your side? Is there anything I can do? Aside from that, the binding and everything worked “right out of the box”.
My actual system is OH 5.1.3 in a fresh openHABian v1.12.0b installation with your latest binding above.
As I am not familiar with filing an issue on GitHub, I ask here. Sorry for that… :face_without_mouth:
Please let me know if you need further infos or testing.
Thanks! :oncoming_fist:
Hi @BGrosse
That’s not a problem, it’s fine here too.
No, you can’t do anything here. I need to add the unit “seconds” to the binding.
I will implement it in the next few days.
@BGrosse
I published a new release here.
Please remove the old binding and re-install form marketplace.
Hi Ronny!
This one works great - thank you for that :+1:
Another thing I noticed is, that the “holiday active” jumps from OFF to ON and immediatley back to OFF again every once in a while:
2026-03-21 19:01:51.276 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Viessmann_Vitocal_222S_Operating_program__holiday_active' changed from OFF to ON (source: org.openhab.core.thing$viessmann:device:8fae8d4ce9:7637415009038218:8fae8d4ce9:heating-operating-programs-holiday#active)
2026-03-21 19:01:51.284 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Viessmann_Vitocal_222S_Operating_program__holiday_active' changed from ON to OFF (source: org.openhab.core.thing$viessmann:device:8fae8d4ce9:7637415009038218:8fae8d4ce9:heating-operating-programs-holiday#active)
2026-03-21 19:03:18.797 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Viessmann_Vitocal_222S_Operating_program__holiday_active' changed from OFF to ON (source: org.openhab.core.thing$viessmann:device:8fae8d4ce9:7637415009038218:8fae8d4ce9:heating-operating-programs-holiday#active)
2026-03-21 19:03:18.819 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Viessmann_Vitocal_222S_Operating_program__holiday_active' changed from ON to OFF (source: org.openhab.core.thing$viessmann:device:8fae8d4ce9:7637415009038218:8fae8d4ce9:heating-operating-programs-holiday#active)
Did you experienced this also? I never saw this on the older ViCare Binding on OH 4.x - it seems to be new with your binding. :roll_eyes:
Does this come from the Viessmann API or is it a glitch effect in the binding?
Please let me know if you need more specific information or testing.
Thanks :oncoming_fist:
I’m sorry, but I’m not able to get it working. I removed the binding and reinstalled it from the marketplace. But I don’t get more than the account thing (via file) and the gateway. Is there a step by step guide or a kind of a tutorial available?
TIA
Reinhold
Assuming you have already entered the Infos for the account thing, like username etc.: If you check the Inbox in the Things section, there is not Device 0 listed? And you cannot add any device via the “+” button?
Account and Gateway things are OK. Devices remain in “INITIALIZING” state and in the log there is an entry “ViError: User does not have access to given feature.” My Viessmann developer account has the basic plan. There is a community thread in the Iobroker forum which mentiones that a token is needed. But the token which can be generated on the Viessman site lives just 1 hour and the binding does not accept a token. On the other hand, when I read this thread her I have the impression that some guys got it working, so I’m wondering what I’m doing wrong.
@Konfusius Could you please set the logging level for the Viessmann Binding to “TRACE” and send me the complete log via private message? I’ll look into the problem.
Does anyone get these warning messages in openHAB 5.1.4?
Message
Failed to normalize configuration for new thing during update 'viessmann:device:xyz:0': {thing/channel=Type description viessmann:duration-minute for viessmann:device:xyz:0:heating-configuration-temperature-outside-damping-factor not found, although we checked the presence before.}
@sven1234 which version are you running?
This should be fixed in the last marketplace release.
As of yesterday everything works fine without any activity or setup change on my side. So I assume the problem was at Viessmann. Anyways. it works and I get data via the API. @ Ronny: thanks for your kind support. I appreciated it.
Hi @rogrun
excellent works! thanks for your effort!!
I am wondering if it would be possible to add a couple of channels that are missing (and were available in the previous vicare binding):
  • type volume heating.gas.consumption.*
  • type energy *.power.consumption.*
  • type boolean heating.dhw.operating.modes .comfort / .eco / .active (=only .active is present)
thanks for your support…
