It’s driving me crazy. Any help is greatly appreciated. I sendCommand a value to a virtual Item and try to react to it with a rule. Which worked great in OH1 but now in OH2 the event triggers, but the state is the one from before. It’s a bit complex. I try to reduce it to the minimum here.
I’m sending Licht_Aus.sendCommand(ON) and it should switch off the hues in a room. It receives a 0 (STATE_OFF) as event, but the read state is not 0. It’s the value from before (2 in this case).
Events lock great, but the If check for (.state) is getting an old value. It looks like the event is triggered, just before the value (state) is saved.
2017-02-14 14:25:09.530 [ItemStateChangedEvent ] - Licht_Aus changed from OFF to ON
2017-02-14 14:25:09.532 [ItemCommandEvent ] - Item 'Licht_Szene_Flur' received command 0
2017-02-14 14:25:09.596 [ItemStateChangedEvent ] - Licht_Szene_Flur changed from 2 to 0
2017-02-14 14:25:09.649 [ItemCommandEvent ] - Item 'Hue_State_Flur' received command 0
2017-02-14 14:25:09.884 [ItemStateChangedEvent ] - Licht_Aus changed from ON to OFF
2017-02-14 14:25:09.919 [ItemStateChangedEvent ] - Hue_State_Flur changed from 2 to 0
2017-02-14 14:25:09.922 [ItemCommandEvent ] - Item 'gHueDimFlur' received command 100
This is my setup.
Switch Licht_Aus //Funktion alle Lichter aus
Number Licht_Szene_Flur //für Schnellauswahl (Szenen)
Number Hue_State_Flur //Funktion
Dimmer Hue1_Dim_Flur (gHueDimFlur) {channel="hue:0220:00178840611f:5:brightness"}
Dimmer Hue2_Dim_Flur (gHueDimFlur) {channel="hue:0220:00178840611f:6:brightness"}
Dimmer Hue3_Dim_Flur (gHueDimFlur) {channel="hue:0220:00178840611f:7:brightness"}
val Integer STATE_OFF = 0
val Integer STATE_COZY = 1
val Integer STATE_NORMAL = 2
val Integer STATE_BRIGHT = 3 //also used as STATE_NIGHT
val Integer STATE_UNKNOWN = 9
rule "Licht_Aus Function"
Item Licht_Aus received command ON
Licht_Szene_Flur.sendCommand(STATE_OFF)
Licht_Aus.postUpdate(OFF)
rule "Licht_Szene_Flur Event"
Item Licht_Szene_Flur received command
if(Licht_Szene_Flur.state == STATE_OFF){
Hue_State_Flur.sendCommand(STATE_OFF)
} else if(Licht_Szene_Flur.state == STATE_COZY){
Hue_State_Flur.sendCommand(STATE_COZY)
} else if(Licht_Szene_Flur.state == STATE_NORMAL){
Hue_State_Flur.sendCommand(STATE_NORMAL)
} else if(Licht_Szene_Flur.state == STATE_BRIGHT){//nachtlicht
Hue_State_Flur.sendCommand(STATE_BRIGHT)
rule "Hue_State_Flur Function"
Item Hue_State_Flur received command
if(Hue_State_Flur.state == STATE_OFF){
gHueDimFlur.sendCommand(OFF)
} else if(Hue_State_Flur.state == STATE_COZY){
gHueDimFlur.sendCommand(50)
Licht_Temp_Flur.sendCommand(TEMP_WARM)
} else if(Hue_State_Flur.state == STATE_NORMAL){
gHueDimFlur.sendCommand(100)
Licht_Temp_Flur.sendCommand(TEMP_NORMAL)
} else if(Hue_State_Flur.state == STATE_BRIGHT){//nachtlicht
gHueDimFlur.sendCommand(1)
