Hi there,
This is my first try with OH rules. For testing purpose, I created a new instance of an OH docker container, running V2.4.0-snapshot-debian, build 1378.
In OH I created four switches SW1 to SW4 as “virtual items” without any connected channels.
Switch SW1 "SW1" <motion>
Switch SW2 "SW2" <motion>
Switch SW3 "SW3" <motion>
Switch SW4 "SW4" <motion>
For having access to the items (PaperUI seems not to show items without channels in the control-section?) there is a simple sitemap:
sitemap myhometest label="Test" {
Frame label="Sitemap1" {
Switch item=SW1 icon="receiver"
Switch item=SW2 icon="screen"
Frame label="Sitemap2" {
Switch item=SW3 icon="cinema"
Switch item=SW4 icon="cinema"
Via rules I simply try to switch SW3 when SW1 changes from off to on.
rule "test"
Item SW1 changed from OFF to ON
logWarn("Testlog", "Rule fired")
SW3.sendCommand(ON)
But nothing happens when SW1 is klicked in the sitemap. Logs say, that the rules were loaded correctly. What seems strange is, that there are absolutely no entries in the events.log. Which might explain why the rule is not working…but why does klicking on the switch does not trigger events? Or am I missing here something else?
2018-10-03 12:55:04.034 [INFO ] [.internal.GenericScriptEngineFactory] - Activated scripting support for ECMAScript
2018-10-03 12:55:05.489 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2018-10-03 12:55:05.534 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-10-03 12:55:06.267 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://172.17.0.4:6444
2018-10-03 12:55:06.269 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://172.17.0.4:6443
2018-10-03 12:55:11.497 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'myitemstest.items'
2018-10-03 12:55:15.266 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'myrulestest.rules'
2018-10-03 12:55:15.487 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-10-03 12:55:15.847 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'myhometest.sitemap'
2018-10-03 12:55:16.856 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-10-03 12:55:17.025 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-10-03 12:55:17.102 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
Thanks for help and greets
Alex
