On my garagedoor i have a reed switch that’s connected to a VMB7IN. When the garagedoor opens i activate a virtual relais.
In the Velbus app on the computer this is working. In Openhab i don’t see the action when the door op open.
This is my config:
in default.sitemap:
Switch item=OpenToe icon=“opentoe” label=“Poort Open/Toe”
in default.items:
Switch OpenToe “Poort Open/Toe” (garage) {channel=“velbus:vmb4ryno:089ad7e2:F1:CH5”}
The virtual relais is on F1 channel 5 in Velbus config application.
in the app on the smartphone (android) i don’t see this action (look likes the door is always closed).
What do i do wrong or what’s missing?
Herman
2019-07-28 14:21:44.408 [vent.ChannelTriggeredEvent] - velbus:vmb2pbn:089ad7e2:17:CH1 triggered PRESSED *** Button door pressed open ***
2019-07-28 14:21:44.441 [vent.ItemStateChangedEvent] - Poort changed from OFF to ON
2019-07-28 14:21:44.513 [vent.ChannelTriggeredEvent] - velbus:vmb2pbn:089ad7e2:17:CH1 triggered RELEASED
2019-07-28 14:21:44.547 [vent.ItemStateChangedEvent] - Poort changed from ON to OFF
2019-07-28 14:21:46.690 [vent.ChannelTriggeredEvent] - velbus:vmb7in:089ad7e2:03:CH6 triggered PRESSED *** VMB7IN Garage ****
2019-07-28 14:21:47.516 [vent.ChannelTriggeredEvent] - velbus:vmb7in:089ad7e2:03:CH6 triggered LONG_PRESSED
2019-07-28 14:21:51.720 [vent.ChannelTriggeredEvent] - velbus:vmb2pbn:089ad7e2:17:CH1 triggered PRESSED *** Button door pressed close ***
2019-07-28 14:21:51.755 [vent.ItemStateChangedEvent] - Poort changed from OFF to ON
(The VMB7In is configured a a long press (1sec) to eliminate switch noise.)
i see no action for the relays.
included also the VelbusLink config (in Dutch).
i use a virtual relay because i will only see the status of the relay in de app. (so i can see when the garagedoor is open or not).
