I have been searching the web for 3 days and I don’t get it. I’m using one virtual slider to control a group of two lights and it works perfectly in one way. The problem is when I change HUE lights with other application or Philips wall switch the slider is not updating to same percent% of brightness as is actual.
If I add two more sliders on SiteMap the two sliders connected directly to items are updating automaticly. Also in log file the level of brightness is logged for the two bulbs.
Below is my configuration. And if anyone has an Idea how to update the Light_Dimmer based on Light_1_Dimmer brightness please advise. I guess it should be some kind of rule but I can’t get the slider to move with anything I tried.
rule "Dimmer"
Item Light_Dimmer received command
var value = Light_Dimmer.state as PercentType
sendCommand(Light_1_Dimmer,value)
sendCommand(Light_2_Dimmer,value)
I have this problem too. Groups are going to UNDEF instead of the value they should have. This also happens with the NOT dimmable hue lights and a switch item.
You don’t need a rule for sending command to the dimmers, all members of Light_Dimmer should received the command when the Light_Dimmer item changes regardless. At least it does with my z-wave lights…
What happens if you try without the rule? Does the Light_Dimmer item get updated with the correct dimmer value?
Here is my full config with switch, dimm, color and color temperature if it helps anyone.
The only issue is now when one of the bulbs is set at different brightness/colorTemp, the dimer and/or ColorTemp sliders are going to 0%. But I guess it is logical.
