I have five of these and something is not working properly. They’ve been included on my z-wave network for days.
I remove the cover, which I assume is “alarm_burglar” and I get:
2018-01-18 20:43:17.828 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-01-18 20:43:17.841 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Application Command Request (ALIVE:DONE)
2018-01-18 20:43:17.844 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: Starting initialisation from DONE
2018-01-18 20:43:17.848 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Incoming command class ALARM
2018-01-18 20:43:17.854 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 28: Received ALARM command V2
2018-01-18 20:43:17.857 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 28: Process NOTIFICATION_REPORT V2
2018-01-18 20:43:17.860 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 28: NOTIFICATION report - 7 = 255, event=3, status=255
2018-01-18 20:43:17.862 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 28: Alarm Type = BURGLAR (7)
2018-01-18 20:43:17.867 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2018-01-18 20:43:17.869 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2018-01-18 20:43:17.876 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Updating channel state zwave:device:cab10335:node28:alarm_burglar to ON [OnOffType]
2018-01-18 20:43:17.884 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=28, callback=255, payload=1C 02 84 08
i put the magnet next to the device, which I assume is “sensor_door” I get:
2018-01-18 20:44:12.721 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Application Command Request (ALIVE:DONE)
2018-01-18 20:44:12.723 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: Starting initialisation from DONE
2018-01-18 20:44:12.728 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Incoming command class BASIC
2018-01-18 20:44:12.730 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 28: Received Basic Request
2018-01-18 20:44:12.732 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 28: Basic Set sent to the controller will be processed as Basic Report
2018-01-18 20:44:12.734 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 28: Basic report, value = 0x00
2018-01-18 20:44:12.738 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-01-18 20:44:12.740 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 0
2018-01-18 20:44:12.743 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=28, callback=1, payload=1C 02 84 08
2018-01-18 20:44:12.773 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Application Command Request (ALIVE:DONE)
2018-01-18 20:44:12.775 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: Starting initialisation from DONE
2018-01-18 20:44:12.779 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Incoming command class ALARM
2018-01-18 20:44:12.781 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 28: Received ALARM command V2
2018-01-18 20:44:12.783 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 28: Process NOTIFICATION_REPORT V2
2018-01-18 20:44:12.784 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 28: NOTIFICATION report - 7 = 0, event=2, status=255
2018-01-18 20:44:12.786 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 28: Alarm Type = BURGLAR (7)
2018-01-18 20:44:12.790 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2018-01-18 20:44:12.791 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2018-01-18 20:44:12.797 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Updating channel state zwave:device:cab10335:node28:alarm_burglar to ON [OnOffType]
2018-01-18 20:44:12.804 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=28, callback=1, payload=1C 02 84 08
The XML file is:
<node>
<deviceClass>
<basicDeviceClass>ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>BINARY_SENSOR</genericDeviceClass>
<specificDeviceClass>ROUTING_SENSOR_BINARY</specificDeviceClass>
</deviceClass>
<homeId>0xf67d3453</homeId>
<nodeId>28</nodeId>
<version>4</version>
<manufacturer>0x109</manufacturer>
<deviceId>0x102</deviceId>
<deviceType>0x2001</deviceType>
<listening>false</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<nodeInformationFrame>
<commandClass>ALARM</commandClass>
<commandClass>ASSOCIATION</commandClass>
<commandClass>BATTERY</commandClass>
<commandClass>MANUFACTURER_SPECIFIC</commandClass>
<commandClass>SENSOR_BINARY</commandClass>
<commandClass>VERSION</commandClass>
<commandClass>WAKE_UP</commandClass>
</nodeInformationFrame>
<supportedCommandClasses>
<entry>
<associationCommandClass>
<version>1</version>
<instances>1</instances>
<versionSupported>1</versionSupported>
<maxGroups>1</maxGroups>
</associationCommandClass>
</entry>
<entry>
<alarmCommandClass>
<version>2</version>
<versionSupported>2</versionSupported>
<alarms>
<entry>
<alarmType>BURGLAR</alarmType>
<alarmState>
<reportedEvents/>
<outer-class reference="../../../.."/>
</alarmState>
</entry>
</alarms>
<v1Supported>true</v1Supported>
<isGetSupported>true</isGetSupported>
</alarmCommandClass>
</entry>
<entry>
<WakeUpCommandClass>
<targetNodeId>1</targetNodeId>
<interval>3600</interval>
<minInterval>600</minInterval>
<maxInterval>604800</maxInterval>
<defaultInterval>3600</defaultInterval>
<intervalStep>200</intervalStep>
<lastWakeup>2018-01-19 01:31:47.895 UTC</lastWakeup>
</WakeUpCommandClass>
</entry>
<entry>
<versionCommandClass>
<libraryType>LIB_SLAVE_ROUTING</libraryType>
<protocolVersion>3.52</protocolVersion>
<applicationVersion>4.84</applicationVersion>
</versionCommandClass>
</entry>
<entry>
<binarySensorCommandClass>
<types/>
</binarySensorCommandClass>
</entry>
<entry>
<manufacturerSpecificCommandClass>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>265</deviceManufacturer>
<deviceType>8193</deviceType>
<deviceId>258</deviceId>
</manufacturerSpecificCommandClass>
</entry>
<entry>
<commandClass>NO_OPERATION</commandClass>
<noOperationCommandClass>
</noOperationCommandClass>
</entry>
<entry>
<batteryCommandClass>
<batteryLevel>100</batteryLevel>
<batteryLow>false</batteryLow>
</batteryCommandClass>
</entry>
<entry>
<commandClass>BASIC</commandClass>
<basicCommandClass>
</basicCommandClass>
</entry>
</supportedCommandClasses>
<securedCommandClasses/>
<associationGroups>
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<associations>
<associationMember>
<node>1</node>
<endpoint>0</endpoint>
</associationMember>
</associations>
</associationGroup>
</entry>
</associationGroups>
<nodeNeighbors>
<int>1</int>
<int>2</int>
<int>3</int>
<int>5</int>
<int>6</int>
<int>9</int>
<int>11</int>
<int>12</int>
<int>13</int>
<int>14</int>
<int>19</int>
<int>20</int>
<int>26</int>
<int>27</int>
</nodeNeighbors>
<lastSent>2018-01-19 01:31:48.247 UTC</lastSent>
<lastReceived>2018-01-19 01:31:48.371 UTC</lastReceived>
</node>
My Items file has:
Contact FF_Foyer_Entry_Sensor "Foyer Entry [%s]" <door> (FF_Foyer, Door) {channel="zwave:device:cab10335:node28:sensor_door"}
Number FF_Foyer_Entry_Battery "Foyer Entry Battery [%d %%]" <energy> (FF_Foyer, Status) {channel="zwave:device:cab10335:node28:battery-level"}
Contact FF_Foyer_Entry_Tamper "Foyer Tamper [%s]" <siren> (FF_Foyer, Status) {channel="zwave:device:cab10335:node28:alarm_burglar"}
Any thoughts? I’m running openHAB 2.3.0 Build #1188. I’ve removed and re-added the things using habmin and PaperUI a few times. Not luck
