Hi Sifu
I set up Openhab2 recently via apt-get on a Rapberry Pi 3 with Z-wave.me daughter card. It works all fine except for my door sensors from Vision (ZD2102).
The Thing is showing up just fine with the correct channels but the door sensor won’t report.
Neither event.log nor openhab.log report anything towards the door sensor (battery-level 83% just works fine).
As this hangs behind a z-wave daughter card which has their own crappy UI I tried it via z-way-server as well. Apparantely in Z-way this sensor works just nice even for the door sensor. Therefore I do suspect the xml file is not correct but I don’t know where to start.
Perhaps I should mention my ZD2102 is a little older and should be V1 (rather than the zwave+ version they are selling now).
Let’s run this down on my node 11 (even yet I have more which behave the same).
Item:
Contact Bedroom_Door "Bedoom door" { zwave="11:command=sensor_door" }
Number Bedroom_Door_Battery "Bedroom door battery" { zwave="11:command=battery_level" }
Node11.xml
`<ZWaveDevice schemaVersion="2"><descriptorVersion>1</descriptorVersion><deviceData><manufacturerId value="0109"/><productType value="2001"/><productId value="0102"/><libType value="06"/><protoVersion value="03"/><protoSubVersion value="34"/><appVersion value="04"/><appSubVersion value="54"/><basicClass value="04"/><genericClass value="20"/><specificClass value="01"/><optional value="true"/><listening value="false"/><routing value="true"/><beamSensor>0</beamSensor></deviceData><deviceDescription><description><lang xml:lang="en"/></description><wakeupNote><lang xml:lang="en"/></wakeupNote><inclusionNote><lang xml:lang="en"/></inclusionNote><productName/><brandName/><productVersion>4.84</productVersion></deviceDescription><commandClasses><commandClass id="0020" version="1" supported="true" controlled="false" secure="false" inNIF="false"/><commandClass id="0030" version="1" supported="true" controlled="false" secure="false" inNIF="true"/><commandClass id="0071" version="2" supported="true" controlled="false" secure="false" inNIF="true"/><commandClass id="0072" version="1" supported="true" controlled="false" secure="false" inNIF="true"/><commandClass id="0080" version="1" supported="true" controlled="false" secure="false" inNIF="true"/><commandClass id="0084" version="2" supported="true" controlled="false" secure="false" inNIF="true"/><commandClass id="0085" version="1" supported="true" controlled="false" secure="false" inNIF="true"/><commandClass id="0086" version="1" supported="true" controlled="false" secure="false" inNIF="true"/></commandClasses><assocGroups><assocGroup number="1" maxNodes="5"><description><lang xml:lang="en">Group 1</lang></description></assocGroup></assocGroups></ZWaveDevice>`
I do have several other nodes and rules running without any issues. Even another door sensor from Vision which is probably the newer zwave+ version (no idea how to differentiate on the hardware) Therefore I trust Openhab2 itself and network stability and similar can be excluded as source of this issue.
Anyone can point me to the solution? I spent the whole afternoon on try and errror as well styudiyng/searching but nothing seem to help.
