I try to find the correct syntax for my things and item-files to be able to handle the control of my Sugarvalley Pool-Equipment via Modbus with a ESP32 with Tastmota + NeoPool-Addon on it!
Data reception is working, i can show ph and redox darta, relay and filter status etc…
But i have no idea how to write via modbus new values or switch a state to turn on a pump or a relay…
this is f.ex. a line of the things-file:
Type number : pHWert [stateTopic=tele/neopool_D7CDB8/SENSOR, transformationPattern=JSONPATH:$.NeoPool.pH.Data]
Type number : pHMax [stateTopic=tele/neopool_D7CDB8/SENSOR, transformationPattern=JSONPATH:$.NeoPool.pH.Max]
the pHMax value is possible to change… here the items-line:
Number pHMax "pH-Max [%s]" (gPool) { channel="mqtt:topic:neopool_D7CDB8:pHMax"}
But i have no idea how to manage it. Nobody here who has a running config for this mqtt, Tasmota NeoPool etc. ?
I also have the problem to get the data from a DS18B20 Temperature Sensor connected and configured correct for GPIO5 on the ESP…
Hope to find here some ideas…
