I use VSC (1.41.1) with installed openHAB extension. Sadly syntax highlightening is not working.
I set in ‘C:>users>…myuser…>AppData>Roaming>Code>User>settings.json’ this code:
{ “openhab.host”:“192.168.178.45”,
"openhab.port": 8080, "workbench.iconTheme": "openhab", "openhab.remoteLspPort": 5007, "openhab.remoteLspEnabled": true, "openhab.useRestApi": true
I bind the Samba-Folder to VSC and have access.
But still no syntax highlightening, and also no access while pressing the ‘openhab-icon’ in the left menu bar of VSC.
Any ideas, whar I’m migth be wrong?
