This is usually displayed, when items and things are loaded as far as i know.
But i have no explanation for a perfectly fine things view and items that are not getting loaded.
This should be the same extension part.
I found the reason, problem solved by workaround
I had three *.items files in my item folder.
myname.items
fritzbox.items
weather.items (with all OpenWeatherMap items)
I deleted the weather.items file (because error occurs after adding this file and some changes I made with the weather bindings), ==> it worked.
I put it back, changed the name to wetter.items, same error again.
I changed the name to OWM.items, it worked again
So, reproducible:
- as soon as the items file name is weather.items or wetter.items, the item list remains empty,
- file name changed => it works
Strange
Could you please file an issue on github for this.
Definitively something we should check through a debugging session.
even more strange now.
Looked at it again tonight, unfortunately the items are again not shown
changed files again back and force, not shown
Now I deleted all my EchoDot items in my myname.items file, it works again, even with a weather.items file in the same folder.
Next steps: I put all Echodot items (I have two of them and all channels of amazonechocontrol are listed for each of this devices) in a new file echodot.items => works
(Always restarting VSC in between)
Putting back the EchoDot items in the myname.items, items are shown in the sidebar, but (!) without the EchoDot items listed.
Playing around a while with it I get the idea, that something runs into a timeout reading the amazonechocontrol channels.
Happy to help with a github issues, but I will see what the systems does tomorrow before I open up that issues (never did that before).
no more issues with Openhab Extension 0.5.1
Thanks for the update, all items are shown (including all EchoDot and OWM items )
