marcusf
(Marcus)
September 24, 2020, 1:01pm
#1
I installed the Volvo on call binding and setup the bridge. I tried to do it in a things-file (as proposed on the binding documentation page . I also tried to do it through PaperUI, but with the same result.
I receive the following error message on the Bridge:
Status: OFFLINE - COMMUNICATION_ERROR java.io.IOException: java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@1f412ef::DecryptedEndPoint@1bad591{vocapi.wirelesscar.net/170.102.194.8:443 <->/172.18.0.2:46754,OPEN,fill=-,flush=-,to=12/0}
Any suggestions? 172.18.0.2 is the OpenHAB docker instance’s IP. Do I need to open up ports in the firewall?
glhopital
(Gaël L'hopital)
September 24, 2020, 3:46pm
#2
There’s a bug filed for this in github
cgeo
(Christos)
October 7, 2020, 9:12pm
#3
Good that I have seen this, it saved me some time troubleshooting
SergioV
(Sergio Verardo)
October 16, 2020, 1:34pm
#4
Can somebody provide a link to that mentioned solution in github? I can’t find it. Thx
cgeo
(Christos)
October 16, 2020, 6:59pm
#5
It’s pretty visible when you google it. The workaround is at the end of the thread
opened 09:36AM - 23 Sep 20 UTC
closed 06:59PM - 03 Oct 20 UTC
I upgraded to openhab 2.5.9 on Raspberry 4B using openhabian.
The 2.5.9 volvooncall binding produces following error:
VolvoOnCall API
This bridge represents the gateway...
bug
help wanted
