I want to bind the VR300 to my openhab, but I doesn’t use the webUI.
I can’t find any neato.cfg file example. Do somebody knows how it should look like?
My configuration:
addons.cfg
binding = modbus,knx,amazondashbutton,homematic,neato
neato.cfg (I think this is wrong)
vendor=Vorwerk
password=mypasswprd
email=myemail@test.de
neato.things
neato:vacuumcleaner:fanndamm [ serial="vacuumcleaner-serial", secret="secret-string"]
neato.items
Group GNeato
Number FannDammBattery "Battery level [%.0f %%]" <battery> (GNeato) { channel = "neato:vacuumcleaner:fanndamm:battery-level" }
String FannDammState "Status [MAP(neato.map):%s]" (GNeato) { channel = "neato:vacuumcleaner:fanndamm:state" }
String FannDammError "Error [%s]" (GNeato) { channel = "neato:vacuumcleaner:fanndamm:error" }
String FannDammAction "Action [MAP(neato.map):%s]" (GNeato) { channel = "neato:vacuumcleaner:fanndamm:action" }
Switch FannDammDockHasBeenSeen "Seen dock [%s]" <present> (GNeato) { channel = "neato:vacuumcleaner:fanndamm:dock-has-been-seen" }
Switch FannDammIsDocked "In dock [MAP(neato.map):%s]" <present> (GNeato) { channel = "neato:vacuumcleaner:fanndamm:is-docked" }
Switch FannDammIsScheduled "Scheduled [%s]" (GNeato) { channel = "neato:vacuumcleaner:fanndamm:is-scheduled" }
Switch FannDammIsCharging "Is Charging [%s]" <heating> (GNeato) { channel = "neato:vacuumcleaner:fanndamm:is-charging" }
String FannDammCategory "Cleaning Category [MAP(neato.map):%s]" (GNeato) { channel = "neato:vacuumcleaner:fanndamm:cleaning-category" }
String FannDammMode "Cleaning Mode [MAP(neato.map):%s]" (GNeato) { channel = "neato:vacuumcleaner:fanndamm:cleaning-mode" }
String FannDammModifier "Cleaning Modifier [MAP(neato.map):%s]" (GNeato) { channel = "neato:vacuumcleaner:fanndamm:cleaning-modifier" }
Number FannDammSpotWidth "SpotWidth [%.0f]" <niveau> (GNeato) { channel = "neato:vacuumcleaner:fanndamm:cleaning-spotwidth" }
Number FannDammSpotHeight "SpotHeight [%.0f]" <niveau> (GNeato) { channel = "neato:vacuumcleaner:fanndamm:cleaning-spotheight" }
String FannDammCommand "Send Command" { channel = "neato:vacuumcleaner:fanndamm:command" }
neato.map
ui_alert_busy_charging=beschäftigt mit Aufladen
ui_error_navigation_noprogress=Navigationsproblem
ui_alert_recovering_location=Standort wiederherstellen
ui_error_brush_overload=Bürsten überlastet
ui_error_dust_bin_full=Staubbehälter voll
ui_error_dust_bin_emptied=Staubbehälter entleert
ui_error_brush_stuck=verstopfte Bürsten
// Curent state of the vacuum cleaner
INVALID=Chillen
IDLE=Idle
BUSY=Busy
PAUSED=Pause
ERROR=Error
ON=Ja
OFF=Nein
// Current action of the vacuum cleaner
HOUSE_CLEANING=Haus Reinigung
SPOT_CLEANING=Spot Reinigung
MANUAL_CLEANING=Manuelle Reinigung
DOCKING=Angedockt
USER\ MENU\ ACTIVE=Aktives Benutzermenü
SUSPENDED\ CLEANING=Reinigung abgebrochen
UPDATING=Aktualisieren
COPYING\ LOGS=Logs kopieren
RECOVERING_LOCATION=zum Ausgangspunkt zurückkehren
IEC\ TEST=Iec Test
// Current or last cleaning mode
CLEAN-MODE-ECO=Eco
CLEAN-MODE-TURBO=Turbo
// Modifier of current or last cleaning
CLEAN-MODIFIER-NORMAL=Normal
CLEAN-MODIFIER-DOUBLE=Doppelt
// Current or Last category of the cleaning
CLEAN-CATEGORY-HOUSE=Haus Reinigung
CLEAN-CATEGORY-SPOT=Spot Reinigung
CLEAN-CATEGORY-MANUAL=Manuelle Reinigung
CLEAN-NAVIGATIONMODE-NORMAL=Normal
CLEAN-NAVIGATIONMODE-EXTRACARE=Extra Care
NULL=NULL
-=NA
=NA
UNRECOGNIZED=unerkannt
NORMAL=Normal
TURBO=Turbo
HOUSE=House Reinigung
ECO=Eco
neato.sitemap
sitemap licht label="VR300" icon="pump"
Frame label="Neato BotVac Connected"
Switch item=FannDammCommand mappings=[clean="Clean",stop="Stop",pause="Pause",resume="Resume", dock="Send to dock"]
Text item=FannDammBattery label="Battery level"
Text item=FannDammState
Text item=FannDammError label="Error Message" icon="siren"
Text item=FannDammAction label="Activity"
Text item=FannDammIsDocked label="In dock"
Group label="Mer information" item=GNeato
