Hello
i did successfully install the Extension and configured it to work with my setup, token authorization and basic ui.
i did manually open the conf folder and saved it as a workspace - is this the intended way?
I am wondering because i do not have a side bar like there: openhab-vscode/README.md at main · openhab/openhab-vscode · GitHub
where you can browse the things or insert the sitemap configuration files.
It’d be great if you could point me in the right direction.
I am using OH 3 on Ubuntu in a VirtualBox (own IP etc.) and mount the drives via smb.
Thank you!
regards
Jonas
