I installed the OH extension in my VS Code, but when i am typing , the popup shows a few items that match the keystrokes, but not all items, and many methods/functions/properties are not shown.
for example, i have tons of items shown in VS Code leftside pane where Items and Things are listed correctly, like “i_HVAC_read…” but when I’m typing , once I get past “i_HVAC” no items are in the popup, but they are there on the leftside pane, all listed.
Also
very few methods and functions in DSL are shown
for example i typed val tmp = myItem.state.
and no methods or functions were in the popup, in fact there was no popup.
Now i know there is toString and many more.
I use VS Code a lot with python, C etc and no probs with that
apart from installation of the OH extension for VSC, do i need to so/check anything?
Please don’t post more than one thread on the same topic. If you have more to add you can edit your original or add a reply. VS Code Extension not showing options
I think items completion is currently missing somehow.
There were large changes in that extension area at the end of 2018 which affected that and it’s likely possible that this has some side effects.
Same goes for rule methods or to be ab it more precise for autocompletion in rules.
Mistakes happen. Since you’ve a response on this one and not on the other thread I recommend deleting that other thread. Click on the three dots menu at the bottom of the post and select the trash can icon.
