Did you ever get to the bottom of this?
I’ve the same issue - it’s basically check the server path, rather than mapping back to the locally accessible version…
Just a newbie question:
Why are some items names in the item files displayed in white, wheras the majority is displayed in a different color (some sort of blue)?
In my VS it seems that all items with a mixture of lower and capital letters are in cyan color, while items with only lower case letters or only capital letters are in white color.
I raised this questions because i wanted to understand the rationale behind that. If it is simply that. Im fine but i thought there would be more.
Hi Peter, yes.
But thanks to your comment, I’ve found one error!
So I had my Pi mounted as a net drive with a letter. However, that network drive never showed in Visual Studio code - apparently because I ran VS Code by default as Administrator (full explanation here.)
After removing the admin checkmark in the properties, I can find the drive letter and also use it in my VS code workspace. This also cleared the error by the VS Code extension that always popped up when I first opened a file from my Pi.
