AndreasK
(Andreas)
July 21, 2020, 8:43am
#1
When I select a file with an error it should open the file directly in the editor. However I get this error:
I added the openhab folder via a mapped drive. I can save and create new files so it is not a permission problem. However when I click the “create file” button in the error window it will create a file on my C:\ drive (C:\openhab\conf…)
Can someone help me or is this feature currently not working?
Andy
H102
(CM6.5 H102)
July 21, 2020, 1:25pm
#2
I do not use Windows but do remember reading that some have needed to create a different drive e.g. Z drive and use that for OH.
Will post back if I can find the topic.
AndreasK
(Andreas)
July 21, 2020, 1:30pm
#3
thx I’ve already tried that but maybe you just need to map the drive directly to the conf folder or to the openhab folder, one folder above conf?
Duplicate from
Hello there,
the syntax check in VS Code is working fine, but when I try to click on a displayed problem in the “Problems” window, e.g.:
[Problem]
it wants to open the file from the wrong url and I get the following error message:
[CannotReadFile]
I am working on a MS Windows machine and Openhab is installed on a Raspberry Pi.
The problem is the same no matter if I open the folder \\OPENHABIANPI\openHAB-conf or if I am using a network drive.
This is what my settings.json looks like:
This is a known error in LSP which hasn’t been solved so far.
AndreasK
(Andreas)
July 22, 2020, 4:14am
#5
yeah thats exactly the same problem maybe we can close this thread and continue on the other one?
system
(system)
closed
September 1, 2020, 8:14pm
#6
