C:\Windows>ssh jonas@synology -i \192.168.1.20\docker\openhab\id_rsa -p8101
Warning: Identity file \192.168.1.20\docker\openhab\id_rsa not accessible: No such file or directory.
ssh: connect to host synology port 8101: Connection refused
EDIT:
I did your guide again from scratch and i can connect again manually now at least.
If i put this in the terminal:
Where did you get this path from? If using ssh with public key, just copy the private key to the client that connects with the ssh server. Then use the local file to connect
Please be aware that you don’t need a key if using password login, but the whole idea of key files is not to use passwords though the connection.
If creating the key pair without setting a password, you will no longer need to provide a password at all, and that’s no security issue, as long as you keep your private key, ehm… private…
