Late to join the openHAB 3 ( ) changes party but here it is.
You can get version 0.8.0-beta
here: https://dev.azure.com/openhab/vscode-openhab/_build/results?buildId=133&view=results
You will find a link to the build artifact including the vsix file.
There are not that much changes, but i wanted to provide a minor version that reflects the main changes in openHAB 3 at least partly, before adding new functions/improvements.
This included also some updated docs about handling the new (authenticated) rest api.
Added
- Add two more precise activation events, based on standard openHAB files Improve activation events by Confectrician · Pull Request #219 · openhab/openhab-vscode · GitHub
- Prepare beta extension usage Prepare beta extension by Confectrician · Pull Request #218 · openhab/openhab-vscode · GitHub
Changed
- Remove classic ui. Fix Markdown errors. Remove classic ui. Fix Markdown errors. by Confectrician · Pull Request #224 · openhab/openhab-vscode · GitHub
- Remove jest from root repo dependencies. Only needed for the server package Change package name to beta. by Confectrician · Pull Request #226 · openhab/openhab-vscode · GitHub
- Bump acorn from 5.7.3 to 5.7.4 in /serverJS Bump acorn from 5.7.3 to 5.7.4 in /serverJS by dependabot · Pull Request #222 · openhab/openhab-vscode · GitHub
- Update dependencies Update dependencies by Confectrician · Pull Request #220 · openhab/openhab-vscode · GitHub
- Remove Paper UI Remove Paper UI by Confectrician · Pull Request #217 · openhab/openhab-vscode · GitHub
Fixed
- Show icons for rules, scripts, persistance files show icons for rules, scripts, persistance files by CWempe · Pull Request #205 · openhab/openhab-vscode · GitHub
- Fix folder icons fix folder icons by CWempe · Pull Request #207 · openhab/openhab-vscode · GitHub
- Encode username and password to make a valid URI. Encode username and password to make a valid URI. Fixes #213 by gabbe · Pull Request #214 · openhab/openhab-vscode · GitHub
