This thread seems to be a small mystery linked to extension 1.0
Guessing the “fix” would be more to do with LSP and Quantity types.
Seems to be an LSP problem which is another topic than this one.
Topic related:
I can only guess what’s happening and it seems that my guesses were not 100% accurate so far.
So we need to extend the logging, and check what the extension is doing exactly.
If possible you may provide me a settings config, so i can build up your exact settings.
Message or github email adress should be feasable.
Please try the following extension @mstormi and @Felix_Schneider
Download link: openhab-1.0.0-pr-262-10bd8f8.vsix
It will add some more logging to the Developer Tools (because i don’t want to make a messy output. No one reads all of that.)
Can be viewed with the following steps:
Open Developer Tools
Go to Console and apply openhab
filter:
Look for following log message types and expand the config info with the little arrow:
This will show what vscode knows about the “deprecated” setting and i am able to see where the warning is coming from.
The output may be different from this simple example, depending on the way your configuration is set up.
for testing purposes I defined "openhab.username": "test123",
in c:/Users/.../AppData/Roaming/Code/User/settings.json
. The output looks like this:
The values are fine, but i would need some real world examples, when the bug is occurring.
Then we would have to track down which setting is causing the warning to appear.
Do you get an error again when you delete the “workaround” you described above?
Second question:
Extension is reporting deprecated password
parameter too.
Did you add that too for testing or is it the bug?
Hello everybody.
I am far from your knowledge in your discussions but have a simple question. In version 1.0.0, “openhab.connection.host” is mandatory, so what do you do when you have several openHAB
servers? Do I have to change the host name in settings.json when I change server to configure?
Have searched in the Community and in the documentation but not found the answer.
That’s not a simple question at all.
As I understand it this setting defines the server that VSC connects to via a) API (to retrieve things,items etc) and b) LSP (to validate code).
@Confectrician: correct ?
Now I myself have been wondering what’s happening when I open multiple files on different OH servers. As probably most OH users I’m using Samba to share /etc/openhab/rules of the OH box.
But my Windoze VSC box does not know that they happen to be on different network drives i.e. different servers. To VSC it’s just another file with a different name.
So when my LSP server is set to A but the file I edit is on server B, how does the LSP validator in A know about the rest of the file and OH instance ?
Or - same question phrased the other way round - how does VSC know it should query B for LSP ?
Would I need to setup a workspace for this purpose and change the workspace’s openhab.connection.host
connection to B ?
I still keep getting a bunch of Java error messages at times such as that one below.
Validation suddenly stops working then.
Couldn’t pinpoint yet when exactly it’s happening but my guess is this is related.
openHAB vscode extension has been activated
[Error - 13:49:54] Request textDocument/definition failed.
Message: Internal error.
Code: -32603
java.util.concurrent.CompletionException: java.lang.ClassCastException: class org.eclipse.xtext.common.types.access.TypeResource cannot be cast to class org.eclipse.xtext.resource.XtextResource (org.eclipse.xtext.common.types.access.TypeResource is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @16f6caa; org.eclipse.xtext.resource.XtextResource is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @16e41bb)
at java.base/java.util.concurrent.CompletableFuture.encodeThrowable(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.completeThrowable(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$UniAccept.tryFire(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.postComplete(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.completeExceptionally(Unknown Source)
at org.eclipse.xtext.ide.server.concurrent.AbstractRequest.logAndCompleteExceptionally(AbstractRequest.java:73)
at org.eclipse.xtext.ide.server.concurrent.ReadRequest.lambda$doRun$0(ReadRequest.java:69)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.base/java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassCastException: class org.eclipse.xtext.common.types.access.TypeResource cannot be cast to class org.eclipse.xtext.resource.XtextResource (org.eclipse.xtext.common.types.access.TypeResource is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @16f6caa; org.eclipse.xtext.resource.XtextResource is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @16e41bb)
at org.eclipse.xtext.ide.server.WorkspaceManager.doRead(WorkspaceManager.java:436)
at org.eclipse.xtext.ide.server.findReferences.WorkspaceResourceAccess.readOnly(WorkspaceResourceAccess.java:36)
at org.eclipse.xtext.ide.server.symbol.DocumentSymbolService.doRead(DocumentSymbolService.java:332)
at org.eclipse.xtext.ide.server.symbol.DocumentSymbolService.getDefinitions(DocumentSymbolService.java:112)
at org.eclipse.xtext.ide.server.symbol.DocumentSymbolService.getDefinitions(DocumentSymbolService.java:99)
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$definition$24(LanguageServerImpl.java:608)
at org.eclipse.xtext.ide.server.WorkspaceManager.doRead(WorkspaceManager.java:438)
at org.eclipse.xtext.ide.server.LanguageServerImpl.definition(LanguageServerImpl.java:607)
at org.eclipse.xtext.ide.server.LanguageServerImpl.definition(LanguageServerImpl.java:595)
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$definition$23(LanguageServerImpl.java:586)
at org.eclipse.xtext.ide.server.concurrent.ReadRequest.lambda$doRun$0(ReadRequest.java:66)
... 5 more
[Error - 17:26:31] Request textDocument/definition failed.
Code: -32603
... 5 more
I’m definitely not an expert but a long while back I did some playing around with the extension with the primary purpose to figure out if one could offload the LSP work to a separate openHAB instance from the production openHAB. The reason was at that time (perhaps still?) the LSP can cause a significant load on the openHAB instance and for some users it was adding lots of latency while they were editing files.
And that makes some sense when one realizes the LSP does the same thing that happens when loading a .rules file. So if there is a heavy hit to the CPU when loading the .rules file, there should be a heavy hit when editing that file and as you type the syntax is checked by the LSP.
If I recall correctly it worked pretty well for the syntax checking. However, it will only be aware of the Things, Items, and Sitemaps that exist on the openHAB instance the extension is connected to. So if you have two or more instances of openHAB, it’ll only know about the Items and such on the one the extension is connected to for the LSP.
Keep in mind this is all pretty old information. I suspect the extension has changed a bit since then. But I post it here in case it’s informative or useful.
Currently there is only one host setting, which is used for all connections. (API and LSP when activated in our case).
The whole code is currently based on the assumption that there is one “server” which is running openHAB.
For sure it would be possible to add some more host settings, but that would raise the question:
Where do start with something like this and where do we stop?
I would agree that it probably makes sense to differentiate lsp and api host like described by rich.
But how should we deal with multiple openHAB servers?
openHAB itself has its difficulties with multi server setups.
(Take a look at the several discussions here for redundant setups.)
One suggestion:
If you wont to configure different openHAB servers independent from each other workspace settings could be useful.
You can add a .vscode
folder with a settings.json
in each openhab configuration folder and just provide the hostname as setting.
Other settings could be done for all folders in the user settings.
vscode will then use the workspace host setting, because it is higher in the hierarchy and fall back to other configured user settings which would then be available for all servers.
You then would just have to open the config folder you currently want to edit and the correct host would be set.
Hopefully this brings some light in the dark.
Besides this:
I am still happy for any input on the deprecated parameter bug, because i am still not able to reproduce it currently.
Just did that; actually I used “Add Folder to Workspace” then VSC creates a file called workspace.code-workspace in that directory and in there are settings {} where you can insert your (adapted) settings.json.
When you edit settings (Ctrl- , ) that file actually is edited when you select the workspace tab.
@Magnus give it a try and add 2 workspaces or as @Confectrician said two dirs “.vscode” with a settings.json each
I think this is the correct and only solution to @Magnus issue.
That is the reason why VScode does support .vscode
folders in work spaces, I think.
@rlkoshak s use case sounds very special.
Isn’t the reason for an LSP server to have a LSP for a specific work space/project?
So you can have different openHAB LSPs when you manage different openHAB instance (like v2 and v3) at the same time.
So do not think we need support for multiple openHAB servers.
But I admit I have special use cases too sometimes.
The problem way back when I looked into this was that on a RPi, simply editing some .rules files connected to the production server would bring the OH instance to its knees, stopping pretty much all the home automation for a time. If VSCode used a different OH instance for the LSP server then the production system wouldn’t have that huge hit in performance. But it also means that VSCode isn’t aware of the Things and Items and such (unless you duplicate them on this other OH instance).
And I wasn’t advocating for any changes to the VSCode extension to support this. My post was mainly to provide some observations which might be relevant.
Though, for those who are managing more than one OH instance, being able to switch between instances as one moves from one instance to the next would be useful. Again, I’m not personally advocating for that. Since I’ve moved to all UI driven configs I don’t use the VSCode with OH anymore. But there is a small but important community of OH admins on this forum who are maintaining OH instances for others. I imagine such a feature would be appreciated.
I think that should be done automatically in the workspace approach, when the workspace knows different settings through configuration.
Thank you for providing the vs code extension. I use the latest version on linux and have a strange problem - where I’m not sure if it is a problem with the extension.
A file is completely marked red with the message that “The type SchattenprogrammRules is already defined in schattenprogramm.rules.” - but that is the file I’m currently working with - there is no other such file that I’m aware of.
There are also no duplicated rule names in that file.
schattenprogramm.rules.txt (692 Bytes)
Is there a know bug that can cause this or do I miss the obvious and there is a mistake in my rules file after all? What additional information is required to troubleshot this?
See
Don’t select the openhab root folder
Thank you for that hint, now the problem is solved for me with this workaround!
Thank you for the reply. I did not open the root folder, but only the rules folder itself. But as it seems to be related to the folder I open I’ll try with the conf folder - at a first glance it looks ok like this.
same
same what ?
