Great, that there is a VSCode specific thread, so I want to refer to another post of me showing an VS-Code specific problem: Beginners Guide to create an Addon without the Eclipse IDE for openHAB 2.4 and place it in your running openHAB runtime - #11 by Jochen_Bauer
Hate to say - that only works because the openHAB installer created that environment variable for you (I ran into that same thing when I was doing the windows side). The others (openhab_runtime, openhab_addons, openhab_logs) probably wonāt work unless your environment defines those as well.
Thatās why I tried the āoptions.envā approach (makes it independent of openhab installer and options youāve chosen) - which works on windows but doesnāt on linux/osx based on this thread.
Iām going to spin up my linux environment and will see if I can find a solution for this..
EDIT: after reading through that thread - you may be right that it would work on linux/osx. Again - Iāll be testing shortly to find out
It works. ![]()
I run all my OH stuff in containers, except a manually installed instance, without any environment variables set, that I will use for debugging.
But Iām not sure about the behavior in other shells.
Yep - I can confirm that the $openhab... definitely work on linux environments. Iāll be making a change to the tasks.json shortly (I need to update the docs anyway for a markdown error). Hopefully the next version will run correctly for you all.
Hereās the PR if people want to try the new tasks.json (and I also included the code formatter setup)
Hi
Can you explain how you get VS Code to access an openhab instance on a remote linux machine? This would be my preferred setup as I have a spare Raspberry Pi to run as a dev instance and will avoid having to have maven etc on my mac laptop.
Unfortunately it only works on x86 Linux with the current preview version, so youāll have to be patient I guess. ![]()
UPDATE: The new Insider version of July now includes support for Raspberry Pi.
Thanks - is that already part of the official set up Guide for VS Code?
Not yet - still waiting on the merge
Note: this was merged sometime over the weekend..
Dear Community,
I try to fire up the VS Code debug task. Unfortuntely it is not possible find the corresponding task. I followed the VS Code guide here Visual Studio Code | openHAB
Anyway I prepared the tasks- and launch-file in my binding .vscode folder. After hitting ctrl+shift+p and selecting Run task ⦠I cannot pick any openHAB related task to choose from.
Thanks in advance for your replies.
Best regards,
Jochen
It is solved! The problem where the slashes - I wasnāt expecting, that on a windows box unix related paths are necessary.
Dear Community,
these days I am starting to use VS Code more intensely. Maven is able to build my addon but lots of classes and includes are not visible, see
import org.eclipse.jdt.annotation.NonNullByDefault;
import org.eclipse.jdt.annotation.Nullable;
import org.eclipse.smarthome.core.thing.ChannelUID;
import org.eclipse.smarthome.core.thing.Thing;
import org.eclipse.smarthome.core.thing.ThingStatus;
import org.eclipse.smarthome.core.thing.binding.BaseThingHandler;
import org.eclipse.smarthome.core.types.Command;
import org.eclipse.smarthome.core.types.RefreshType;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
What is the most preferred way to add these modules to VS Code.
Best regards,
Jochen
UPDATE: It is solved. After a new start of VS Code the imports were recognized.
The Steps for each Bundle donāt work for me.
Steps to reproduce:
git clone https://github.com/openhab/openhab2-addons.gitcd bundles/org.openhab.binding.astromvn clean install -DskipTests -DskipChecks
I get loads of compile errors like QuantityType cannot be resolved to a type.
It seems that the imports cannot be resolved.
At the beginning there are warnings like:
The POM for org.openhab.core.bom:org.openhab.core.bom.compile:pom:2.5.0-20190717.100901-102 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
Iām not an expert in maven (in the least bit) but Iād clear out the .m2/.p2 directories (usually in your home directory) and try again.
I have the same problem. I followed
https://www.openhab.org/docs/developer/ide/vscode.html
but got stuck on step 10. part 2.
Press CTRL-SHIFT-P ā Tasks: Run Task ā Start openHAB (Debug) to start an openHAB instance in debug mode. You should see openHAB startup in a new VSCode terminal.
I get an error message:
In Zeile:1 Zeichen:3
+ & $env:openhab_home/start.bat debug
+ CategoryInfo : ObjectNotFound: (F://Openhabian/...-main/start.bat:String) [], Command NotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
There is no start.bat file in myopenhab_home in Windows. I guess this should start a debug instance of openhab on my remote raspi dedicated to running openhab.
Where can I find the contents of the missing start.bat?
or can I use an alternative to start openhab in debug mode on my raspi (via putty)
Will VS connect to this debug session as stated in 10.3. of the above document?
