The script is just this:
from core.log import logging, LOG_PREFIX, log_traceback
@log_traceback
def removeOWMItems():
removeOWMItems.log = logging.getLogger("{}.removeOWMItems".format(LOG_PREFIX))
from core.items import remove_item
for item in ir.getItemsByTag("OpenWeatherMap"):
removeOWMItems.log.debug("removeOWMItems: [{}]".format(item))
remove_item(item)
# use this as a last resort, but make sure it's not removing any Items not
created by this script
for item in ir.getAll():
if "Forecast_" in item.name or "Current_" in item.name:
remove_item(item)
#removeOWMItems()
def addOWMItems():
addOWMItems.log = logging.getLogger("{}.addOWMItems".format(LOG_PREFIX))
# create OWM Items and groups, if they do not exist
scriptExtension.importPreset("RuleSupport")
from javax.measure.quantity import Dimensionless, Temperature, Length, Speed, Pressure#, Angle
try:
from org.openhab.core.thing import ThingTypeUID
from org.openhab.core.thing import ChannelUID
except:
from org.eclipse.smarthome.core.thing import ThingTypeUID
from org.eclipse.smarthome.core.thing import ChannelUID
try:
from org.eclipse.smarthome.core.library.types import QuantityTypeArithmeticGroupFunction
except:
from org.openhab.core.library.types import QuantityTypeArithmeticGroupFunction
from core.items import add_item
from core.links import add_link
try:
owmThingUID = None
for thing in things.getAll():
if thing.getThingTypeUID() == ThingTypeUID("openweathermap:weather-and-forecast"):
if str(thing.statusInfo) == "ONLINE":
thingConfiguration = thing.getConfiguration()
forecastHours = thingConfiguration.get("forecastHours")
if str(forecastHours) == "120":
forecastDays = thingConfiguration.get("forecastDays")
if str(forecastDays) == "0":
owmThingUID = str(thing.getUID())
break
else:
addOWMItems.log.warn("Thing found, but forecastDays is not set to [0]: forecastDays=[{}]".format(forecastDays))
else:
addOWMItems.log.warn("Thing found, but forecastHours is not set to [120]: forecastHours=[{}]".format(forecastHours))
else:
addOWMItems.log.warn("Thing found, but statusInfo was not [ONLINE]: statusInfo=[{}]".format(thing.statusInfo))
if owmThingUID is None:
addOWMItems.log.warn("No Thing found with ThingTypeUID 'openweathermap:weather-and-forecast', or it was not ONLINE, or it was improperly configured for the free API. Exiting script.")
else:
addOWMItems.log.debug("owmThingUID set to [{}]".format(owmThingUID))
# install Scale transformation service, if not already
from org.eclipse.smarthome.model.script.actions.Exec import executeCommandLine
import json
scaleCheckResult = json.loads(executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -s --connect-timeout 10 -m 10 -X GET -H \"Accept: application/json\" \"http://localhost:8080/rest/extensions/transformation-scale\"", 15000))['installed']
if not scaleCheckResult:
installScaleResult = executeCommandLine("/bin/sh@@-c@@/usr/bin/curl -o /dev/null -s -w \"%{http_code}\" --connect-timeout 10 -m 10 -X POST -H \"Content-Type: application/json\" -H \"Accept: application/json\" \"http://localhost:8080/rest/extensions/transformation-scale/install\"",15000)
if installScaleResult != "200":
addOWMItems.log.debug("Scale transformation service installation failed")
return
else:
addOWMItems.log.debug("Scale transformation service has been installed")
else:
addOWMItems.log.debug("Scale transformation service is already installed")
# create Current group and Items
if ir.getItems("gOpenWeatherMap") == []:
add_item("gOpenWeatherMap", item_type="Group", groups=["gWeather"], label="OpenWeatherMap", tags=["OpenWeatherMap"])
if ir.getItems("gCurrent") == []:
add_item("gCurrent", item_type="Group", groups=["gOpenWeatherMap"], label="Current", tags=["OpenWeatherMap"])
if ir.getItems("Current_Timestamp") == []:
add_item("Current_Timestamp", item_type="DateTime", groups=["gCurrent", "gForecast_Timestamp_1"], label="Current: Timestamp [%1$tY-%1$tm-%1$td %1$tI:%1$tM%1$tp]", category="Time", tags=["OpenWeatherMap"])
add_link("Current_Timestamp", ChannelUID(owmThingUID + ":current#time-stamp"))
if ir.getItems("Current_Condition") == []:
add_item("Current_Condition", item_type="String", groups=["gCurrent", "gForecast_Condition_1"], label="Current: Condition [%s]", category="Sun_Clouds", tags=["OpenWeatherMap"])
add_link("Current_Condition", ChannelUID(owmThingUID + ":current#condition"))
if ir.getItems("Current_ConditionID") == []:
add_item("Current_ConditionID", item_type="String", groups=["gCurrent", "gForecast_ConditionID_1"], label="Current: Condition ID [%s]", tags=["OpenWeatherMap"])
add_link("Current_ConditionID", ChannelUID(owmThingUID + ":current#condition-id"))
if ir.getItems("Current_IconID") == []:
add_item("Current_IconID", item_type="String", groups=["gCurrent", "gForecast_IconID_1"], label="Current: Icon ID [%s]", tags=["OpenWeatherMap"])
add_link("Current_IconID", ChannelUID(owmThingUID + ":current#icon-id"))
if ir.getItems("Current_Icon") == []:
add_item("Current_Icon", item_type="Image", groups=["gCurrent", "gForecast_Icon_1"], label="Current: Icon", tags=["OpenWeatherMap"])
add_link("Current_Icon", ChannelUID(owmThingUID + ":current#icon"))
if ir.getItems("Current_Temperature") == []:
add_item("Current_Temperature", item_type="Number:Temperature", groups=["gCurrent", "gForecast_Temperature_High_1", "gForecast_Temperature_Low_1"], label="Current: Temperature [%.0f %unit%]", category="Temperature", tags=["OpenWeatherMap"])
add_link("Current_Temperature", ChannelUID(owmThingUID + ":current#temperature"))
if ir.getItems("Current_Pressure") == []:
add_item("Current_Pressure", item_type="Number:Pressure", groups=["gCurrent", "gForecast_Pressure_1"], label="Current: Pressure [%.1f %unit%]", category="Pressure", tags=["OpenWeatherMap"])
add_link("Current_Pressure", ChannelUID(owmThingUID + ":current#pressure"))
if ir.getItems("Current_Humidity") == []:
add_item("Current_Humidity", item_type="Number:Dimensionless", groups=["gCurrent", "gForecast_Humidity_1"], label="Current: Humidity [%d %%]", category="Humidity", tags=["OpenWeatherMap"])
add_link("Current_Humidity", ChannelUID(owmThingUID + ":current#humidity"))
if ir.getItems("Current_WindSpeed") == []:
add_item("Current_WindSpeed", item_type="Number:Speed", groups=["gCurrent", "gForecast_WindSpeed_1"], label="Current: Wind speed [%.0f %unit%]", category="Wind", tags=["OpenWeatherMap"])
add_link("Current_WindSpeed", ChannelUID(owmThingUID + ":current#wind-speed"))
if ir.getItems("Current_GustSpeed") == []:
add_item("Current_GustSpeed", item_type="Number:Speed", groups=["gCurrent", "gForecast_GustSpeed_1"], label="Current: Gust speed [%.0f %unit%]", category="Wind", tags=["OpenWeatherMap"])
add_link("Current_GustSpeed", ChannelUID(owmThingUID + ":current#gust-speed"))
if ir.getItems("Current_WindDirection") == []:
add_item("Current_WindDirection", item_type="Number:Angle", groups=["gCurrent", "gForecast_WindDirection_1"], label="Current: Wind direction [SCALE(windDirection.scale):%s]", category="Wind", tags=["OpenWeatherMap"])
add_link("Current_WindDirection", ChannelUID(owmThingUID + ":current#wind-direction"))
if ir.getItems("Current_Cloudiness") == []:
add_item("Current_Cloudiness", item_type="Number:Dimensionless", groups=["gCurrent", "gForecast_Cloudiness_1"], label="Current: Cloudiness [%d %%]", category="Sun_Clouds", tags=["OpenWeatherMap"])
add_link("Current_Cloudiness", ChannelUID(owmThingUID + ":current#cloudiness"))
if ir.getItems("Current_RainVolume") == []:
add_item("Current_RainVolume", item_type="Number:Length", groups=["gCurrent", "gForecast_RainVolume_1"], label="Current: Rain volume [%.1f %unit%]", category="Rain", tags=["OpenWeatherMap"])
add_link("Current_RainVolume", ChannelUID(owmThingUID + ":current#rain"))
if ir.getItems("Current_SnowVolume") == []:
add_item("Current_SnowVolume", item_type="Number:Length", groups=["gCurrent", "gForecast_SnowVolume_1"], label="Current: Snow volume [%.1f %unit%]", category="Snow", tags=["OpenWeatherMap"])
add_link("Current_SnowVolume", ChannelUID(owmThingUID + ":current#snow"))
# create Forecast groups
import calendar
from org.joda.time import DateTime
lastReading = DateTime(str(items["Current_Timestamp"])).getDayOfWeek() - 1
for index in range(1, 6):
dayOfWeek = "Today" if index == 1 else calendar.day_name[(lastReading + index - 1) % 7]
if ir.getItems("gForecast_" + str(index)) == []:
add_item("gForecast_" + str(index), item_type="Group", groups=["gOpenWeatherMap"], label=dayOfWeek, tags=["OpenWeatherMap"])
if ir.getItems("gForecast_Timestamp_" + str(index)) == []:
add_item("gForecast_Timestamp_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Timestamp [%1$tY-%1$tm-%1$td %1$tI:%1$tM%1$tp]", category="Time", tags=["OpenWeatherMap"])
if ir.getItems("gForecast_Condition_" + str(index)) == []:
add_item("gForecast_Condition_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Condition [%s]", gi_base_type="String", category="Sun_Clouds", tags=["OpenWeatherMap"])
if ir.getItems("gForecast_ConditionID_" + str(index)) == []:
add_item("gForecast_ConditionID_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Condition ID [%s]", gi_base_type="String", tags=["OpenWeatherMap"])
if ir.getItems("gForecast_IconID_" + str(index)) == []:
add_item("gForecast_IconID_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Icon ID [%s]", gi_base_type="String", tags=["OpenWeatherMap"])
if ir.getItems("gForecast_Icon_" + str(index)) == []:
add_item("gForecast_Icon_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Icon", gi_base_type="Image", tags=["OpenWeatherMap"])
if ir.getItems("gForecast_Temperature_High_" + str(index)) == []:
add_item("gForecast_Temperature_High_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Temperature (high) [%.0f %unit%]", category="Temperature_Hot", gi_base_type="Number:Temperature", group_function=QuantityTypeArithmeticGroupFunction.Max(Temperature), tags=["OpenWeatherMap"])
if ir.getItems("gForecast_Temperature_Low_" + str(index)) == []:
add_item("gForecast_Temperature_Low_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Temperature (low) [%.0f %unit%]", category="Temperature_Cold", gi_base_type="Number:Temperature", group_function=QuantityTypeArithmeticGroupFunction.Min(Temperature), tags=["OpenWeatherMap"])
if ir.getItems("gForecast_Pressure_" + str(index)) == []:
add_item("gForecast_Pressure_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Pressure [%.1f %unit%]", category="Pressure", gi_base_type="Number:Pressure", group_function=QuantityTypeArithmeticGroupFunction.Max(Pressure), tags=["OpenWeatherMap"])
if ir.getItems("gForecast_Humidity_" + str(index)) == []:
add_item("gForecast_Humidity_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Humidity [%d %%]", category="Humidity", gi_base_type="Number:Dimensionless", group_function=QuantityTypeArithmeticGroupFunction.Max(Dimensionless), tags=["OpenWeatherMap"])
if ir.getItems("gForecast_WindSpeed_" + str(index)) == []:
add_item("gForecast_WindSpeed_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Wind Speed [%.0f %unit%]", category="Wind", gi_base_type="Number:Speed", group_function=QuantityTypeArithmeticGroupFunction.Max(Speed), tags=["OpenWeatherMap"])
if ir.getItems("gForecast_GustSpeed_" + str(index)) == []:
add_item("gForecast_GustSpeed_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Gust Speed [%.0f %unit%]", category="Wind", gi_base_type="Number:Speed", group_function=QuantityTypeArithmeticGroupFunction.Max(Speed), tags=["OpenWeatherMap"])
if ir.getItems("gForecast_WindDirection_" + str(index)) == []:
#add_item("gForecast_WindDirection_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Wind direction [SCALE(windDirection.scale):%s]", category="Wind", gi_base_type="Number:Angle", group_function=QuantityTypeArithmeticGroupFunction.Avg(Angle), tags=["OpenWeatherMap"])# this doesn't work properly yet
add_item("gForecast_WindDirection_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Wind direction [SCALE(windDirection.scale):%s]", category="Wind", gi_base_type="Number:Angle", tags=["OpenWeatherMap"])
if ir.getItems("gForecast_Cloudiness_" + str(index)) == []:
add_item("gForecast_Cloudiness_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Cloudiness [%d %%]", category="Sun_Clouds", gi_base_type="Number:Dimensionless", group_function=QuantityTypeArithmeticGroupFunction.Max(Dimensionless), tags=["OpenWeatherMap"])
if ir.getItems("gForecast_RainVolume_" + str(index)) == []:
add_item("gForecast_RainVolume_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Rain Volume [%.1f %unit%]", category="Rain", gi_base_type="Number:Length", group_function=QuantityTypeArithmeticGroupFunction.Sum(Length), tags=["OpenWeatherMap"])
if ir.getItems("gForecast_SnowVolume_" + str(index)) == []:
add_item("gForecast_SnowVolume_" + str(index), item_type="Group", groups=["gForecast_" + str(index)], label=dayOfWeek + ": Snow Volume [%.1f %unit%]", category="Snow", gi_base_type="Number:Length", group_function=QuantityTypeArithmeticGroupFunction.Sum(Length), tags=["OpenWeatherMap"])
# create Forecast Items
for index in range(1, 41):
if ir.getItems("Forecast_Timestamp_{:02d}".format(3 * index)) == []:
add_item("Forecast_Timestamp_{:02d}".format(3 * index), item_type="DateTime", label="Forecast ({:02d}): Timestamp [%1$tY-%1$tm-%1$td %1$tI:%1$tM%1$tp]".format(3 * index), category="Time", tags=["OpenWeatherMap"])
add_link("Forecast_Timestamp_{:02d}".format(3 * index), ChannelUID(owmThingUID + ":forecastHours{:02d}#time-stamp".format(3 * index)))
if ir.getItems("Forecast_Condition_{:02d}".format(3 * index)) == []:
add_item("Forecast_Condition_{:02d}".format(3 * index), item_type="String", label="Forecast ({:02d}): Condition [%s]".format(3 * index), category="Sun_Clouds", tags=["OpenWeatherMap"])
add_link("Forecast_Condition_{:02d}".format(3 * index), ChannelUID(owmThingUID + ":forecastHours{:02d}#condition".format(3 * index)))
if ir.getItems("Forecast_ConditionID_{:02d}".format(3 * index)) == []:
add_item("Forecast_ConditionID_{:02d}".format(3 * index), item_type="String", label="Forecast ({:02d}): Condition ID [%s]".format(3 * index), tags=["OpenWeatherMap"])
add_link("Forecast_ConditionID_{:02d}".format(3 * index), ChannelUID(owmThingUID + ":forecastHours{:02d}#condition-id".format(3 * index)))
if ir.getItems("Forecast_IconID_{:02d}".format(3 * index)) == []:
add_item("Forecast_IconID_{:02d}".format(3 * index), item_type="String", label="Forecast ({:02d}): Icon ID [%s]".format(3 * index), tags=["OpenWeatherMap"])
add_link("Forecast_IconID_{:02d}".format(3 * index), ChannelUID(owmThingUID + ":forecastHours{:02d}#icon-id".format(3 * index)))
if ir.getItems("Forecast_Icon_{:02d}".format(3 * index)) == []:
add_item("Forecast_Icon_{:02d}".format(3 * index), item_type="Image", label="Forecast ({:02d}): Icon".format(3 * index), tags=["OpenWeatherMap"])
add_link("Forecast_Icon_{:02d}".format(3 * index), ChannelUID(owmThingUID + ":forecastHours{:02d}#icon".format(3 * index)))
if ir.getItems("Forecast_Temperature_{:02d}".format(3 * index)) == []:
add_item("Forecast_Temperature_{:02d}".format(3 * index), item_type="Number:Temperature", label="Forecast ({:02d}): Temperature [%.0f %unit%]".format(3 * index), category="Temperature", tags=["OpenWeatherMap"])
add_link("Forecast_Temperature_{:02d}".format(3 * index), ChannelUID(owmThingUID + ":forecastHours{:02d}#temperature".format(3 * index)))
if ir.getItems("Forecast_Pressure_{:02d}".format(3 * index)) == []:
add_item("Forecast_Pressure_{:02d}".format(3 * index), item_type="Number:Pressure", label="Forecast ({:02d}): Pressure [%.1f %unit%]".format(3 * index), category="Pressure", tags=["OpenWeatherMap"])
add_link("Forecast_Pressure_{:02d}".format(3 * index), ChannelUID(owmThingUID + ":forecastHours{:02d}#pressure".format(3 * index)))
if ir.getItems("Forecast_Humidity_{:02d}".format(3 * index)) == []:
add_item("Forecast_Humidity_{:02d}".format(3 * index), item_type="Number:Dimensionless", label="Forecast ({:02d}): Humidity [%d %%]".format(3 * index), category="Humidity", tags=["OpenWeatherMap"])
add_link("Forecast_Humidity_{:02d}".format(3 * index), ChannelUID(owmThingUID + ":forecastHours{:02d}#humidity".format(3 * index)))
if ir.getItems("Forecast_WindSpeed_{:02d}".format(3 * index)) == []:
add_item("Forecast_WindSpeed_{:02d}".format(3 * index), item_type="Number:Speed", label="Forecast ({:02d}): Wind speed [%.0f %unit%]".format(3 * index), category="Wind", tags=["OpenWeatherMap"])
add_link("Forecast_WindSpeed_{:02d}".format(3 * index), ChannelUID(owmThingUID + ":forecastHours{:02d}#wind-speed".format(3 * index)))
if ir.getItems("Forecast_GustSpeed_{:02d}".format(3 * index)) == []:
add_item("Forecast_GustSpeed_{:02d}".format(3 * index), item_type="Number:Speed", label="Forecast ({:02d}): Gust speed [%.0f %unit%]".format(3 * index), category="Wind", tags=["OpenWeatherMap"])
add_link("Forecast_GustSpeed_{:02d}".format(3 * index), ChannelUID(owmThingUID + ":forecastHours{:02d}#gust-speed".format(3 * index)))
if ir.getItems("Forecast_WindDirection_{:02d}".format(3 * index)) == []:
add_item("Forecast_WindDirection_{:02d}".format(3 * index), item_type="Number:Angle", label="Forecast ({:02d}): Wind direction [SCALE(windDirection.scale):%s]".format(3 * index), category="Wind", tags=["OpenWeatherMap"])
add_link("Forecast_WindDirection_{:02d}".format(3 * index), ChannelUID(owmThingUID + ":forecastHours{:02d}#wind-direction".format(3 * index)))
if ir.getItems("Forecast_Cloudiness_{:02d}".format(3 * index)) == []:
add_item("Forecast_Cloudiness_{:02d}".format(3 * index), item_type="Number:Dimensionless", label="Forecast ({:02d}): Cloudiness [%d %%]".format(3 * index), category="Sun_Clouds", tags=["OpenWeatherMap"])
add_link("Forecast_Cloudiness_{:02d}".format(3 * index), ChannelUID(owmThingUID + ":forecastHours{:02d}#cloudiness".format(3 * index)))
if ir.getItems("Forecast_RainVolume_{:02d}".format(3 * index)) == []:
add_item("Forecast_RainVolume_{:02d}".format(3 * index), item_type="Number:Length", label="Forecast ({:02d}): Rain volume [%.1f %unit%]".format(3 * index), category="Rain", tags=["OpenWeatherMap"])
add_link("Forecast_RainVolume_{:02d}".format(3 * index), ChannelUID(owmThingUID + ":forecastHours{:02d}#rain".format(3 * index)))
if ir.getItems("Forecast_SnowVolume_{:02d}".format(3 * index)) == []:
add_item("Forecast_SnowVolume_{:02d}".format(3 * index), item_type="Number:Length", label="Forecast ({:02d}): Snow volume [%.1f %unit%]".format(3 * index), category="Snow", tags=["OpenWeatherMap"])
add_link("Forecast_SnowVolume_{:02d}".format(3 * index), ChannelUID(owmThingUID + ":forecastHours{:02d}#snow".format(3 * index)))
from core.rules import rule
from core.triggers import when
@rule("Add OpenWeatherMap Items to daily forecast groups")
@when("Item Current_Timestamp changed")
def addOWMItemsToGroups(event):
# remove hourly forecast Items from groups
for groupIndex in range(1, 6):
for member in filter(lambda item: "Current" not in item.name, ir.getItem("gForecast_Timestamp_{}".format(groupIndex)).getMembers()):
ir.getItem("gForecast_Timestamp_{}".format(groupIndex)).removeMember(member)
for member in filter(lambda item: "Current" not in item.name, ir.getItem("gForecast_Condition_{}".format(groupIndex)).getMembers()):
ir.getItem("gForecast_Condition_{}".format(groupIndex)).removeMember(member)
for member in filter(lambda item: "Current" not in item.name, ir.getItem("gForecast_ConditionID_{}".format(groupIndex)).getMembers()):
ir.getItem("gForecast_ConditionID_{}".format(groupIndex)).removeMember(member)
for member in filter(lambda item: "Current" not in item.name, ir.getItem("gForecast_IconID_{}".format(groupIndex)).getMembers()):
ir.getItem("gForecast_IconID_{}".format(groupIndex)).removeMember(member)
for member in filter(lambda item: "Current" not in item.name, ir.getItem("gForecast_Icon_{}".format(groupIndex)).getMembers()):
ir.getItem("gForecast_Icon_{}".format(groupIndex)).removeMember(member)
for member in filter(lambda item: "Current" not in item.name, ir.getItem("gForecast_Temperature_High_{}".format(groupIndex)).getMembers()):
ir.getItem("gForecast_Temperature_High_{}".format(groupIndex)).removeMember(member)
for member in filter(lambda item: "Current" not in item.name, ir.getItem("gForecast_Temperature_Low_{}".format(groupIndex)).getMembers()):
ir.getItem("gForecast_Temperature_Low_{}".format(groupIndex)).removeMember(member)
for member in filter(lambda item: "Current" not in item.name, ir.getItem("gForecast_Pressure_{}".format(groupIndex)).getMembers()):
ir.getItem("gForecast_Pressure_{}".format(groupIndex)).removeMember(member)
for member in filter(lambda item: "Current" not in item.name, ir.getItem("gForecast_Humidity_{}".format(groupIndex)).getMembers()):
ir.getItem("gForecast_Humidity_{}".format(groupIndex)).removeMember(member)
for member in filter(lambda item: "Current" not in item.name, ir.getItem("gForecast_WindSpeed_{}".format(groupIndex)).getMembers()):
ir.getItem("gForecast_WindSpeed_{}".format(groupIndex)).removeMember(member)
for member in filter(lambda item: "Current" not in item.name, ir.getItem("gForecast_GustSpeed_{}".format(groupIndex)).getMembers()):
ir.getItem("gForecast_GustSpeed_{}".format(groupIndex)).removeMember(member)
for member in filter(lambda item: "Current" not in item.name, ir.getItem("gForecast_WindDirection_{}".format(groupIndex)).getMembers()):
ir.getItem("gForecast_WindDirection_{}".format(groupIndex)).removeMember(member)
for member in filter(lambda item: "Current" not in item.name, ir.getItem("gForecast_Cloudiness_{}".format(groupIndex)).getMembers()):
ir.getItem("gForecast_Cloudiness_{}".format(groupIndex)).removeMember(member)
for member in filter(lambda item: "Current" not in item.name, ir.getItem("gForecast_RainVolume_{}".format(groupIndex)).getMembers()):
ir.getItem("gForecast_RainVolume_{}".format(groupIndex)).removeMember(member)
for member in filter(lambda item: "Current" not in item.name, ir.getItem("gForecast_SnowVolume_{}".format(groupIndex)).getMembers()):
ir.getItem("gForecast_SnowVolume_{}".format(groupIndex)).removeMember(member)
# update group labels to reflect week day
import calendar
ir.getItem("gForecast_" + str(index)).setLabel(dayOfWeek)
ir.getItem("gForecast_Timestamp_" + str(index)).setLabel(dayOfWeek + ": Timestamp")
ir.getItem("gForecast_Condition_" + str(index)).setLabel(dayOfWeek + ": Condition [%s]")
ir.getItem("gForecast_ConditionID_" + str(index)).setLabel(dayOfWeek + ": Condition ID [%s]")
ir.getItem("gForecast_IconID_" + str(index)).setLabel(dayOfWeek + ": Icon ID [%s]")
ir.getItem("gForecast_Icon_" + str(index)).setLabel(dayOfWeek + ": Icon")
ir.getItem("gForecast_Temperature_High_" + str(index)).setLabel(dayOfWeek + ": Temperature (high) [%.0f %unit%]")
ir.getItem("gForecast_Temperature_Low_" + str(index)).setLabel(dayOfWeek + ": Temperature (low) [%.0f %unit%]")
ir.getItem("gForecast_Pressure_" + str(index)).setLabel(dayOfWeek + ": Pressure [%.1f %unit%]")
ir.getItem("gForecast_Humidity_" + str(index)).setLabel(dayOfWeek + ": Humidity [%d %%]")
ir.getItem("gForecast_WindSpeed_" + str(index)).setLabel(dayOfWeek + ": Wind Speed [%.0f %unit%]")
ir.getItem("gForecast_GustSpeed_" + str(index)).setLabel(dayOfWeek + ": Gust Speed [%.0f %unit%]")
ir.getItem("gForecast_WindDirection_" + str(index)).setLabel(dayOfWeek + ": Wind direction [SCALE(windDirection.scale):%s]")
ir.getItem("gForecast_Cloudiness_" + str(index)).setLabel(dayOfWeek + ": Cloudiness [%d %%]")
ir.getItem("gForecast_RainVolume_" + str(index)).setLabel(dayOfWeek + ": Rain Volume [%.1f %unit%]")
ir.getItem("gForecast_SnowVolume_" + str(index)).setLabel(dayOfWeek + ": Snow Volume [%.1f %unit%]")
# add Forecast Items to groups, and update the labels to reflect time
groupIndex = 1
if DateTime(str(items["Forecast_Timestamp_{:02}".format(3 * index)])).getDayOfWeek() - 1 != (DateTime.now().getDayOfWeek() + groupIndex - 2) % 7:
if groupIndex == 5:
break# we're at the end of the forecasts that fit into 5 days
else:
groupIndex += 1
labelTime = items["Forecast_Timestamp_{:02}".format(3 * index)].format("%1$tl:%1$tM%1$tp")
ir.getItem("gForecast_Timestamp_{}".format(groupIndex)).addMember(ir.getItem("Forecast_Timestamp_{:02d}".format(3 * index)))
ir.getItem("Forecast_Timestamp_{:02d}".format(3 * index)).setLabel("Forecast ({}): Timestamp [%1$tY-%1$tm-%1$td %1$tI:%1$tM%1$tp]".format(labelTime))
ir.getItem("gForecast_Condition_{}".format(groupIndex)).addMember(ir.getItem("Forecast_Condition_{:02d}".format(3 * index)))
ir.getItem("Forecast_Condition_{:02d}".format(3 * index)).setLabel("Forecast ({}): Condition [%s]".format(labelTime))
ir.getItem("gForecast_ConditionID_{}".format(groupIndex)).addMember(ir.getItem("Forecast_ConditionID_{:02d}".format(3 * index)))
ir.getItem("Forecast_ConditionID_{:02d}".format(3 * index)).setLabel("Forecast ({}): Condition ID [%s]".format(labelTime))
ir.getItem("gForecast_IconID_{}".format(groupIndex)).addMember(ir.getItem("Forecast_IconID_{:02d}".format(3 * index)))
ir.getItem("Forecast_IconID_{:02d}".format(3 * index)).setLabel("Forecast ({}): Icon ID [%s]".format(labelTime))
ir.getItem("gForecast_Icon_{}".format(groupIndex)).addMember(ir.getItem("Forecast_Icon_{:02d}".format(3 * index)))
ir.getItem("Forecast_Icon_{:02d}".format(3 * index)).setLabel("Forecast ({}): Icon".format(labelTime))
ir.getItem("gForecast_Temperature_High_{}".format(groupIndex)).addMember(ir.getItem("Forecast_Temperature_{:02d}".format(3 * index)))
ir.getItem("Forecast_Temperature_{:02d}".format(3 * index)).setLabel("Forecast ({}): Temperature [%.0f %unit%]".format(labelTime))
ir.getItem("gForecast_Temperature_Low_{}".format(groupIndex)).addMember(ir.getItem("Forecast_Temperature_{:02d}".format(3 * index)))
ir.getItem("gForecast_Pressure_{}".format(groupIndex)).addMember(ir.getItem("Forecast_Pressure_{:02d}".format(3 * index)))
ir.getItem("Forecast_Pressure_{:02d}".format(3 * index)).setLabel("Forecast ({}): Pressure [%.1f %unit%]".format(labelTime))
ir.getItem("gForecast_Humidity_{}".format(groupIndex)).addMember(ir.getItem("Forecast_Humidity_{:02d}".format(3 * index)))
ir.getItem("Forecast_Humidity_{:02d}".format(3 * index)).setLabel("Forecast ({}): Humidity [%d %%]".format(labelTime))
ir.getItem("gForecast_WindSpeed_{}".format(groupIndex)).addMember(ir.getItem("Forecast_WindSpeed_{:02d}".format(3 * index)))
ir.getItem("Forecast_WindSpeed_{:02d}".format(3 * index)).setLabel("Forecast ({}): Wind speed [%.0f %unit%]".format(labelTime))
ir.getItem("gForecast_GustSpeed_{}".format(groupIndex)).addMember(ir.getItem("Forecast_GustSpeed_{:02d}".format(3 * index)))
ir.getItem("Forecast_GustSpeed_{:02d}".format(3 * index)).setLabel("Forecast ({}): Gust speed [%.0f %unit%]".format(labelTime))
ir.getItem("gForecast_WindDirection_{}".format(groupIndex)).addMember(ir.getItem("Forecast_WindDirection_{:02d}".format(3 * index)))
ir.getItem("Forecast_WindDirection_{:02d}".format(3 * index)).setLabel("Forecast ({}): Wind direction [SCALE(windDirection.scale):%s]".format(labelTime))
ir.getItem("gForecast_Cloudiness_{}".format(groupIndex)).addMember(ir.getItem("Forecast_Cloudiness_{:02d}".format(3 * index)))
ir.getItem("Forecast_Cloudiness_{:02d}".format(3 * index)).setLabel("Forecast ({}): Cloudiness [%d %%]".format(labelTime))
ir.getItem("gForecast_RainVolume_{}".format(groupIndex)).addMember(ir.getItem("Forecast_RainVolume_{:02d}".format(3 * index)))
ir.getItem("Forecast_RainVolume_{:02d}".format(3 * index)).setLabel("Forecast ({}): Rain volume [%.1f %unit%]".format(labelTime))
ir.getItem("gForecast_SnowVolume_{}".format(groupIndex)).addMember(ir.getItem("Forecast_SnowVolume_{:02d}".format(3 * index)))
ir.getItem("Forecast_SnowVolume_{:02d}".format(3 * index)).setLabel("Forecast ({}): Snow volume [%.1f %unit%]".format(labelTime))
# set Condition, Icon and WindDirection group values
for group in [600, 200, 500, 300, 700, 800]:# the Conditions are organized into groups (https://openweathermap.org/weather-conditions), which I have prioritized
forecastItems = filter(lambda item: int(item.state.toString()) in range(group, group + 100), ir.getItem("gForecast_ConditionID_" + str(index)).getMembers())
if len(forecastItems) > 0:
sortedItems = sorted(forecastItems, key = lambda item: int(item.state.toString()))
selectedItem = sortedItems.pop()# this will provide the highest value in the sorted list of Items, which is usually the most severe condition
events.postUpdate("gForecast_ConditionID_" + str(index), selectedItem.state.toString())
events.postUpdate("gForecast_Condition_" + str(index), items[selectedItem.name.replace("ID", "")].toString())
events.postUpdate("gForecast_IconID_" + str(index), items[selectedItem.name.replace("Condition", "Icon")].toString())
events.postUpdate(ir.getItem("gForecast_Icon_" + str(index)), items[selectedItem.name.replace("ConditionID", "Icon")])
break
# this can be removed when QuantityTypeArithmeticGroupFunction.Avg() is fixed for Number:Angle
windDirectionItemStates = map(lambda item: item.state.intValue(), filter(lambda member: member.state != NULL and member.state != UNDEF, ir.getItem("gForecast_WindDirection_" + str(index)).getMembers()))
if len(windDirectionItemStates) > 0:
windDirectionAvg = reduce(lambda x, y: (((x + y) / 2) if y - x < 180 else (x + y + 360) / 2) % 360, windDirectionItemStates)
events.postUpdate("gForecast_WindDirection_" + str(index), str(windDirectionAvg))
addOWMItemsToGroups.log.debug("Updated groups and Items")
addOWMItemsToGroups(None)
except:
import traceback
addOWMItems.log.error(traceback.format_exc())
def scriptLoaded(id):
addOWMItems()
and it works quite fine( it’s Original Scott
). So I’m wondering if my VSC-Settings for Python are correct?!
.env is:
PYTHONPATH="./automation/lib/python"
.pylintrc is:
[MESSAGES CONTROL]
disable=
missing-docstring,
unused-variable,
line-too-long,
logging-format-interpolation,
bare-except,
broad-except,
pointless-string-statement,
undefined-variable,
unused-argument,
wrong-import-position,
anomalous-unicode-escape-in-string,
global-statement
ignored-modules=
org.joda.time,
java,
core,
core.jsr223,
core.actions,
community,
personal,
configuration,
events
[DESIGN]
# Maximum number of parents for a class (see R0901).
max-parents=15
and .vsc(settings.json) is:
"openhab.host": "192.168.x.yyy",
"openhab.port": 8080,
"openhab.remoteLspEnabled": true,
"openhab.remoteLspPort": 5007,
"openhab.sitemapPreviewUI": "basicui",
"openhab.useRestApi": true,
"python.linting.ignorePatterns": [
"**/automation/**/python/core/**/*.py",
"**/automation/**/python/community/**/*.py"
"python.linting.enabled": true,
"python.linting.pylintEnabled": true,
"python.pythonPath": "D:\\Programme-Peter\\Python\\Python27\\python.exe"
