I wanted to switch from the old Wake on Lan binding to the network binding to wake my PC’s remotely.
I’m not completely stupid but these rules in openHAB get me down. I read the documentation from the network binding and wanted to create a rule to wake up the PC, but I fail miserably again.
rule "Home Server wecken"
Item HomeServer_Online changed
val actions = getActions("network", "network:pingdevice:Home Server")
if (actions === null) {
logInfo("actions", "Actions not found, check thing ID")
return
else {
actions.sendWakeOnLanPacket()
This is exactly what the documentation usually says and of course it doesn’t work. What values must be in there so that OH sends the WOL packet?
I can use OH well, but the rules is a book with seven seals.
I’m starting to feel really stupid to always have to ask.
What doesn’t work? What do the logs say? Did you also read the bit about your thing definition requiring the MAC address of your device that you’re trying to wake?
val actions = getActions("network", "network:pingdevice:Home_Server")
return
else {
FYI! The finished rule should be written like this:
Item HomeServer_WOL changed from OFF to ON
val actions = getActions("network", "network:pingdevice:192_168_0_10")
return
else {
It is important to define the change correctly, otherwise the computer will always restart as soon as the switch changes.
