in the following config, WOL works for the KodiPC, but not for the WorkPC. The shutdown, issued via a ssh-command works on both machines. The KodioffXXX-Items and WorkpcoffXXX-Items are generated by VS Code-Editor-Extension from things made withe Paper-UI. The WorkPC responds to a wol command submitted via shell on my notebook, so WOL working for WorkPC.
Please, can somebody have a look at my config-files if there is a glitch i haven’t noticed? Thanks!
The Items-file:
Switch KodiOn "Kodion" {wol="ON:192.168.1.255#D4-3D-7E-E1-B5-A0"}
String KodioffOutput "Output" {channel="exec:command:31753531:output"}
String KodioffInput "Input" {channel="exec:command:31753531:input"}
Number KodioffExit "Exit value" {channel="exec:command:31753531:exit"}
Switch KodioffRun "Running" {channel="exec:command:31753531:run"}
Switch KodiPC "Kodi" [ "Lighting" ]
Switch WorkPcOn "WorkPCOn" {wol="ON:192.168.1.255#B4-2E-99-31-7F-87"}
String WorkpcoffOutput "Output" {channel="exec:command:63e0a6ff:output"}
String WorkpcoffInput "Input" {channel="exec:command:63e0a6ff:input"}
Number WorkpcoffExit "Exit value" {channel="exec:command:63e0a6ff:exit"}
Switch WorkpcoffRun "Running" {channel="exec:command:63e0a6ff:run"}
Switch WorkPC "Erde" [ "Lighting" ]
the rules-file
rule "Kodi1 WOL"
Item KodiPC received command
then switch (receivedCommand) {
case ON : KodiOn.sendCommand(ON)
case OFF : KodioffRun.sendCommand(ON)
rule "WorkPC WOL"
Item WorkPC received command
case ON : WorkPcOn.sendCommand(ON)
case OFF : WorkpcoffRun.sendCommand(ON)
and the sitemap-file
sitemap wol label="WakeOnLan" {
Frame label="Kodi" {
Switch item=KodiPC label="Mediacenter" icon="Switch"
//For debugging
Switch item=KodioffRun label="Kodi aus" icon="Switch"
Text item=KodioffOutput label="Kodi Output" icon="sun_clouds"
Frame label="PC" {
Switch item=WorkPC label="ArbeitsPC" icon="Switch"
//For debugging
Switch item=workpcoffRun label="ArbeitsPC aus" icon="Switch"
Text item=workpcoffOutput label="PC Output" icon="sun_clouds"
