I have a WallMote Dual (zw129) and after adding it to my zwave network, I look in PaperUI and see the only channels available are
Switch
Dimmer
Electric Meter (watts and kwh)
This seems odd to me as the WallMote quad, (zw130) has these channels:
scene_number
scene_number(1-4)
Battery Level
Alarm
With zwave debug mode enabled, I see a central scene command being sent when I press button 1, so why should there not be a scene channel? Or any of the others for that matter? Electric Meter is meaningless for a battery powered device.
So because of this, I have limited means of controlling the device.
I am seeing the same thing. It also doesn’t have the standard information about the device, as per the quad wallmotes, so I am thinking it isn’t registered in the database. Was just going to check.
I checked the DB and its listed there. I could still use the device if the left button sent a command for each press. Sending a command for every other press just has no meaning for me.
I have the same issue, via the logs I can see it is receiving events via CENTRAL_SCENE but we don’t have the SCE_NUMBER channel so we can’t catch the events in OpenHab.
Is there any other way we can catch events for the DUO Wallmote with the existing channels available ?
