Hi I have small problem with some scene. It doesn’t work.
The idea was that a wallplug should off when consumption go to 5 wat and less for 60 seconds
Can somebody send me correct code?
Switch P2_Sypialnia_SzafkaNocna "Szafka nocna" { zwave="72:command=switch_binary" }
Number P2_Sypialnia_SzafkaNocna_Power "Aktualne zuzycie energii elektrycznej [%.1f W]" { zwave="72:command=sensor_multilevel" }
Number P2_Sypialnia_SzafkaNocna_Energy "Calkowite zuzycie energii elektrycznej [%.2f KWh]" { zwave="72:command=meter" }
rule
Item P2_Sypialnia_SzafkaNocna_Power changed
if(P2_Sypialnia_SzafkaNocna_Power.state <= 5) {
timer_p2_sypialnia_szafkanocna = createTimer(now.plusSeconds(60)) [|
sendCommand(P2_Sypialnia_SzafkaNocna,OFF)
else {
if(timer_p2_sypialnia_szafkanocna!=null) {
timer_p2_sypialnia_szafkanocna.cancel
timer_p2_sypialnia_szafkanocna = null
