Want to find a consultant to help me get this working
Dear All
I have installed openhab on my mac mini, a Mac book pro and a raspberry 2.
Why so many installations. Well its because I can not get the program to be fully functional on any computer that I have. Also it is weird that the software is working or not working on each machine, differently
About 3 month ago I spent a lot of time trying to get this all working. I am happy to learn however I now need some concentrated help
My goal is to integrate my phillips hue lights and wemo switches.
Also I have some eve products and I am making my own arduino wireless sensors
I have in the past watched youtube video on these aspects, however if you can not get the unit to bind then you van not make progress
Probably I will want the system running on a raspberry 3 (not finally decided)
On all three machines the software is installed and it is running. I have log files that can be forwarded to you for inspection
So what is not working
On the Mac Mini there is a java problem. The mini thinks it has version 8 installed and openhab does not agree. Also I can not get the wemo switch to bind to the software even though I have added the wemo file to add ons folder
mobile app does not connect to the server
On the Mac book pro the mobile app does not connect to the server. However the wemo did bind
On the raspberry 2
can not connect via a browser or the mobile app
I think the problem is with firewalls and router ports however it could be anything
I am free most times to work on this and can colaborate via remote software and Skype
I am happy to pay a small/ reasonable fee to help me get this up and running. For an experience person it should be simple
regards
Max
Some free advice. Pick one environment (does not matter which, although your final target is not a bad choice).
Solve THAT ONE. Your solution will likely involve various/many hackish things that are probably actually irrelevant but you don’t know that yet. DOCUMENT EVERYTHING YOU DO AS YOU DO IT. Every command line complete with options, every file change, EVERYTHING.
A. Solve connectivity FIRST. Can you ping the target environment from another machine in the same LAN. If not, SOLVE THAT FIRST.
B. Once you can ping the target, can you ssh to it ? If not, SOLVE THAT.
C. Once you can ssh, can you start OpenHab in the ssh session. If not, SOLVE THAT.
D. Once you can start OpenHab, can you make a configuration change and have it “stick” ? If not, SOLVE THAT.
Many thanks I will work through this in the morning. Excuse my ignorance what is ssh
Max Birley
+353 87 462 7660
Skype mdbirley
ssh -> Secure(d) SHell, this software provides a secured connection e.g. from your MacBook to your Raspberry command line, so you don’t need no graphical environment on the Pi.
Dear All
I have made some progress small with OpenHab in the last week or so. It seems that my previous problem relates to the fact that I have 2 networks here at my house. One is simple network and has one wireless router called “Office” .The other relies on a separate wireless router plus a number of Devolo wireless extenders.
The house does not get good internet bandwidth over normal phone lines so I use 2 wireless routers that connect to a close by cell phone wireless system.
The second network is called “Home". If I log onto Office most things with OpenHab work. I can get Openhab’s server to start, the browser and the app both send commands to the server and I can see the commands being logged in the server terminal screen. When I use “Home" neither the browser screens nor the app work or connect. So for now, until someone can help me find a solution to this I will stick with the simple “Office” network system.
I will need to fix this as the house is large and I need to have access via the network to the whole house or this will be a very limited system.
Help will be appreciated on this issue
OK onto my real headache.
To get started with this project at first I am aiming low. All I am trying to do is to connect to one Wemo switch to openhab.
To do this, I have connected the Wemo switch to the Office wireless network and it is fully functional via the Wemo app.
I added the following line to the demo.items file
Switch Light_FF_Office_Ceiling “Ceiling” (FF_Office, Lights) {wemo = "Socket-1_0-221538K1100237”}
The server when it starts up, sees the following
2016-07-04 20:49:44.145 [INFO ] [.service.AbstractActiveService] - Wemo Refresh Service has been started
and then nothing.
Some help here would be appreciated as I am going around in circles. I sure the fix is minor
Server output to terminal window
Maxs-MacBook-Pro:~ maxbirley$ sudo /applications/openhab/start.sh
Password:
Launching the openHAB runtime…
osgi> 2016-07-04 20:49:28.227 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.8.1).
2016-07-04 20:49:29.232 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2016-07-04 20:49:29.287 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2016-07-04 20:49:31.632 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
2016-07-04 20:49:38.842 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘demo.sitemap’
2016-07-04 20:49:39.047 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘db4o.persist’
2016-07-04 20:49:39.067 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘exec.persist’
2016-07-04 20:49:39.073 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘logging.persist’
2016-07-04 20:49:39.082 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘rrd4j.persist’
2016-07-04 20:49:39.132 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘demo.script’
2016-07-04 20:49:39.233 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘demo.items’
2016-07-04 20:49:39.781 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /classicui/openhab.app
2016-07-04 20:49:42.859 [INFO ] [.service.AbstractActiveService] - NTP Refresh Service has been started
2016-07-04 20:49:42.885 [INFO ] [.service.AbstractActiveService] - HTTP Refresh Service has been started
2016-07-04 20:49:42.923 [INFO ] [.p.rrd4j.internal.RRD4jService] - Removing invalid defintion component = null heartbeat = 0 min/max = 0.0/0.0 step = 0 0 archives(s) = [] 0 items(s) = []
2016-07-04 20:49:43.099 [INFO ] [runtime.busevents ] - Date state updated to 2016-07-04T20:49:43
2016-07-04 20:49:44.673 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:49:44.673 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:49:44.912 [INFO ] [runtime.busevents ] - Weather_Humidity state updated to
2016-07-04 20:49:47.529 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:49:47.530 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:49:47.542 [INFO ] [runtime.busevents ] - Weather_Temperature state updated to
2016-07-04 20:49:49.341 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘demo.rules’
2016-07-04 20:49:50.253 [ERROR] [m.r.internal.engine.RuleEngine] - Error during the execution of startup rule ‘Initialize light states’: Could not invoke method: org.openhab.model.script.actions.BusEvent.postUpdate(org.openhab.core.items.Item,java.lang.Number) on instance: null
2016-07-04 20:49:50.351 [ERROR] [m.r.internal.engine.RuleEngine] - Error during the execution of startup rule ‘Initialize heating states’: Could not invoke method: org.openhab.model.script.actions.BusEvent.postUpdate(org.openhab.core.items.Item,java.lang.Number) on instance: null
2016-07-04 20:49:50.442 [ERROR] [m.r.internal.engine.RuleEngine] - Error during the execution of startup rule ‘Initialize contact states’: Could not invoke method: org.openhab.model.script.actions.BusEvent.postUpdate(org.openhab.core.items.Item,java.lang.Number) on instance: null
2016-07-04 20:49:50.466 [INFO ] [runtime.busevents ] - DemoLocation state updated to 52.5200066,13.4049540
2016-07-04 20:49:50.566 [INFO ] [runtime.busevents ] - Temperature_GF_Corridor state updated to 18.90000000
2016-07-04 20:49:50.570 [INFO ] [runtime.busevents ] - Temperature_GF_Toilet state updated to 21.80000000
2016-07-04 20:49:50.574 [INFO ] [runtime.busevents ] - Temperature_GF_Living state updated to 18.00000000
2016-07-04 20:49:50.578 [INFO ] [runtime.busevents ] - Temperature_GF_Kitchen state updated to 18.30000000
2016-07-04 20:49:50.582 [INFO ] [runtime.busevents ] - Temperature_FF_Bath state updated to 21.40000000
2016-07-04 20:49:50.585 [INFO ] [runtime.busevents ] - Temperature_FF_Office state updated to 18.80000000
2016-07-04 20:49:50.592 [INFO ] [runtime.busevents ] - Temperature_FF_Child state updated to 18.70000000
2016-07-04 20:49:50.595 [INFO ] [runtime.busevents ] - Temperature_FF_Bed state updated to 21.30000000
2016-07-04 20:49:50.688 [INFO ] [runtime.busevents ] - Weather_Temp_Max state updated to 4.98333333333333339254522798000834882259368896484375
2016-07-04 20:49:50.717 [INFO ] [runtime.busevents ] - Weather_Temp_Min state updated to 1
2016-07-04 20:49:50.769 [INFO ] [g.openhab.model.script.Weather] - Temperature evolved of 0 degrees.
2016-07-04 20:50:00.058 [INFO ] [runtime.busevents ] - Temperature_GF_Corridor state updated to 17.90000000
2016-07-04 20:50:00.062 [INFO ] [runtime.busevents ] - Temperature_GF_Toilet state updated to 20.30000000
2016-07-04 20:50:00.074 [INFO ] [runtime.busevents ] - Temperature_GF_Living state updated to 17.80000000
2016-07-04 20:50:00.077 [INFO ] [runtime.busevents ] - Temperature_GF_Kitchen state updated to 20.50000000
2016-07-04 20:50:00.083 [INFO ] [runtime.busevents ] - Temperature_FF_Bath state updated to 18.00000000
2016-07-04 20:50:00.086 [INFO ] [runtime.busevents ] - Temperature_FF_Office state updated to 20.90000000
2016-07-04 20:50:00.090 [INFO ] [runtime.busevents ] - Temperature_FF_Child state updated to 21.80000000
2016-07-04 20:50:00.099 [INFO ] [runtime.busevents ] - Temperature_FF_Bed state updated to 20.30000000
2016-07-04 20:50:08.481 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:08.482 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:14.987 [INFO ] [runtime.busevents ] - Light_FF_Office_Ceiling received command ON
2016-07-04 20:50:14.990 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:14.991 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:15.301 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:15.302 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:15.368 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:15.370 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:18.234 [INFO ] [runtime.busevents ] - Light_FF_Office_Ceiling received command OFF
2016-07-04 20:50:18.240 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:18.241 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:18.550 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:18.551 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:18.603 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:18.604 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:22.351 [WARN ] [org.eclipse.jetty.io.nio ] - javax.net.ssl.SSLException: Inbound closed before receiving peer’s close_notify: possible truncation attack?
2016-07-04 20:50:24.599 [WARN ] [org.eclipse.jetty.io.nio ] - javax.net.ssl.SSLException: Inbound closed before receiving peer’s close_notify: possible truncation attack?
2016-07-04 20:50:24.683 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:24.684 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:27.906 [INFO ] [runtime.busevents ] - Light_FF_Office_Ceiling received command ON
2016-07-04 20:50:27.909 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:27.910 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:27.912 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:27.913 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:28.216 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:28.217 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:28.220 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:28.221 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:28.353 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:28.354 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:30.831 [INFO ] [runtime.busevents ] - Light_FF_Office_Ceiling received command OFF
2016-07-04 20:50:30.833 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:30.834 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:31.141 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:31.142 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:31.351 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:31.352 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:46.039 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:50:46.039 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:50:46.050 [INFO ] [runtime.busevents ] - Weather_Humidity state updated to
2016-07-04 20:50:48.379 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:50:48.379 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:50:49.056 [INFO ] [runtime.busevents ] - Light_FF_Office_Ceiling received command ON
2016-07-04 20:50:49.056 [INFO ] [runtime.busevents ] - Weather_Temperature state updated to
2016-07-04 20:50:49.059 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:49.060 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:49.368 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:49.369 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:49.435 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:49.436 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:56.225 [INFO ] [runtime.busevents ] - Light_FF_Office_Ceiling received command OFF
2016-07-04 20:50:56.227 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:56.228 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:56.532 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:56.533 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:56.577 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:56.578 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:57.545 [INFO ] [runtime.busevents ] - Light_FF_Office_Ceiling received command ON
2016-07-04 20:50:57.547 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:57.548 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:57.856 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:57.857 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:57.899 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:57.900 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:50:58.582 [INFO ] [runtime.busevents ] - Light_FF_Office_Ceiling received command ON
2016-07-04 20:51:46.842 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:51:46.842 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:51:46.850 [INFO ] [runtime.busevents ] - Weather_Humidity state updated to
2016-07-04 20:51:49.169 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:51:49.169 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:51:49.179 [INFO ] [runtime.busevents ] - Weather_Temperature state updated to
2016-07-04 20:52:00.041 [WARN ] [org.eclipse.jetty.io.nio ] - javax.net.ssl.SSLException: Inbound closed before receiving peer’s close_notify: possible truncation attack?
2016-07-04 20:52:47.662 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:52:47.663 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:52:47.673 [INFO ] [runtime.busevents ] - Weather_Humidity state updated to
2016-07-04 20:52:50.341 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:52:50.341 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:52:50.349 [INFO ] [runtime.busevents ] - Weather_Temperature state updated to
2016-07-04 20:53:48.842 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:53:48.842 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:53:48.851 [INFO ] [runtime.busevents ] - Weather_Humidity state updated to
2016-07-04 20:53:51.174 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:53:51.174 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:53:51.182 [INFO ] [runtime.busevents ] - Weather_Temperature state updated to
2016-07-04 20:54:51.566 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:54:51.566 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:54:51.575 [INFO ] [runtime.busevents ] - Weather_Humidity state updated to
2016-07-04 20:54:51.895 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:54:51.895 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:54:51.903 [INFO ] [runtime.busevents ] - Weather_Temperature state updated to
2016-07-04 20:55:00.024 [INFO ] [runtime.busevents ] - Temperature_GF_Corridor state updated to 20.10000000
2016-07-04 20:55:00.027 [INFO ] [runtime.busevents ] - Temperature_GF_Toilet state updated to 19.50000000
2016-07-04 20:55:00.032 [INFO ] [runtime.busevents ] - Temperature_GF_Living state updated to 21.30000000
2016-07-04 20:55:00.035 [INFO ] [runtime.busevents ] - Temperature_GF_Kitchen state updated to 19.40000000
2016-07-04 20:55:00.038 [INFO ] [runtime.busevents ] - Temperature_FF_Bath state updated to 18.30000000
2016-07-04 20:55:00.042 [INFO ] [runtime.busevents ] - Temperature_FF_Office state updated to 19.30000000
2016-07-04 20:55:00.045 [INFO ] [runtime.busevents ] - Temperature_FF_Child state updated to 20.70000000
2016-07-04 20:55:00.047 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:55:00.048 [INFO ] [runtime.busevents ] - Temperature_FF_Bed state updated to 18.10000000
2016-07-04 20:55:00.048 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:55:00.355 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:55:00.356 [WARN ] [t.i.s.MapTransformationService] - Could not find a mapping for ‘-’ in the file ‘en.map’.
2016-07-04 20:55:52.562 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:55:52.562 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:55:52.569 [INFO ] [runtime.busevents ] - Weather_Humidity state updated to
2016-07-04 20:55:55.467 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:55:55.467 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:55:55.474 [INFO ] [runtime.busevents ] - Weather_Temperature state updated to
2016-07-04 20:56:53.000 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:56:53.000 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:56:53.009 [INFO ] [runtime.busevents ] - Weather_Humidity state updated to
2016-07-04 20:56:56.340 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:56:56.340 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:56:56.348 [INFO ] [runtime.busevents ] - Weather_Temperature state updated to
2016-07-04 20:57:53.879 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:57:53.879 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:57:53.886 [INFO ] [runtime.busevents ] - Weather_Humidity state updated to
2016-07-04 20:57:57.221 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:57:57.222 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:57:57.231 [INFO ] [runtime.busevents ] - Weather_Temperature state updated to
2016-07-04 20:58:54.720 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:58:54.720 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:58:54.727 [INFO ] [runtime.busevents ] - Weather_Humidity state updated to
2016-07-04 20:58:58.085 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 20:58:58.085 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 20:58:58.092 [INFO ] [runtime.busevents ] - Weather_Temperature state updated to
2016-07-04 21:00:00.026 [INFO ] [runtime.busevents ] - Temperature_GF_Corridor state updated to 21.30000000
2016-07-04 21:00:00.029 [INFO ] [runtime.busevents ] - Temperature_GF_Toilet state updated to 21.30000000
2016-07-04 21:00:00.031 [INFO ] [runtime.busevents ] - Temperature_GF_Living state updated to 21.10000000
2016-07-04 21:00:00.033 [INFO ] [runtime.busevents ] - Temperature_GF_Kitchen state updated to 20.30000000
2016-07-04 21:00:00.035 [INFO ] [runtime.busevents ] - Temperature_FF_Bath state updated to 21.60000000
2016-07-04 21:00:00.038 [INFO ] [runtime.busevents ] - Temperature_FF_Office state updated to 19.60000000
2016-07-04 21:00:00.041 [INFO ] [runtime.busevents ] - Temperature_FF_Child state updated to 19.20000000
2016-07-04 21:00:00.042 [INFO ] [runtime.busevents ] - Temperature_FF_Bed state updated to 18.10000000
2016-07-04 21:00:00.773 [ERROR] [g.openhab.io.net.http.HttpUtil] - Fatal transport error: java.net.SocketTimeoutException: Read timed out
2016-07-04 21:00:00.774 [ERROR] [.o.b.http.internal.HttpBinding] - No response received from ‘http://weather.yahooapis.com/forecastrss?w=638242&u=c
2016-07-04 21:00:01.101 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.comhttp://yahooapis.com”}
2016-07-04 21:00:01.101 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-07-04 21:00:01.106 [INFO ] [runtime.busevents ] - Weather_Temperature state updated to
2
You should provide a copy of your items file and openhab.cfg so folks can help you more effectively.
You have a number of bindings running that you haven’t discussed configuring. You could try removing the ones you’re not working on. This would reduce the extraneous output you have to deal with.
Here is the items file. In a separate post I will put the config file.
Basically they are the DEMO files with one change where I have added a memo switch
I still am happy to pay for a consultant
regards
Max
Group All
Group gGF (All)
Group gFF (All)
Group gC (All)
Group Outdoor (All)
Group Shutters (All)
Group Weather (All)
Group Status (All)
Group GF_Living “Living Room” (gGF)
Group GF_Kitchen “Kitchen” (gGF)
Group GF_Toilet “Toilet” (gGF)
Group GF_Corridor “Corridor” (gGF)
Group FF_Bath “Bathroom” (gFF)
Group FF_Office “Office” (gFF)
Group FF_Child “Child’s Room” (gFF)
Group FF_Bed “Bedroom” (gFF)
Group FF_Corridor “Corridor” (gFF)
/* active groups */
Group:Switch:OR(ON, OFF) Lights “All Lights [(%d)]” (All)
Group:Switch:OR(ON, OFF) Heating “No. of Active Heatings [(%d)]” (All)
Group:Number:AVG Temperature “Avg. Room Temperature [%.1f °C]” (Status)
Group:Contact:OR(OPEN, CLOSED) Windows “Open windows [(%d)]” (All)
/* Lights */
Dimmer Light_GF_Living_Table “Table” (GF_Living, Lights)
Switch Light_GF_Corridor_Ceiling “Ceiling” (GF_Corridor, Lights)
Switch Light_GF_Kitchen_Ceiling “Ceiling” (GF_Kitchen, Lights)
Switch Light_GF_Kitchen_Table “Table” (GF_Kitchen, Lights)
Switch Light_GF_Corridor_Wardrobe “Wardrobe” (GF_Corridor, Lights)
Switch Light_GF_Toilet_Ceiling “Ceiling” (GF_Toilet, Lights)
Switch Light_GF_Toilet_Mirror “Mirror” (GF_Toilet, Lights)
Switch Light_FF_Bath_Ceiling “Ceiling” (FF_Bath, Lights)
Switch Light_FF_Bath_Mirror “Mirror” (FF_Bath, Lights)
Switch Light_FF_Corridor_Ceiling “Corridor” (FF_Corridor, Lights)
Switch Light_FF_Office_Ceiling “Ceiling” (FF_Office, Lights) {wemo=“WeMoSwitch”}
Switch Light_FF_Child_Ceiling “Ceiling” (FF_Child, Lights)
Switch Light_FF_Bed_Ceiling “Ceiling” (FF_Bed, Lights)
Switch Light_C_Corridor_Ceiling “Ceiling” (gC, Lights)
Switch Light_C_Staircase “Staircase” (gC, Lights)
Switch Light_C_Washing_Ceiling “Washing” (gC, Lights)
Switch Light_C_Workshop “Workshop” (gC, Lights)
Switch Light_Outdoor_Garage “Garage” (Outdoor, Lights)
Switch Light_Outdoor_Terrace “Terrace” (Outdoor, Lights)
Switch Light_Outdoor_Frontdoor “Frontdoor” (Outdoor, Lights)
/* Heating */
Switch Heating_GF_Corridor “GF Corridor” (GF_Corridor, Heating)
Switch Heating_GF_Toilet “Toilet” (GF_Toilet, Heating)
Switch Heating_GF_Living “Livingroom” (GF_Living, Heating)
Switch Heating_GF_Kitchen “Kitchen” (GF_Kitchen, Heating)
Switch Heating_FF_Bath “Bath” (FF_Bath, Heating)
Switch Heating_FF_Office “Office” (FF_Office, Heating)
Switch Heating_FF_Child “Child’s Room” (FF_Child, Heating)
Switch Heating_FF_Bed “Bedroom” (FF_Bed, Heating)
/* Rollershutters */
Switch Shutter_all (Shutters)
Rollershutter Shutter_GF_Toilet “Toilet” (GF_Toilet, Shutters)
Rollershutter Shutter_GF_Kitchen “Kitchen” (GF_Kitchen, Shutters)
Rollershutter Shutter_GF_Living “Livingroom” (GF_Living, Shutters)
Rollershutter Shutter_FF_Bed “Bedroom” (FF_Bed, Shutters)
Rollershutter Shutter_FF_Bath “Bath” (FF_Bath, Shutters)
Rollershutter Shutter_FF_Office_Window “Office Window” (FF_Office, Shutters)
Rollershutter Shutter_FF_Office_Door “Office Door” (FF_Office, Shutters)
/* Indoor Temperatures */
Number Temperature_GF_Corridor “Temperature [%.1f °C]” (Temperature, GF_Corridor)
Number Temperature_GF_Toilet “Temperature [%.1f °C]” (Temperature, GF_Toilet)
Number Temperature_GF_Living “Temperature [%.1f °C]” (Temperature, GF_Living)
Number Temperature_GF_Kitchen “Temperature [%.1f °C]” (Temperature, GF_Kitchen)
Number Temperature_FF_Bath “Temperature [%.1f °C]” (Temperature, FF_Bath)
Number Temperature_FF_Office “Temperature [%.1f °C]” (Temperature, FF_Office)
Number Temperature_FF_Child “Temperature [%.1f °C]” (Temperature, FF_Child)
Number Temperature_FF_Bed “Temperature [%.1f °C]” (Temperature, FF_Bed)
/* Windows */
Contact Window_GF_Frontdoor “Frontdoor [MAP(en.map):%s]” (GF_Corridor, Windows)
Contact Window_GF_Kitchen “Kitchen [MAP(en.map):%s]” (GF_Kitchen, Windows)
Contact Window_GF_Living “Terrace door [MAP(en.map):%s]” (GF_Living, Windows)
Contact Window_GF_Toilet “Toilet [MAP(en.map):%s]” (GF_Toilet, Windows)
Contact Window_FF_Bath “Bath [MAP(en.map):%s]” (FF_Bath, Windows)
Contact Window_FF_Bed “Bedroom [MAP(en.map):%s]” (FF_Bed, Windows)
Contact Window_FF_Office_Window “Office Window [MAP(en.map):%s]” (FF_Office, Windows)
Contact Window_FF_Office_Door “Balcony Door [MAP(en.map):%s]” (FF_Office, Windows)
Contact Garage_Door “Garage Door [MAP(en.map):%s]” (Outdoor, Windows)
Group Weather_Chart (Weather)
Number Weather_Temperature “Outside Temperature [%.1f °C]” (Weather_Chart) { http="<[http://weather.yahooapis.com/forecastrss?w=638242&u=c:60000:XSLT(yahoo_weather_temperature.xsl)]" }
Number Weather_Humidity “Outside Humidity [%.1f %%]” (Weather) { http="<[http://weather.yahooapis.com/forecastrss?w=638242&u=c:60000:XSLT(yahoo_weather_humidity.xsl)]" }
Number Weather_Humidex “Humidex [SCALE(humidex.scale):%s]” (Weather)
Number Weather_Temp_Max “Todays Maximum [%.1f °C]” (Weather_Chart)
Number Weather_Temp_Min “Todays Minimum [%.1f °C]” (Weather_Chart)
Number Weather_Chart_Period "Chart Period"
DateTime Weather_LastUpdate “Last Update [%1$ta %1$tR]”
/* NTP binding demo item */
DateTime Date “Date [%1$tA, %1$td.%1$tm.%1$tY]” { ntp=“Europe/Berlin:de_DE” }
/* Demo items */
Switch DemoSwitch "Switch"
Dimmer DimmedLight “Dimmer [%d %%]”
Color RGBLight “RGB Light”
Rollershutter DemoShutter "Roller Shutter"
Dimmer DemoBlinds “Blinds [%d %%]”
Number Scene_General “Scene”
Number Radio_Station “Radio”
Dimmer Volume "Volume [%.1f %%]"
Number Temperature_Setpoint “Temperature [%.1f °C]”
String UnknownDevices “Unknown Devices in Range: [%s]” { bluetooth="?" }
Number NoOfPairedDevices “Paired Devices in Range: [%d]” { bluetooth="!" }
/* Locations */
Location DemoLocation “Brandenburg Gate Berlin”
