- Platform information:
- Hardware: x86 QNAO
- OS: linux
- Java Runtime Environment: 8 something
- openHAB version: 2.5.6
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration MANY
- Sitemap configuration FEW
- Rules code related MANY
Hello
I need some help - I could sort out a lot of errors listed in log
The only remaining error for the time beeing is
2020-12-09 19:19:48.866 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command '' not supported by type 'OnOffValue': No enum constant org.eclipse.smarthome.core.library.types.OnOffType.
2020-12-09 19:20:33.238 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command '' not supported by type 'OnOffValue': No enum constant org.eclipse.smarthome.core.library.types.OnOffType.
2020-12-09 19:20:51.557 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command '' not supported by type 'OnOffValue': No enum constant org.eclipse.smarthome.core.library.types.OnOffType.
2020-12-09 19:22:15.955 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command '' not supported by type 'OnOffValue': No enum constant org.eclipse.smarthome.core.library.types.OnOffType.
So in total I have about 25 sonoff items via MQTT running. Some with Senors
There are many rules to synchronize the .state to the switch.state
There are rules to trigger the items via alex
And there are sitemaps used on Iphone APP
So I need your help as after hours I still do not really know where is the problem
Is the warning a result of a .sendCommand() action
Or is the warning the result of a currently not connected device where a rule tries to set something
Here some examples of thing, item and rules
item:
Switch Hobbykeller_Switch "Hobbykeller " (gSONOFF_B8) { channel="mqtt:topic:63abe7ae:SONOFF_B8thg:PowerSwitch" }
Switch Hobbykeller_State "Hobbykeller State" (gSONOFF_B8) { channel="mqtt:topic:63abe7ae:SONOFF_B8thg:PowerSwitchRes"}
Number HobbykellerTemperatur "Hobbykeller Temp [%s °C]" (gSONOFF_B8info) { channel="mqtt:topic:63abe7ae:SONOFF_B8thg:Temperatur"}
Number HobbykellerHum "Hobbykeller Hum [%s]" (gSONOFF_B8info) { channel="mqtt:topic:63abe7ae:SONOFF_B8thg:Hum"}
String Hobbykeller_Uptime "Hobbykeller Uptime" (gSONOFF_B8Info) { channel="mqtt:topic:63abe7ae:SONOFF_B8thg:uptime" }
thing:
Thing topic SONOFF_B8thg "Hobbykeller Sonoff" @ "Keller" {
Channels:
Type switch : PowerSwitch "Power Switch" [ stateTopic="SONOFF_B8/cmnd/POWER", commandTopic="SONOFF_B8/cmnd/POWER", on="ON", off="OFF" ]
Type switch : PowerSwitchRes "Switch State" [ stateTopic="SONOFF_B8/tele/STATE", transformationPattern="JSONPATH:$.POWER",on="ON",off="OFF"]
Type number : Temperatur "Temperatur" [ stateTopic="SONOFF_B8/tele/SENSOR", transformationPattern="JSONPATH:$.AM2301.Temperature"]
Type number : Hum "Luftfeuchtigkeit" [ stateTopic="SONOFF_B8/tele/SENSOR", transformationPattern="JSONPATH:$.AM2301.Humidity"]
Type string : uptime "Uptime" [ stateTopic="SONOFF_B8/tele/STATE", transformationPattern="JSONPATH:$.Uptime" ]
rules: (example)
rule "Temp_Hobbykeller_Sonoff_Umbau"
Item HobbykellerTemperatur changed or
Item HobbykellerHum changed
Temp_Hobbykeller_Sonoff.postUpdate(HobbykellerTemperatur.state.toString +" °C " + String::format("%.0f", (HobbykellerHum.state as DecimalType).floatValue())+ " %")
other rule !!
if (Hobbykeller_State.state == ON) {Hobbykeller_Switch.state = ON}
if (Hobbykeller_State.state == OFF) {Hobbykeller_Switch.state = OFF}
So where do I have to look for to eliminate the warning in the log … ?
