aj1039
(aj1039)
#1
- Platform information:
- OS: Windows 10 Enterprise (64bit)
- Java Runtime Environment: Java Runtime Environment Version 8.0 Update 161 (32bit)
- openHAB version: 2.3.0 SNAPSHOT 2018-04-23
Start from a clean copy
Add zwave binding
The following warning logs every 5 seconds
events.log.XML (200 Bytes)
openhab.log.XML (8.3 KB)
Kai
(Kai Kreuzer)
#2
Thanks - could you please report a bug at https://github.com/eclipse/smarthome/issues?
zonegrise
(Gaston Boisvert)
#4
Same problem with OSx Sierra
KHOne
(KHONE)
#5
is there any solution or workaround?
Karsten
Kai
(Kai Kreuzer)
#6
Yes, see here - it has been fixed an hour ago and the fix will be included in tonights distro build.
KHOne
(KHONE)
#7
You are great
Thanks a lot
