Hi all,
not quiet shure if this is here the right place to notice.
I use “org.openhab.binding.zwave-2.5.13-SNAPSHOT.jar” (because of usiing devices that are not in normal binding.jar) in openhabian 1.6.2b openhab 2.5.12 and get this warning:
2021-02-11 16:39:29.596 [WARN ] [ig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/thing/thermofloor/z smoke_0_0.xml' in module 'org.openhab.binding.zwave' could not be parsed: The URI 'thing-type:zwave:thermofloor_z smoke_00_000' in node 'config-description' is invalid! : Illegal character in opaque part at index 30: thing-type:zwave:thermofloor_z smoke_00_000
---- Debugging information ----
message : The URI 'thing-type:zwave:thermofloor_z smoke_00_000' in node 'config-description' is invalid!
cause-exception : java.net.URISyntaxException
cause-message : Illegal character in opaque part at index 30: thing-type:zwave:thermofloor_z smoke_00_000
class : org.eclipse.smarthome.config.core.ConfigDescription
required-type : org.eclipse.smarthome.config.core.ConfigDescription
converter-type : org.eclipse.smarthome.config.xml.ConfigDescriptionConverter
path : /thing-descriptions/thing-type/config-description
line number : 71
class[1] : java.util.ArrayList
converter-type[1] : com.thoughtworks.xstream.converters.collections.CollectionConverter
class[2] : org.eclipse.smarthome.core.thing.xml.internal.ThingTypeXmlResult
converter-type[2] : org.eclipse.smarthome.core.thing.xml.internal.ThingTypeConverter
class[3] : org.eclipse.smarthome.core.thing.xml.internal.ThingDescriptionList
converter-type[3] : org.eclipse.smarthome.core.thing.xml.internal.ThingDescriptionConverter
version : not available
com.thoughtworks.xstream.converters.ConversionException: The URI 'thing-type:zwave:thermofloor_z smoke_00_000' in node 'config-description' is invalid! : Illegal character in opaque part at index 30: thing-type:zwave:thermofloor_z smoke_00_000
line number : 71
at org.eclipse.smarthome.config.xml.ConfigDescriptionConverter.unmarshal(ConfigDescriptionConverter.java:75) ~[?:?]
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:72) ~[bundleFile:?]
at com.thoughtworks.xstream.core.AbstractReferenceUnmarshaller.convert(AbstractReferenceUnmarshaller.java:65) ~[bundleFile:?]
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:66) ~[bundleFile:?]
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:50) ~[bundleFile:?]
at com.thoughtworks.xstream.converters.collections.AbstractCollectionConverter.readItem(AbstractCollectionConverter.java:71) ~[bundleFile:?]
at com.thoughtworks.xstream.converters.collections.CollectionConverter.addCurrentElementToCollection(CollectionConverter.java:98) ~[bundleFile:?]
at com.thoughtworks.xstream.converters.collections.CollectionConverter.populateCollection(CollectionConverter.java:91) ~[bundleFile:?]
at com.thoughtworks.xstream.converters.collections.CollectionConverter.populateCollection(CollectionConverter.java:85) ~[bundleFile:?]
at com.thoughtworks.xstream.converters.collections.CollectionConverter.unmarshal(CollectionConverter.java:80) ~[bundleFile:?]
at org.eclipse.smarthome.core.thing.xml.internal.AbstractDescriptionTypeConverter.unmarshal(AbstractDescriptionTypeConverter.java:190) ~[?:?]
at org.eclipse.smarthome.core.thing.xml.internal.ThingDescriptionConverter.unmarshal(ThingDescriptionConverter.java:53) ~[?:?]
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:134) ~[bundleFile:?]
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:32) ~[bundleFile:?]
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1185) ~[bundleFile:?]
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1169) ~[bundleFile:?]
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1115) ~[bundleFile:?]
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1062) ~[bundleFile:?]
at org.eclipse.smarthome.config.xml.util.XmlDocumentReader.readFromXML(XmlDocumentReader.java:85) ~[bundleFile:?]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.parseDocuments(XmlDocumentBundleTracker.java:411) [bundleFile:?]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.processBundle(XmlDocumentBundleTracker.java:398) [bundleFile:?]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.access$6(XmlDocumentBundleTracker.java:393) [bundleFile:?]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker$2.run(XmlDocumentBundleTracker.java:363) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: java.net.URISyntaxException: Illegal character in opaque part at index 30: thing-type:zwave:thermofloor_z smoke_00_000
at java.net.URI$Parser.fail(URI.java:2913) ~[?:?]
at java.net.URI$Parser.checkChars(URI.java:3084) ~[?:?]
at java.net.URI$Parser.parse(URI.java:3120) ~[?:?]
at java.net.URI.<init>(URI.java:600) ~[?:?]
at org.eclipse.smarthome.config.xml.ConfigDescriptionConverter.unmarshal(ConfigDescriptionConverter.java:73) ~[?:?]
... 49 more
I thing there is something not correct in this build.
Cheers
Stef
