I have trouble with one of my items. It is showing this when updating (but only sometimes, not every time):
2020-08-16 21:35:00.417 [WARN ] [pse.smarthome.core.items.GenericItem] - failed notifying listener 'org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@1d0118e' about state update of item OU_Backyard_AbsoluteHumidity: Can not compare incompatible units.
java.lang.IllegalArgumentException: Can not compare incompatible units.
at org.eclipse.smarthome.core.library.types.QuantityType.compareTo(QuantityType.java:174) ~[bundleFile:?]
at org.eclipse.smarthome.core.library.types.QuantityType.equals(QuantityType.java:156) ~[bundleFile:?]
at org.eclipse.smarthome.core.items.GenericItem$1.run(GenericItem.java:260) [bundleFile:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_265]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_265]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_265]
2020-08-16 21:35:00.417 [WARN ] [pse.smarthome.core.items.GenericItem] - failed notifying listener 'org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl@1bae282' about state update of item OU_Backyard_AbsoluteHumidity: Can not compare incompatible units.
2020-08-16 21:35:00.417 [WARN ] [pse.smarthome.core.items.GenericItem] - failed notifying listener 'OU_Backyard (Type=GroupItem, Members=14, State=NULL, Label=Hinterhof, Category=garage, Tags=[Garden], Groups=[Home, OU])' about state update of item OU_Backyard_AbsoluteHumidity: Can not compare incompatible units.
2020-08-16 21:40:00.402 [WARN ] [pse.smarthome.core.items.GenericItem] - failed notifying listener 'org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@1d0118e' about state update of item OU_Backyard_AbsoluteHumidity: Unable to convert to system unit during compare.
java.lang.IllegalArgumentException: Unable to convert to system unit during compare.
at org.eclipse.smarthome.core.library.types.QuantityType.compareTo(QuantityType.java:171) ~[bundleFile:?]
I already deleted the persisted data in influxdb because I thought there was a problem with units.
This is the item:
As a workaround I commented the item and rebooted. After that I uncommented leaving the groups still commented. After an hour seeing now errors i uncommented the groups. So far everything is running again. Thanks!
Hi all!
I have the same problem now in OH3!
I didn’t create any .persist files jet (complete new installation) and every other item is persisting just fine (influxdb)…
2021-01-19 10:54:26.861 [WARN ] [org.openhab.core.items.GenericItem ] - failed notifying listener 'org.openhab.core.persistence.internal.PersistenceManagerImpl@1f40ff2' about state update of item ESPA0_Office2Humidity: newPosition > limit: (83916 > 8192)
java.lang.IllegalArgumentException: newPosition > limit: (83916 > 8192)
at java.nio.Buffer.createPositionException(Buffer.java:318) ~[?:?]
at java.nio.Buffer.position(Buffer.java:293) ~[?:?]
at java.nio.ByteBuffer.position(ByteBuffer.java:1086) ~[?:?]
at java.nio.MappedByteBuffer.position(MappedByteBuffer.java:226) ~[?:?]
at java.nio.MappedByteBuffer.position(MappedByteBuffer.java:67) ~[?:?]
at org.rrd4j.core.RrdNioBackend.read(RrdNioBackend.java:172) ~[?:?]
at org.rrd4j.core.RrdBackend.readInt(RrdBackend.java:270) ~[?:?]
at org.rrd4j.core.RrdPrimitive.readInt(RrdPrimitive.java:38) ~[?:?]
at org.rrd4j.core.RrdInt.get(RrdInt.java:35) ~[?:?]
at org.rrd4j.core.Archive.<init>(Archive.java:45) ~[?:?]
at org.rrd4j.core.RrdDb.<init>(RrdDb.java:290) ~[?:?]
at org.rrd4j.core.RrdDb.<init>(RrdDb.java:204) ~[?:?]
at org.rrd4j.core.RrdDb.<init>(RrdDb.java:233) ~[?:?]
at org.openhab.persistence.rrd4j.internal.RRD4jPersistenceService.getDB(RRD4jPersistenceService.java:322) ~[?:?]
at org.openhab.persistence.rrd4j.internal.RRD4jPersistenceService.store(RRD4jPersistenceService.java:140) ~[?:?]
at org.openhab.core.persistence.internal.PersistenceManagerImpl.handleStateEvent(PersistenceManagerImpl.java:152) ~[?:?]
at org.openhab.core.persistence.internal.PersistenceManagerImpl.stateChanged(PersistenceManagerImpl.java:473) ~[?:?]
at org.openhab.core.items.GenericItem.lambda$1(GenericItem.java:259) [bundleFile:?]
2021-01-23 19:51:25.560 [WARN ] [org.openhab.core.items.GenericItem ] - failed notifying listener 'org.openhab.core.persistence.internal.PersistenceManagerImpl@1aa7cd1' about state update of item SensorPower1: newPosition > limit: (83916 > 36864)
java.lang.IllegalArgumentException: newPosition > limit: (83916 > 36864)
I have also other items generating the same WARN message.
It seems there is relation with a file permission issue, because al these items also had a ‘Permission denied’ error in the openhab.log file.
openhab.log:2021-01-23 17:28:53.170 [ERROR] [d4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file '/var/lib/openhab/persistence/rrd4j/SensorPower1.rrd': /var/lib/openhab/persistence/rrd4j/SensorPower1.rrd (Permission denied)
-rw------- 1 root root 36K Jan 16 17:19 SensorPower1.rrd
I changed the permissions and owner to 644 and openhab.openhab just like the other item files.
I seem to have the same problem, but I can’t find any *.rrd file on my openhabian installation. Search for it in the entie system, can you give me an idea where to find it (maybe it was renamed - I’m using the latest OH3 release).
I assume if you don’t find *.rrd files in /var/lib/openhab/persistence/rrd4j that you haven’t configured RRD4j as the persistance ‘layer’. You can check this in the web GUI: Settings → System Services → Persistance.
If it is, i’m unable to help you further with this.
