- Platform information:
- Hardware: Raspberry Pi 3B+
- OS: OpenHabian 2.4 stable
- Issue of the topic:
While using the Openhabian-Config, “Upgrade System” utility, I received the following auto-generated e-mail while the update was running:
cron (3.0pl1-127+deb8u2) jessie-security; urgency=medium
* As a reasonable protective measure, crontabs are now limited to 1000 lines
in length per crontab.
The maintainers find it very unlikely that longer crontabs exist; however,
if you do have a use case, please file a bug report with a brief rationale,
and we will consider raising this limit.
-- Christian Kastner <ckk@debian.org> Sun, 10 Mar 2019 17:44:13 +0100
I have very few rules in Openhab that runs on a cron trigger, but I don’t think this is the cause. Can someone explain what this means and what I can do to correct it? I have never heard of crontabs before, but have done some quick research, and when I tried to list the crontab (crontab -l)I get:
no crontab for openhabian
System seems to be running as it should, so I am not sure what is going on here. Any help is appreciated.
Thanks,
~John
