- Platform information:
- Hardware: x86
- OS: Proxmox with Openhabian Linux
- Java Runtime Environment: the One in Openhabian
- openHAB version: 4.1.2
- Issue of the topic:
In the log I receive the following warnings:
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.powerdc4', serviceName='JSONPATH'} failed: Invalid path '$.result.powerdc4' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.powerdc2', serviceName='JSONPATH'} failed: Invalid path '$.result.powerdc2' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.sn', serviceName='JSONPATH'} failed: Invalid path '$.result.sn' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.powerdc1', serviceName='JSONPATH'} failed: Invalid path '$.result.powerdc1' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.feedinenergy', serviceName='JSONPATH'} failed: Invalid path '$.result.feedinenergy' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.inverterStatus', serviceName='JSONPATH'} failed: Invalid path '$.result.inverterStatus' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.yieldtoday', serviceName='JSONPATH'} failed: Invalid path '$.result.yieldtoday' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.inverterType', serviceName='JSONPATH'} failed: Invalid path '$.result.inverterType' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.uploadTime', serviceName='JSONPATH'} failed: Invalid path '$.result.uploadTime' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.feedinpower', serviceName='JSONPATH'} failed: Invalid path '$.result.feedinpower' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.acpower', serviceName='JSONPATH'} failed: Invalid path '$.result.acpower' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.peps2', serviceName='JSONPATH'} failed: Invalid path '$.result.peps2' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.powerdc3', serviceName='JSONPATH'} failed: Invalid path '$.result.powerdc3' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.soc', serviceName='JSONPATH'} failed: Invalid path '$.result.soc' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.yieldtotal', serviceName='JSONPATH'} failed: Invalid path '$.result.yieldtotal' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.141 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.feedinpowerM2', serviceName='JSONPATH'} failed: Invalid path '$.result.feedinpowerM2' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.142 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.batPower', serviceName='JSONPATH'} failed: Invalid path '$.result.batPower' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.142 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.consumeenergy', serviceName='JSONPATH'} failed: Invalid path '$.result.consumeenergy' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.142 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.peps1', serviceName='JSONPATH'} failed: Invalid path '$.result.peps1' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.142 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.result.peps3', serviceName='JSONPATH'} failed: Invalid path '$.result.peps3' in '{"exception":"There have been several violations in a row, and the system will prohibit calls within the next hour","code":1,"tokenId":"20240516190825463358954","success":false}'
2024-10-04 08:54:57.223 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '-8 kWh' with function '$.Haus.Power_curr' and format '%s'
The code for the last warning is:
UID: mqtt:topic:8ab148a10c:ba2c88ef65
label: AAAA_Stromzähler
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:8ab148a10c
channels:
- id: tele_Stromzaehler_total
channelTypeUID: mqtt:number
label: tele_Stromzaehler_total
description: ""
configuration:
formatBeforePublish: "%d"
stateTopic: tele/Stromzaehler/SENSOR
transformationPattern: jsonpath:$.Haus.Total_in
- id: tele_Stromzaehler_out_total
label: tele_Stromzaehler_out_total
description: ""
configuration:
transformationPattern: jsonpath:$.Haus.Total_out
- id: tele_Stromzaehler_SENSOR
label: tele_Stromzaehler_SENSOR
description: ""
configuration:
unit: kWh
transformationPattern: JSONPATH:$.Haus.Power_curr
And for the first warnings here are the things and the items file:
things:
Thing http:url:solax "Solax inverter" [
// baseURL="https://www.eu.solaxcloud.com:9443/proxy/api/getRealtimeInfo.do?tokenId=YOUR_TOKEN_ID&sn=YOUR_SERIAL_NUMBER",
baseURL="https://eu.solaxcloud.com/proxyApp/proxy/api/getRealtimeInfo.do?tokenId=........&sn=......",
refresh=10] {
Channels:
Type string : sn "Serial Number" [stateTransformation="JSONPATH:$.result.sn"]
Type number : acpower "AC Power" [stateTransformation="JSONPATH:$.result.acpower"]
// Type number : powerdc1 "DC Power" [ stateTransformation="JSONPATH:$.result.powerdc1" ]
Type number : yieldtoday "Yield Today" [ stateTransformation="JSONPATH:$.result.yieldtoday" ]
Type number : yieldtotal "Yield Total" [ stateTransformation="JSONPATH:$.result.yieldtotal" ]
Type number : feedinpower "Feed In Power" [ stateTransformation="JSONPATH:$.result.feedinpower" ]
Type number : feedinenergy "Feed In Energy" [ stateTransformation="JSONPATH:$.result.feedinenergy" ]
Type number : consumeenergy "Feed In Energy" [ stateTransformation="JSONPATH:$.result.consumeenergy" ]
Type number : feedinpowerm2 "Inverter.Meter2.AC.power.total" [ stateTransformation="JSONPATH:$.result.feedinpowerM2" ]
Type number : soc "Battery Charge" [ stateTransformation="JSONPATH:$.result.soc" ]
Type number : peps1 "Inverter.AC.EPS.power.R" [ stateTransformation="JSONPATH:$.result.peps1" ]
Type number : peps2 "Inverter.AC.EPS.power.S" [ stateTransformation="JSONPATH:$.result.peps2" ]
Type number : peps3 "Inverter.AC.EPS.power.T" [ stateTransformation="JSONPATH:$.result.peps3" ]
Type number : inverterType "Iverter Type" [ stateTransformation="JSONPATH:$.result.inverterType" ]
Type number : inverterStatus "Iverter Status" [ stateTransformation="JSONPATH:$.result.inverterStatus" ]
Type string : uploadTime "Last data" [ stateTransformation="JSONPATH:$.result.uploadTime" ]
Type number : batPower "Battery power" [ stateTransformation="JSONPATH:$.result.batPower" ]
Type number : powerdc1 "Inverter.DC.PV.power.MPPT1" [ stateTransformation="JSONPATH:$.result.powerdc1" ]
Type number : powerdc2 "Inverter.DC.PV.power.MPPT2" [ stateTransformation="JSONPATH:$.result.powerdc2" ]
Type number : powerdc3 "Inverter.DC.PV.power.MPPT3" [ stateTransformation="JSONPATH:$.result.powerdc3" ]
Type number : powerdc4 "Inverter.DC.PV.power.MPPT4" [ stateTransformation="JSONPATH:$.result.powerdc4" ]
Group gsolax_inverter "Solax Cloud"
String solax_sn "Seriennummer [%s]" (gsolax_inverter) { channel="http:url:solax:sn" }
// Number sol+ax_powerdc1 "Herstellung von Platten [%.0f W]" (gsolax_inverter){ channel="http:url:solax:powerdc1" }
Number:Power solax_batPower "Entnahme aus der Batterie [%.0f W]" (gsolax_inverter) {unit="W", channel="http:url:solax:batPower" }
Number:Power solax_feedinpower "Entnahme aus dem Netz [%.0f W]" (gsolax_inverter) {unit="W", channel="http:url:solax:feedinpower" }
Number:Energy solax_consumeenergy "Hausverbrauch [%.0f kWh]" (gsolax_inverter) {unit="kWh", channel="http:url:solax:consumeenergy" }
Number:Dimensionless solax_soc "Akku-Ladung [%.0f %%]" (gsolax_inverter) {unit="%", channel="http:url:solax:soc" }
Number:Energy solax_yieldtoday "Tägliche Produktion [%.0f kWh]" (gsolax_inverter){unit="kWh", channel="http:url:solax:yieldtoday" }
Number:Energy solax_yieldtotal "Gesamtproduktion [%.0f kWh]" (gsolax_inverter) {unit="kWh", channel="http:url:solax:yieldtotal" }
Number:Power solax_acpower "Energie im Konverter [%.0f W]" (gsolax_inverter){unit="W", channel="http:url:solax:acpower" }
Number:Energy solax_feedinenergy "Einspeisestrom [%.0f kWh]" (gsolax_inverter) {unit="kWh", channel="http:url:solax:feedinenergy" }
String solax_uploadTime "Aktuelle Termine [%s]" (gsolax_inverter) { channel="http:url:solax:uploadTime" }
Number:Dimensionless solax_inverterType "Inverter Typ [MAP(Solax.map):%s]" (gsolax_inverter) { channel="http:url:solax:inverterType"}
Number:Dimensionless solax_inverterStatus "Inverter Status [MAP(Solax.map):%s]" (gsolax_inverter) { channel="http:url:solax:inverterStatus" }
Number:Power solax_feedinpowerm2 "Inverter.Meter2.AC.power.total [%.0f W]" (gsolax_inverter) {unit="W", channel="http:url:solax:feedinpowerM2" }
Number:Power solax_peps1 "Inverter.AC.EPS.power.R [%.0f W]" (gsolax_inverter) {unit="W", channel="http:url:solax:peps1" }
Number:Power solax_peps2 "Inverter.AC.EPS.power.S [%.0f W]" (gsolax_inverter) {unit="W", channel="http:url:solax:peps2" }
Number:Power solax_peps3 "Inverter.AC.EPS.power.T [%.0f W]" (gsolax_inverter) {unit="W", channel="http:url:solax:peps3" }
Number:Power solax_powerdc1 "Inverter.DC.PV.power.MPPT1 [%.0f W]" (gsolax_inverter) {unit="W", channel="http:url:solax:powerdc1" }
Number:Power solax_powerdc2 "Inverter.DC.PV.power.MPPT2 [%.0f W]" (gsolax_inverter) {unit="W", channel="http:url:solax:powerdc2" }
// Number solax_powerdc3 "Inverter.DC.PV.power.MPPT3 [%.0f W]" (gsolax_inverter) { channel="http:url:solax:powerdc3" }
// Number solax_powerdc4 "Inverter.DC.PV.power.MPPT4 [%.0f W]" (gsolax_inverter) { channel="http:url:solax:powerdc4" }
Does anybody could help me with an hint how to remove these warnings.
Many thanks in advanced,
Andreas
