Dear Community,
I can see that there is the option in the Java Console to watch the Debug logs in the Eclipse IDE. Anyway is there are chance to configure this output - sometimes I want to print some log outputs, but it is hard to follow the logs, because there are so many lines, after installing the ‘Standard’-environment.
By the way, is there a chance to add the 9001-port for the logfiles like in the productive system environment? Thanks in advance.
Best regards,
Jochen
