buedy have you opened your config in openhab designer? It does a reasonably good job at picking up and highlighting errors in your config
Hello
Yes, I do all my configs with the openhab designer. There are no errors.
Hi there,
since yesterday I quite often started to receive such error with Yahoo Weather Binding:
CommonId not found: CommonIdHandler[provider=YAHOO,id=<null>,icon=<null>]
And temperature is not updated. Am I the only one? What could be the reason?
Same here.
Same here.
Hre are the logs I can find with the weather binding since the 5th of November (OH2 snapshot 554):
2016-11-07 07:49:22.691 [WARN ] [ther.internal.parser.CommonIdHandler] - CommonId not found: CommonIdHandler[provider=WUNDERGROUND,id=<null>,icon=<null>]
2016-11-07 07:49:22.707 [WARN ] [eather.internal.bus.WeatherPublisher] - Weather forecast day 0 not available for locationId 'home', only 0 available
2016-11-07 07:49:22.717 [WARN ] [eather.internal.bus.WeatherPublisher] - Weather forecast day 0 not available for locationId 'home', only 0 available
2016-11-07 07:49:22.722 [WARN ] [eather.internal.bus.WeatherPublisher] - Weather forecast day 0 not available for locationId 'home', only 0 available
2016-11-09 03:19:27.673 [WARN ] [ther.internal.parser.CommonIdHandler] - CommonId not found: CommonIdHandler[provider=WUNDERGROUND,id=<null>,icon=<null>]
2016-11-09 03:19:27.692 [WARN ] [eather.internal.bus.WeatherPublisher] - Weather forecast day 0 not available for locationId 'home', only 0 available
2016-11-09 03:19:27.699 [WARN ] [eather.internal.bus.WeatherPublisher] - Weather forecast day 0 not available for locationId 'home', only 0 available
2016-11-09 03:19:27.706 [WARN ] [eather.internal.bus.WeatherPublisher] - Weather forecast day 0 not available for locationId 'home', only 0 available
2016-11-09 22:19:32.119 [ERROR] [nal.provider.AbstractWeatherProvider] - WUNDERGROUND[home]: Can't retreive weather data: HTTP/1.0 504 Gateway Time-out
2016-11-09 22:19:32.127 [WARN ] [eather.internal.bus.WeatherPublisher] - Weather forecast day 0 not available for locationId 'home', only 0 available
2016-11-09 22:19:32.142 [WARN ] [eather.internal.bus.WeatherPublisher] - Weather forecast day 0 not available for locationId 'home', only 0 available
2016-11-09 22:19:32.147 [WARN ] [eather.internal.bus.WeatherPublisher] - Weather forecast day 0 not available for locationId 'home', only 0 available
It looks like the error only occured sometimes.
Same here ā¦
Iām getting the same error. Works sometimes, then stops, then restarts. Even without restarting OH. Any ideas out there? Using Yahoo.
Hi All! Same problem hereā¦
Does anyone have a solution??
2017-01-22 14:08:57.876 [WARN ] [o.b.w.i.parser.CommonIdHandler] - CommonId not found: CommonIdHandler[provider=YAHOO,id=,icon=]
same problem here!
Why?
Can anyone help us with this intermittent problem? Is there something we can do like extending the timeout on weather service or suchlike?
Same goes for me!
I have noticed that it works some times but not most of the time it failsā¦
Iām on build #743 using open-weather-map with no problems to be observed!
Same here.
2017-01-24 17:05:29.098 [WARN ] [o.b.w.i.parser.CommonIdHandler] - CommonId not
at the and I migrate to the new OH 2 also for that problem!
it is some days that seems to work?
in my log file there are not āWARNā about Yahoo
Yes, my yahoo weather has worked better the last few days as well.
