Trying to set up weather binding.
Configuration is as follow:
weather.cfg
# The apikey for the different weather providers, at least one must be specified
# Note: Hamweather requires two apikeys: client_id=apikey, client_secret=apikey2
#apikey.ForecastIo=
weather:apikey.OpenWeatherMap=real api key
#apikey.WorldWeatherOnline=
#apikey.Wunderground=
#apikey.Hamweather=
#apikey2.Hamweather=
#apikey.Meteoblue=
#location.<wkelzenberg>.name=Kelzenberg
weather:location.<wkelzenberg>.latitude=51.099098
weather:location.<wkelzenberg>.longitude=6.5095
#location.<wkelzenberg>.woeid=6553038
weather:location.<wkelzenberg>.provider=OpenWeatherMap
weather:location.<wkelzenberg>.language=en
weather:location.<wkelzenberg>.updateInterval=1
But I can’t get it running. The binding is not gathering any data.
If I trace the installation of the binding, I see the following log incl. an error:
23:15:44.546 [DEBUG] [org.openhab.binding.weather ] - BundleEvent INSTALLED - org.openhab.binding.weather
23:15:44.967 [DEBUG] [org.openhab.binding.weather ] - BundleEvent RESOLVED - org.openhab.binding.weather
23:15:47.012 [DEBUG] [org.openhab.binding.weather ] - BundleEvent STARTING - org.openhab.binding.weather
23:15:47.165 [DEBUG] [weather.internal.bus.WeatherActivator] - Weather binding has been started.
23:15:47.265 [DEBUG] [org.openhab.binding.weather ] - BundleEvent STARTED - org.openhab.binding.weather
23:15:47.564 [DEBUG] [nal.bus.WeatherGenericBindingProvider] - Adding item Humidity with WeatherBindingConfig[locationId=wkelzenberg,type=atmosphere,property=humidity,roundingMode=HALF_UP,scale=2]
23:15:47.945 [DEBUG] [nal.bus.WeatherGenericBindingProvider] - Adding item Visibility with WeatherBindingConfig[locationId=wkelzenberg,type=atmosphere,property=visibility,roundingMode=HALF_UP,scale=2]
23:15:48.328 [DEBUG] [nal.bus.WeatherGenericBindingProvider] - Adding item Pressure with WeatherBindingConfig[locationId=wkelzenberg,type=atmosphere,property=pressure,roundingMode=HALF_UP,scale=2]
23:15:48.702 [DEBUG] [nal.bus.WeatherGenericBindingProvider] - Adding item Pressure_Trend with WeatherBindingConfig[locationId=wkelzenberg,type=atmosphere,property=pressureTrend]
23:15:49.918 [DEBUG] [nal.bus.WeatherGenericBindingProvider] - Adding item Ozone with WeatherBindingConfig[locationId=wkelzenberg,type=atmosphere,property=ozone,roundingMode=HALF_UP,scale=2]
Removed more details, otherwise I would extend the lenght of this post]
23:16:17.125 [TRACE] [her.internal.metadata.MetadataHandler] - Added provider mapping METEOBLUE: ProviderMappingInfo[source=last_model_update,target=condition.observationTime,converter=JSON_DATE]
23:16:17.790 [ERROR] [org.openhab.binding.weather ] - FrameworkEvent ERROR - org.openhab.binding.weather
org.osgi.framework.ServiceException: Exception in org.apache.felix.scr.impl.manager.SingleComponentManager.getService()
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:222) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) ~[?:?]
at org.apache.felix.metatype.internal.ManagedServiceTracker.addingService(ManagedServiceTracker.java:52) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:291) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) ~[?:?]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) ~[?:?]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) ~[?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1361) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:888) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1248) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$1(FeaturesServiceImpl.java:1147) ~[?:?]
Caused by: java.lang.IllegalStateException: Could not obtain lock
at org.apache.felix.scr.impl.manager.AbstractComponentManager.obtainLock(AbstractComponentManager.java:231) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.obtainStateLock(AbstractComponentManager.java:279) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.ungetService(SingleComponentManager.java:934) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:846) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) ~[?:?]
... 79 more
23:16:23.384 [DEBUG] [g.weather.internal.gfx.WeatherServlet] - Starting up weather servlet at /weather
23:16:17.865 [TRACE] [her.internal.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=weather.id,target=condition.id,converter=STRING]
23:16:25.111 [DEBUG] [org.openhab.binding.weather ] - ServiceEvent REGISTERED - {javax.servlet.ServletContext}={osgi.web.symbolicname=org.openhab.binding.weather, osgi.web.version=1.11.0, osgi.web.contextname=custom, osgi.web.contextpath=/, service.id=369, service.bundleid=231, service.scope=singleton} - org.openhab.binding.weather
23:16:24.803 [ERROR] [org.openhab.binding.weather ] - FrameworkEvent ERROR - org.openhab.binding.weather
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:806) ~[?:?]
... 79 more
23:16:30.750 [WARN ] [core.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@130a888' takes more than 5000ms.
23:16:25.743 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'binding-weather1' has been installed.
: query.results.channel.item.forecast
[Removed more details, otherwise I would extend the lenght of this post]
23:16:56.123 [DEBUG] [weather.internal.common.WeatherConfig] - Parsing of weather configuration settings completed.
23:16:56.217 [INFO ] [weather.internal.common.WeatherConfig] - ProviderConfig[providerName=OPENWEATHERMAP,apiKey=real api key]
23:16:56.332 [INFO ] [weather.internal.common.WeatherConfig] - LocationConfig[providerName=OPENWEATHERMAP,language=en,updateInterval=1,latitude=51.099098,longitude=6.5095,woeid=<null>,locationId=<wkelzenberg>,name=Kelzenberg]
Except for the errors, all seems to be setup correctly.
I searched for error, but I couldn’t find an answer which helped.
Any ideas?
