if i try to bind weather i get some errors in openhab.log:
[ERROR] [org.openhab.binding.weather] - [org.openhab.binding.weather(171)] bind method [addBindingProvider] not found; Component will fail
It seems to installed anyway:
[INFO ] [smarthome.event.ExtensionEvent ] - Extension ‘binding-weather’ has been installed.
but it cant see it in ‘paper ui’ under configuration - bindings and if i try to configure it like 1.x i get
[INFO ] [ternal.scheduler.WeatherJobScheduler] - Disabling weather locationId ‘locationId1’, no binding available
Is it my fault or a problem with openhab2?
Regards
