Hi
Could you tell me how to do this, i think im moving into unknown territory
Hi
logInfo("test", now.plusDays(1).dayOfWeek)
Is this right?
2016-10-31 00:54:00.326 [ERROR] [.o.m.r.i.engine.ExecuteRuleJob] - Error during the execution of rule Update days of the week
java.lang.RuntimeException: The name â.plusDays()â cannot be resolved to an item or type.
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:67) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateMemberFeatureCall(XbaseInterpreter.java:549) ~[na:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_111]
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[na:1.8.0_111]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[na:1.8.0_111]
at java.lang.reflect.Method.invoke(Unknown Source) ~[na:1.8.0_111]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateMemberFeatureCall(XbaseInterpreter.java:545) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:751) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:712) ~[na:na]
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na]
at org.openhab.model.rule.internal.engine.ExecuteRuleJob.execute(ExecuteRuleJob.java:55) ~[na:na]
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [quartz-all-2.1.7.jar:na]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557) [quartz-all-2.1.7.jar:na]
Forecast1Text.postUpdate(now.plusDays(1).toString + " " +Forecast1Condition.state.toString+ " " +Forecast1TempMin.state.toString+" °C bis "+Forecast1TempMax.state.toString+" °C" )
displays
2018-03-07T16:49:41.497+01:00 Regen möglich 1 °C bis 8 °C
However, I would like:
Dienstag Regen möglich 1 °C bis 8 °C
or
Tuesday Regen möglich 1 °C bis 8 °C
Does anyone know what I am instead of
should usually write?
Thanks a lot.
Probably wouldâve been better to start a new thread for this.
However, youâd probably want something like:
String::format("%1$tA", now.plusDays(1))
See the formatter docs for more conversion possibilities.
