I’ve been trying to get the weather binding to work, but have been unable to get it to work with any type of config I throw at it. This is my current config for ForecastIo and I’m not quite sure why it doesn’t work.
I’m using OpenHAB 2.0-SNAPSHOT.
Errors:
2016-09-02 07:38:37.305 [WARN ] [eather.internal.common.WeatherConfig] - Incomplete location config for locationId '<locationId1>'. Check openhab.cfg.
2016-09-02 07:38:37.308 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler, id=330, bundle=208/mvn:org.openhab.binding/org.openhab.binding.weather/1.9.0-SNAPSHOT]: Updating property weather of configuration org.openhab.weather caused a problem: Incomplete location config for locationId '<locationId1>'. Check openhab.cfg.
org.osgi.service.cm.ConfigurationException: weather : Incomplete location config for locationId '<locationId1>'. Check openhab.cfg.
at org.openhab.binding.weather.internal.common.WeatherConfig.parse(WeatherConfig.java:97)[208:org.openhab.binding.weather:1.9.0.201608310111]
at org.openhab.binding.weather.internal.bus.WeatherBinding.updated(WeatherBinding.java:82)[208:org.openhab.binding.weather:1.9.0.201608310111]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1444)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1400)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:143)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:110)[7:org.apache.felix.configadmin:1.8.8]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_101]
Config(services/weather.cfg):
apikey.ForecastIo=b9702cxxxxxcb91b4c30ec48exxxxxxx
#apikey.OpenWeatherMap=
#apikey.WorldWeatherOnline=
#apikey.Wunderground=
#apikey.Hamweather=
#apikey2.Hamweather=
#apikey.Meteoblue=
# location configuration, you can specify multiple locations
location.home.name=Home
location.home.provider=ForecastIo
location.home.language=en
location.home.updateInterval=10
location.home.latitude=33.8665
location.home.longitude=-84.3383
#location.<locationId2>.name=
#location.<locationId2>.latitude= (not required for Yahoo provider)
#location.<locationId2>.longitude= (not required for Yahoo provider)
#location.<locationId2>.woeid= (required for Yahoo provider)
#location.<locationId2>.provider=
#location.<locationId2>.language=
#location.<locationId2>.updateInterval=
Second, the log referres to a “locationId1” which normally is the demo entry in the cfg file. Just make sure that there aren’t any entries left with this id (as “home” is your actual id).
Third (if everything above doesn’t solve your problem), try using another locationID. I’ve had similar problems and somewhere around here in the forum someone told me that the id “home” is some kind of reserved for the yahoo provider. I just changed my ID to home2 and everything worked. I would suggest only to try this if the other corrections don’t get a working binding.
Ah, wait a second: I have just seen you are using OH2. My hints are related to an OH1 installation, so no guarantee that this is valid for OH2.
Thanks for the ideas. Sadly none of those ideas worked. I do agree with you that it’s quite weird for the <locationId1> to be in the error log. It looks like OpenHAB2 is reading a demo configuration file instead of the one in the services folder. I think I might report this as a bug.
I too can’t seem to get the weather binding working on OpenHAB 2.0=SNAPHOT.
Here’s my setup:
/services/weather.cfg:
# The apikey for the different weather providers, at least one must be specified
# Note: Hamweather requires two apikeys: client_id=apikey, client_secret=apikey2
#apikey.ForecastIo=
weather:apikey.Wunderground=7xxxc80xxx588xxx
#apikey.Hamweather=
weather:location.myhome.name=My House
weather:location.myhome.latitude=-34.10413
weather:location.myhome.longitude=-18.36039
weather:locationd.myhome.provider=Wunderground
weather:location.myhome.language=en
weather:location.myhome.updateInterval=10
,items setup: (just a few, I copied the whole thing from the wiki
// temperature
Number Temperature "Outside Temperature [%.0f °C]" <temperature> {weather="locationId=myhome, type=temperature, property=current"}
Number Humidity "Humidity [%d %%]" weather="locationId=myhome, type=atmosphere, property=humidity"}
and my .sitemap:
Frame label="Weather" {
Text item=Temperature valuecolor=[>25="orange",>15="green",<=15="blue"]{
I’m not sure where to extract the log though, so if you can point me in that direction I’ll gladly post it here to see if it’s the same issue. I also don’t know where my openhab.cfg file is.
Of course I’ll come back and post here if I figure it out, but I’ve been trying for a while now and still no joy.
Edit: Is the log you posted coming from the OpenHAB2 Eclipse IDE when you run the configuration? If so I’ll try get my instance running through the IDE (though it’s probably a bit too advanced for me at the moment!) A pointer would be welcome though… would I clone a local copy of my site to my PC and set up Eclipse to load it? My OH2 is currently on my Raspberry Pi. I’ll start with the IDE setup guide I guess
@Udo_Hartmann I’ve followed your format given in your post. And I’m still getting the errors I posted above. Doesn’t it look weird that the error has <locationId1> in it, yet that doesn’t exist in the file it’s supposed to parse?
I found in the map config/org/openhab a (back up ?) file called "weather.config"
In the map are the old configurations which seems to caused the problem with the weather binding.
But i cant change it, its protected…
Update: I managed to get thinks working by deleting all old “stuff” in the file.
So I had this same issue it something was being held in memory. Basically I had a bad config but it would not go away. I had to stop OH and delete everything in /var/lib/openhab2/config/org/openhab/weather.config before starting it again. This is with OH2, hope this helps someone.
Clearing the incorrect entries in the /var/lib/openhab2/config/org/openhab helped me fix a lot of the services that were previous breaking. These files not getting properly updated when changes are made to the services/.cfg files is a bit of a bug
