Still plugging away at this guys…
I’ve must have missed something fundamental about how the weather binding works as I’ve done a test with a garbage weather.cfg file and it makes no difference in what appears in Basic UI.
When I correctly link the Temperature item it returns the correct value (always true to what Google says)
Number Temperature "Temperature [%.0f °C]" <temperature> {weather="locationId=myhome, type=temperature, property=current"}
Then I try to retrieve the min and max values, but these have never worked…
Number Temp_Min "Temperature min [%.0f °C]" <temperature> {weather="locationId=myhome, type=temperature, property=min"}
Number Temp_Max "Temperature max [%.0f °C]" <temperature> {weather="locationId=myhome, type=temperature, property=max"}
So I’m wondering if maybe OH2 is retrieving the temperature internally? I’ve looked all over but can’t seem to find anything.
My sitemap:
Frame label="Weather" {
Text item=Temperature valuecolor=[>25="orange",>15="green",<=15="blue"]{
Frame {
Text item=Temp_Max valuecolor=[>25="orange",>15="green",>5="orange",<=5="blue"]
Text item=Temp_Min valuecolor=[>25="orange",>15="green",>5="orange",<=5="blue"]
Please be aware that while I have the weather binding installed in Paper UI, it does not show up is a ‘thing’ in my inbox. Maybe it’s not properly installed? I wouldn’t know how to check, though I still get my 17deg.
Open to any advice guys…
