So I have the Lat/Long set for my house in the Weather binding but the temperature coming back from WUnderground is not the same as the close weather stations when I look at their website or in my Vera install which is using the same API Key? The Weather binding is returning temperatures 5-6 degrees higher. I have to look at weather stations 10 miles or so south to see similar readings.
[Update] Nevermind, I found the station it must be pulling from. Making slight changes to the Lat/Long moved it to another station.
