Hi, the log is below.The client is connected to internet, wget is working, xmpp is working, I have no specific security rules in my network. I’ve removed Date to squeeze log and keep it in one post. Log:
19:05:03.990 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.7.1).
19:05:10.779 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
19:05:11.007 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
19:05:21.508 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘galactica.sitemap’
19:05:24.698 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘db4o.persist’
19:05:25.376 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘exec.persist’
19:05:25.414 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘logging.persist’
19:05:25.463 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘rrd4j.persist’
19:05:25.664 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘greent.items’
19:05:25.892 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘weather.items’
19:05:26.003 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘galactica.items’
19:05:29.649 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
19:05:35.344 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /openhab.app
19:05:42.275 [INFO ] [.service.AbstractActiveService] - Modbus Polling Service has been started
19:05:42.332 [INFO ] [t.AbstractSocketChannelBinding] - The maximum buffer will be set to the default value of 1024
19:05:42.334 [INFO ] [t.AbstractSocketChannelBinding] - The interval to retry connection setups will be set to the default value of 5
19:05:42.336 [INFO ] [t.AbstractSocketChannelBinding] - The cron job to reset connections will be set to the default value of 0 0 0 * * ?
19:05:42.343 [INFO ] [t.AbstractSocketChannelBinding] - The setting to queue write operation until a channel gets connected will be set to the default value of true
19:05:42.345 [INFO ] [t.AbstractSocketChannelBinding] - The port to listen for incoming connections will be set to the default value of 0
19:05:42.346 [INFO ] [t.AbstractSocketChannelBinding] - The setting to share channels within an Item will be set to the default value of true
19:05:42.348 [INFO ] [t.AbstractSocketChannelBinding] - The setting to share channels between the items with the same direction will be set to the default value of true
19:05:42.350 [INFO ] [t.AbstractSocketChannelBinding] - The setting to share channels between directions will be set to the default value of true
19:05:42.352 [INFO ] [t.AbstractSocketChannelBinding] - The setting to use address masks for incoming connections will be set to the default value of true
19:05:42.355 [INFO ] [t.protocol.internal.TCPBinding] - The maximum time out for blocking write operations will be set to the default vaulue of 3000
19:05:42.357 [INFO ] [t.protocol.internal.TCPBinding] - The blocking nature of read/write operations will be set to the default vaulue of false
19:05:42.359 [INFO ] [t.protocol.internal.TCPBinding] - The preamble for all write operations will be set to the default vaulue of
19:05:42.360 [INFO ] [t.protocol.internal.TCPBinding] - The postamble for all write operations will be set to the default vaulue of
19:05:42.363 [INFO ] [.service.AbstractActiveService] - TCP Refresh Service has been started
19:05:42.366 [INFO ] [t.protocol.internal.TCPBinding] - Updating states with returned values will be set to the default vaulue of true
19:05:42.368 [INFO ] [t.protocol.internal.TCPBinding] - The characterset will be set to the default vaulue of ASCII
19:05:44.518 [INFO ] [.service.AbstractActiveService] - HTTP Refresh Service has been started
19:05:47.205 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘doorbell.rules’
19:05:48.026 [INFO ] [tion.xmpp.internal.XMPPConnect] - Connection to XMPP as ‘xxx.xxx@gmail.com/3AEA744D’ has been established. Is secure/encrypted: true
19:05:48.086 [WARN ] [io.squeezeserver.SqueezeServer] - Unexpected or unsupported configuration: squeezebox.host. Ignoring.
19:05:48.318 [WARN ] [j.smack.util.PacketParserUtils] - Failed to parse extension packet in Presence packet.
19:05:48.346 [INFO ] [.service.AbstractActiveService] - Satel Refresh Service has been started
19:05:48.366 [INFO ] [o.o.b.s.i.protocol.Ethm1Module] - Connecting to ETHM-1 module at 192.168.1.191:7094
19:05:48.388 [INFO ] [o.o.b.s.i.protocol.Ethm1Module] - ETHM-1 module connected successfuly
19:05:48.579 [INFO ] [o.o.b.s.i.protocol.SatelModule] - Connection to Integra 64 initialized. Version: 1.13 2014-11-18.
19:05:48.728 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘mailbox.rules’
19:05:48.796 [INFO ] [.service.AbstractActiveService] - Exec Refresh Service has been started
19:05:49.060 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘securityviolation.rules’
19:05:49.324 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘dashboard.rules’
19:05:51.572 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘doorlock.rules’
19:05:51.609 [INFO ] [.service.AbstractActiveService] - XBMC Refresh Service has been started
19:05:52.494 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘voicecommand.rules’
19:05:54.350 [DEBUG] [o.o.b.w.i.bus.WeatherActivator] - Weather binding has been started.
19:05:54.786 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘squeeze.rules’
19:05:55.387 [DEBUG] [.WeatherGenericBindingProvider] - Adding item Humidity with WeatherBindingConfig[locationId=home,type=atmosphere,property=humidity,roundingMode=HALF_UP,scale=2]
19:05:55.391 [DEBUG] [.WeatherGenericBindingProvider] - Adding item Visibility with WeatherBindingConfig[locationId=home,type=atmosphere,property=visibility,roundingMode=HALF_UP,scale=2]
19:05:55.396 [DEBUG] [.WeatherGenericBindingProvider] - Adding item Visibility_Mph with WeatherBindingConfig[locationId=home,type=atmosphere,property=visibility,roundingMode=HALF_UP,scale=2,unit=MPH]
19:05:55.408 [DEBUG] [.WeatherGenericBindingProvider] - Adding item Pressure with WeatherBindingConfig[locationId=home,type=atmosphere,property=pressure,roundingMode=HALF_UP,scale=2]
19:05:55.412 [DEBUG] [.WeatherGenericBindingProvider] - Adding item Pressure_Inches with WeatherBindingConfig[locationId=home,type=atmosphere,property=pressure,roundingMode=HALF_UP,scale=2,unit=INCHES]
19:05:55.417 [DEBUG] [.WeatherGenericBindingProvider] - Adding item Pressure_Trend with WeatherBindingConfig[locationId=home,type=atmosphere,property=pressureTrend]
19:05:55.420 [DEBUG] [.WeatherGenericBindingProvider] - Adding item Ozone with WeatherBindingConfig[locationId=home,type=atmosphere,property=ozone,roundingMode=HALF_UP,scale=2]
19:05:55.425 [DEBUG] [.WeatherGenericBindingProvider] - Adding item UV_Index with WeatherBindingConfig[locationId=home,type=atmosphere,property=uvIndex,roundingMode=HALF_UP,scale=0]
19:05:55.903 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.relative_humidity,target=atmosphere.humidity,converter=PERCENT_INTEGER]
19:05:55.906 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=avehumidity,target=atmosphere.humidity,converter=INTEGER]
19:05:55.908 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=humidity,target=atmosphere.humidity,converter=INTEGER]
19:05:55.910 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=humidity,target=atmosphere.humidity,converter=FRACTION_INTEGER]
19:05:55.913 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=humidity,target=atmosphere.humidity,converter=INTEGER]
19:05:55.915 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=atmosphere.humidity,target=atmosphere.humidity,converter=INTEGER]
19:05:55.920 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=humidity,target=atmosphere.humidity,converter=INTEGER]
19:05:55.924 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.visibility_km,target=atmosphere.visibility,converter=DOUBLE]
19:05:55.927 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=visibility,target=atmosphere.visibility,converter=DOUBLE]
19:05:55.929 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=visibility,target=atmosphere.visibility,converter=DOUBLE]
19:05:55.931 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=atmosphere.visibility,target=atmosphere.visibility,converter=DOUBLE]
19:05:55.933 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=visibilityKM,target=atmosphere.visibility,converter=DOUBLE]
19:05:55.943 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.pressure_mb,target=atmosphere.pressure,converter=DOUBLE]
19:05:55.946 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=pressure,target=atmosphere.pressure,converter=DOUBLE]
19:05:55.948 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=pressure,target=atmosphere.pressure,converter=DOUBLE]
19:05:55.950 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=pressure,target=atmosphere.pressure,converter=DOUBLE]
19:05:55.952 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=atmosphere.pressure,target=atmosphere.pressure,converter=DOUBLE]
19:05:55.961 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=pressureMB,target=atmosphere.pressure,converter=DOUBLE]
19:05:55.976 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.pressure_trend,target=atmosphere.pressureTrend,converter=PRESSURE_TREND]
19:05:55.979 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=ozone,target=atmosphere.ozone,converter=INTEGER]
19:05:55.991 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.UV,target=atmosphere.uvIndex,converter=INTEGER]
19:05:55.993 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=uvIndex,target=atmosphere.uvIndex,converter=INTEGER]
19:05:55.998 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=clouds.all,target=clouds.percent,converter=INTEGER]
19:05:56.006 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=clouds,target=clouds.percent,converter=INTEGER]
19:05:56.008 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=cloudCover,target=clouds.percent,converter=FRACTION_INTEGER]
19:05:56.011 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=cloudcover,target=clouds.percent,converter=INTEGER]
19:05:56.013 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=sky,target=clouds.percent,converter=INTEGER]
19:05:56.027 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.weather,target=condition.text,converter=STRING]
19:05:56.031 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=conditions,target=condition.text,converter=STRING]
19:05:56.033 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=weather.description,target=condition.text,converter=STRING]
19:05:56.036 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=summary,target=condition.text,converter=STRING]
19:05:56.038 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=weatherDesc.value,target=condition.text,converter=STRING]
19:05:56.041 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=text,target=condition.text,converter=STRING]
19:05:56.043 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=weather,target=condition.text,converter=STRING]
19:05:56.056 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.observation_epoch,target=condition.observationTime,converter=UNIX_DATE]
19:05:56.058 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=date.epoch,target=condition.observationTime,converter=UNIX_DATE]
19:05:56.060 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=dt,target=condition.observationTime,converter=UNIX_DATE]
19:05:56.062 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=time,target=condition.observationTime,converter=UNIX_DATE]
19:05:56.064 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=localObsDateTime,target=condition.observationTime,converter=UTC_DATE]
19:05:56.066 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=date,target=condition.observationTime,converter=DATE]
19:05:56.069 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=lastBuildDate,target=condition.observationTime,converter=FULL_UTC_DATE]
19:05:56.071 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=forecast.date,target=condition.observationTime,converter=SIMPLE_DATE]
19:05:56.080 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=ob.timestamp,target=condition.observationTime,converter=UNIX_DATE]
19:05:56.083 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=periods.timestamp,target=condition.observationTime,converter=UNIX_DATE]
19:05:56.088 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=weather.id,target=condition.id,converter=STRING]
19:05:56.090 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=code,target=condition.id,converter=STRING]
19:05:56.093 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=weatherCode,target=condition.id,converter=STRING]
19:05:56.095 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=weatherPrimaryCoded,target=condition.id,converter=MULTI_ID]
19:05:56.101 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=icon,target=condition.icon,converter=STRING]
19:05:56.104 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=icon,target=condition.icon,converter=STRING]
19:05:56.107 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.icon,target=condition.icon,converter=STRING]
19:05:56.109 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=simpleforecast.forecastday.icon,target=condition.icon,converter=STRING]
19:05:56.112 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=icon,target=condition.icon,converter=STRING]
19:05:56.119 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=precipIntensity,target=precipitation.rain,converter=DOUBLE]
19:05:56.122 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.precip_1hr_metric,target=precipitation.rain,converter=DOUBLE]
19:05:56.125 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=qpf_allday.mm,target=precipitation.rain,converter=DOUBLE]
19:05:56.128 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=rain.3h,target=precipitation.rain,converter=DOUBLE_3H]
19:05:56.130 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=rain,target=precipitation.rain,converter=DOUBLE_3H]
19:05:56.133 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=rain.1h,target=precipitation.rain,converter=DOUBLE]
19:05:56.135 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=precipMM,target=precipitation.rain,converter=DOUBLE]
19:05:56.138 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=precipMM,target=precipitation.rain,converter=DOUBLE]
19:05:56.143 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=snow_allday.cm,target=precipitation.snow,converter=DOUBLE]
19:05:56.150 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=snow.3h,target=precipitation.snow,converter=DOUBLE_3H]
19:05:56.153 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=snowDepthCM,target=precipitation.snow,converter=DOUBLE]
19:05:56.158 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=precipType,target=precipitation.type,converter=STRING]
19:05:56.162 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=precipProbability,target=precipitation.probability,converter=FRACTION_INTEGER]
19:05:56.164 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=pop,target=precipitation.probability,converter=INTEGER]
19:05:56.173 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.temp_c,target=temperature.current,converter=DOUBLE]
19:05:56.176 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=main.temp,target=temperature.current,converter=DOUBLE]
19:05:56.179 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=temp.day,target=temperature.current,converter=DOUBLE]
19:05:56.181 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=currently.temperature,target=temperature.current,converter=DOUBLE]
19:05:56.183 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=temp_C,target=temperature.current,converter=DOUBLE]
19:05:56.186 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=condition.temp,target=temperature.current,converter=DOUBLE]
19:05:56.189 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=tempC,target=temperature.current,converter=DOUBLE]
19:05:56.196 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=low.celsius,target=temperature.min,converter=DOUBLE]
19:05:56.198 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=main.temp_min,target=temperature.min,converter=DOUBLE]
19:05:56.201 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=temp.min,target=temperature.min,converter=DOUBLE]
19:05:56.203 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=temperatureMin,target=temperature.min,converter=DOUBLE]
19:05:56.211 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=tempMinC,target=temperature.min,converter=DOUBLE]
19:05:56.214 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=forecast.low,target=temperature.min,converter=DOUBLE]
19:05:56.217 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=minTempC,target=temperature.min,converter=DOUBLE]
19:05:56.223 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=high.celsius,target=temperature.max,converter=DOUBLE]
19:05:56.226 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=main.temp_max,target=temperature.max,converter=DOUBLE]
19:05:56.228 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=temp.max,target=temperature.max,converter=DOUBLE]
19:05:56.231 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=temperatureMax,target=temperature.max,converter=DOUBLE]
19:05:56.234 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=tempMaxC,target=temperature.max,converter=DOUBLE]
19:05:56.236 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=forecast.high,target=temperature.max,converter=DOUBLE]
19:05:56.239 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=maxTempC,target=temperature.max,converter=DOUBLE]
19:05:56.243 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.feelslike_c,target=temperature.feel,converter=DOUBLE]
19:05:56.246 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=feelslikeC,target=temperature.feel,converter=DOUBLE]
19:05:56.255 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.dewpoint_c,target=temperature.dewpoint,converter=DOUBLE]
19:05:56.257 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=dewPoint,target=temperature.dewpoint,converter=DOUBLE]
19:05:56.260 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=dewpointC,target=temperature.dewpoint,converter=DOUBLE]
19:05:56.271 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=DewPointC,target=temperature.dewpoint,converter=DOUBLE]
19:05:56.278 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.wind_kph,target=wind.speed,converter=DOUBLE]
19:05:56.285 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=avewind.kph,target=wind.speed,converter=DOUBLE]
19:05:56.296 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=speed,target=wind.speed,converter=DOUBLE]
19:05:56.307 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=windSpeed,target=wind.speed,converter=WIND_MPS]
19:05:56.312 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=windspeedKmph,target=wind.speed,converter=DOUBLE]
19:05:56.316 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=wind.speed,target=wind.speed,converter=DOUBLE]
19:05:56.322 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=windSpeedKPH,target=wind.speed,converter=DOUBLE]
19:05:56.330 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=winddir16Point,target=wind.direction,converter=STRING]
19:05:56.344 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.wind_degrees,target=wind.degree,converter=INTEGER]
19:05:56.356 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=avewind.degrees,target=wind.degree,converter=INTEGER]
19:05:56.373 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=deg,target=wind.degree,converter=INTEGER]
19:05:56.376 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=windBearing,target=wind.degree,converter=INTEGER]
19:05:56.378 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=winddirDegree,target=wind.degree,converter=INTEGER]
19:05:56.380 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=wind.direction,target=wind.degree,converter=INTEGER]
19:05:56.398 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=windDirDEG,target=wind.degree,converter=INTEGER]
19:05:56.402 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.wind_gust_kph,target=wind.gust,converter=DOUBLE]
19:05:56.404 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=wind.gust,target=wind.gust,converter=DOUBLE]
19:05:56.412 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=windGustKPH,target=wind.gust,converter=DOUBLE]
19:05:56.422 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=wind.chill,target=wind.chill,converter=DOUBLE]
19:05:56.489 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=windchill_c,target=wind.chill,converter=DOUBLE]
19:05:56.497 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=windchillC,target=wind.chill,converter=DOUBLE]
19:05:56.514 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.observation_location.full,target=station.name,converter=STRING]
19:05:56.518 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=place.name,target=station.name,converter=STRING]
19:05:56.524 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.station_id,target=station.id,converter=STRING]
19:05:56.537 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=response.id,target=station.id,converter=STRING]
19:05:56.540 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.observation_location.latitude,target=station.latitude,converter=DOUBLE]
19:05:56.541 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=loc.lat,target=station.latitude,converter=DOUBLE]
19:05:56.557 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=current_observation.observation_location.longitude,target=station.longitude,converter=DOUBLE]
19:05:56.560 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=loc.long,target=station.longitude,converter=DOUBLE]
19:05:56.575 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping HAMWEATHER: ProviderMappingInfo[source=error.description,target=weather.error,converter=STRING]
19:05:56.578 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping FORECASTIO: ProviderMappingInfo[source=error,target=weather.error,converter=STRING]
19:05:56.581 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=message,target=weather.error,converter=STRING]
19:05:56.583 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WORLDWEATHERONLINE: ProviderMappingInfo[source=data.error.msg,target=weather.error,converter=STRING]
19:05:56.606 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping WUNDERGROUND: ProviderMappingInfo[source=response.error.type,target=weather.error,converter=STRING]
19:05:56.608 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping YAHOO: ProviderMappingInfo[source=error.description,target=weather.error,converter=STRING]
19:05:56.613 [TRACE] [b.w.i.metadata.MetadataHandler] - Added provider mapping OPENWEATHERMAP: ProviderMappingInfo[source=cod,target=weather.responseCode,converter=INTEGER]
19:05:56.671 [TRACE] [b.w.i.metadata.MetadataHandler] - Added forecast mapping OPENWEATHERMAP: list
19:05:56.672 [TRACE] [b.w.i.metadata.MetadataHandler] - Added forecast mapping WUNDERGROUND: forecast.simpleforecast.forecastday
19:05:56.674 [TRACE] [b.w.i.metadata.MetadataHandler] - Added forecast mapping FORECASTIO: daily.data
19:05:56.678 [TRACE] [b.w.i.metadata.MetadataHandler] - Added forecast mapping WORLDWEATHERONLINE: data.weather
19:05:56.680 [TRACE] [b.w.i.metadata.MetadataHandler] - Added forecast mapping YAHOO: query.results.channel.item.forecast
19:05:56.681 [TRACE] [b.w.i.metadata.MetadataHandler] - Added forecast mapping HAMWEATHER: response.responses.response.periods
19:05:57.126 [DEBUG] [.w.internal.gfx.WeatherServlet] - Starting up weather servlet at /weather
19:05:57.786 [INFO ] [.service.AbstractActiveService] - NTP Refresh Service has been started
