Many thanks to make this great feature and widget. With my fresh new 2.3.0 install i have problems with making the widget visible. I think I’m missing something in my configuration. Weather Underground ‘thing’ is configured and online.
So… I’ve looked through the forum and am so close to getting this working. However rendering up the icons is proofing a little beyond me. I’ve got the widget and binding installed and working… And the static images too. However the icons don’t render.
I’m pretty sure I downloaded and installed the latest build version but my iconKey channel is not available. Everything else is working fine. Do I need to revert back to #1212? Shouldn’t any of the newer builds work?
To be more specific, I downloaded #1226 (March14, 2018).
I’m having the same issue as you. The “Weather Icon” channel is present but not the “Weather IconKey”. The IconKey is used to pull the nicer images from the local server whereas the Weather Icon is a Base65 encoded image coming from WeatherUndergroud.
Yes, I downloaded the 2.3.0.SNAPSHOT addons, uninstalled the old binding, rebooted, and installed the new binding. The binding is listed as the 2.3.0.SNAPSHOT in PaperUI so I’m pretty sure I have the correct version.
I’ve since installed OpenHab 2.3.0-1 and still do not get an IconKey channel.
Yes, I validated that the icons are there. I think the issue is with the lack of a channel for the IconKey. There is no item to create that the Angular client code binds to. When I look at the rendered HTML the binding is giving a null value.
Well, therein lies my issue. I have the Weather icon option but no Weather icon key. Yes, I’ve clicked on the Show More. The Weather Icon isn’t available until you choose Show More. I don’t believe the Weather Icon was even available in the 2.2 binding.
I think you may have two versions of the binding installed.
If memory serves, bindings in the ADDON folder do not show up in PaperUI as installed.
Try removing the binding in PaperUI and just leave the downloaded binding in the ADDON folder. You should be able to check if it’s installed through the KARAF console.
After removing the existing weather underground things, uninstalling the binding, removing the JAR from my addons directory, and rebooting, I think the issue is fixed. After reinstalling the binding from what I assume was the 2.3.0-1 SNAPHOT, i now have an Icon Key channel.
